Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 09-12-2009, 09:55 PM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default Broken OEM Oil pickup ... Pictures
I still get the occasional call from customers asking me if the OEM pickup tube failures are real so I've created an album and will be updating it over time.
Most shops I speak with treat it like the Yeti, until they see an actual failure they don't believe the issue exists. What's really interesting is the recent shift in dealerships installing my aftermarket pickup (at the customers request) instead of putting an OEM one back in. In the past dealerships would ONLY install OEM parts.
So feel free to check out the pictures and if anyone has any questions feel free to post them.
OEM OIL PICKUP FAILURE PICTURES
KillerBMotorsport is offline   Reply With Quote
Old 09-12-2009, 10:13 PM   #2
SLI99
Member#: 134819
2005 Ford F150 FX4
the same exact thing occured to big AL at ICS performance in stanford, CT .....broken oil pickup
SLI99 is offline   Reply With Quote
Old 09-12-2009, 11:51 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I had a question in another forum regarding the new models, has the pickup been changed/updated with the changes in 2008 and newer?
The answer is, no they have not. ALL EJ25 motors have the same pickup from 2006-current model year. This includes Impreza, Legacy and Forester models.
Old 09-13-2009, 02:03 AM   #4
autofinesse
Member#: 217663
Whats the reason behind this failure? I have the 2L in my 05 and I just picked up an 06 sti pan/pickup/baffle for some added insurance for my engine but the last thing I'd want to deal with is abusted pickup. What happens when it does fail? Will it toast the motor right away?
autofinesse is offline   Reply With Quote
Old 09-13-2009, 08:36 AM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Here's a clip from an older thread of mine:
I’ve gotten many requests for detailed information regarding the Oil Pickup, both OEM and the one I sell so I thought I’d post, what I know, for everyone to see. Specifically the questions seemed to be about the factory pickup and how/why it fails. Bear in mind this is information that has been presented to me and I am no scientist.
So on to the factory pickups… They are brazed assemblies (it's kind of like welding, but more like soldering with temperatures much lower than welding ~800 degrees. The braze is the gold stuff you see between the parts, see pictures here). For the braze to properly hold the metal pieces together this stuff called 'flux' is put on the areas where the braze will be applied. The flux makes sure that when the parts are heated up that the braze flows between and sticks to the metal parts properly. When operators, or machines, puts the flux on these parts to get them ready for brazing, the flux must AT LEAST cover the area that needs to be brazed together. So the application of the flux is typically quite liberal and sloppy.
This application of flux and brazing seems to be done properly because I've never seen a braze joint failure. The problem is that the flux SHOULD be cleaned from the parts after the brazing process has been completed. We'll come back to this in a second.
Now the tube, where the failures occur, is a simple thin (~.030") wall seam welded tube. A seam welded tube is basically a long skinny flat piece of metal that gets rolled into a tube and then welded where the ends meet. If you look at some of the pics in my link above you'll see a distinct line that runs the length of the tube. That's the weld. Welded tubing has its downside. While cheap, the weld can be the achilies heal if not done properly. When done properly a weld in low carbon steel will be harder, stronger and more brittle. In this situation it's a rougher surface too (when you look under a microscope, compared to the non-welded areas). Anytime there is an irregularity on the surface of a material with lumps, bumps, pits, etc., it creates a weakness.
OK so let’s get back to the braze… When not removed from certain process affected areas, specifically a hardened brittle weld, it will get into any micro pock mark or pit when it's applied and heated and a chemical reaction will occur. The flux reacts with the specific metal condition of the weld (harder and pits, etc..) and will etch into the pits making them deeper... and can also make the metal more brittle too. This is what ends up weakening the tube to the point of crack formation. And the fact that it's bolted to the bottom of an engine and exposed to vibrations doesn't help either.
Speaking to vibrations and engines modified with bolt-ons. Engine vibration is not as much a contributing factor as you might initially think for a few reasons. The rotating assemblies are fairly well balanced and harmonically dampened. The oil pickup is submerged in oil, and filled with oil. This dampens the engine vibrations tremendously at the pickup. Some assume the pickup is just swinging around from the engine vibrations, but forget that the pickup is also in oil and full of oil. Now where high frequency vibrations do come from is the oil pump. Typically called ‘high frequency pressure pulsation’, these lower amplitude pulses can have a more pronounced affect because of harmonics that can build in the pickup assembly, possibly where a critical frequency may be being reached at certain RPMs (speed of the oil pump).
So essentially, based on what I have experienced and learned, the OEM oil pickup failures are initiated from a chemical reaction from braze flux on the weld seam and these weakened areas are taken advantage of by oil pump induced high frequency vibrations.
And another regarding catching the pressure drop with a guage:
P-iff, even if you had a guage it might not necessarily let you catch it in time. Failure is often rapid, because even when a crack starts to develop it will still suck oil to the pump. The pressure guage shows pressure after the pump and is not an ideal indicator of what's going on before the pump. There are some instances (I'm speaking from second hand information from other threads on here and other forums) where a pressure guage showed a decrease in pressure before complete failure. Personally at the flow rates this lubrication system is suposed to operate at, if there was a failure you'd have to be watching the guage as it happens and shut it down quickly! I don't watch my guages constantly, especially when flogging it Here's a pic of the lubrication system specs so you can see what I mean as far as how much oil (quarts per minute) should be flowing at higher RPMs.
Old 09-13-2009, 05:14 PM   #6
autofinesse
Member#: 217663
Thanks for the info, very helpful. So was it just the 06 pickups that suffered from this? Do the failures typically occur in nodded cars or has this also happened to factory 06+?
Old 09-13-2009, 05:32 PM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
From what I've been able to find, broken pickups in Subarus has been a problem since 1996, BUT it's more common in the EJ20 and EJ25 motors, from 2002 on. They made an update to the pickup/pan in 2006-current, and it actually has a worse failure rate than previous versions.
Modifications have nothing to do with the probablility of failure. There have even been a few rare cases (06 and 07) where the OEM one broke, was covered and replaced under warranty, and then the replaced unit broke. These all required a new shortblock and were in stock cars. This is also very rare, but if you search on here, you'll find all the info on it.
Old 09-14-2009, 04:48 PM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Added a couple more pictures.
Old 09-14-2009, 05:01 PM   #9
Mechie3
Member#: 120152
Interesting to see the oil specs of 14psi idle and 43psi @ 5krpms. Some people on here swear you're an idiot if you don't have 20psi @ idle and 80psi everyother time.
Mechie3 is offline   Reply With Quote
Old 09-14-2009, 09:16 PM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Your are correct. I keep that image handy just for that reason.
Old 10-22-2009, 11:51 PM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Added even more pics.
Old 10-23-2009, 12:37 AM   #12
falcon_view
Member#: 225651
04 Forester 2.5 XT
Found this to save the engine if the tube cracks or breaks
http://www.summitracing.com/parts/SU...5&autoview=sku
To over ride the switch to start, tap in the brake load side to the out bound side of the switch to get power when pressing the brake peddle,you need to add a diode to brake over ride wire so the brake lights don't stay on when the pressure switch closes. When oil pressure comes up release the brake peddle. You can kill the ignition and/or fuel pump with this switch. The kit comes with complete instructions so they may have a better idea on how to start the engine. I am calling tomorrow to find out more. In any case I am getting one.
Also it is a good anti theft device depending on how you wire it.
falcon_view is offline   Reply With Quote
Old 10-23-2009, 09:54 AM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
That's a pretty neat idea for those who don't who don't want to pay attention to idiot lights or for those of us that have a Subaru where the idiot light comes on at only 2psi.
The only downside I can see here, relating to busted oil pickups, is if you have a crack you may still maintain enough pressure to not trigger the sensor, but that low pressure at high RPM/load can be problematic.
The failures I've seen with high RPM pressure issues were all caught because of an observed lower oil pressure at high RPM, not at idle. If you're lucky enough to develop a crack (vs. the more common immediate failure) a guage is your best bet.
I think this sensor is a neat idea and a definite step up from the Suby OEM 2psi activation pressure, and obviously you can't be oblivious to your engine shutting off.
Old 10-23-2009, 10:24 AM   #14
falcon_view
Member#: 225651
04 Forester 2.5 XT
I wonder what the oil psi is when turning the engine with the starter and if it would get over 7 psi to close the oil pressure safety switch?
Just called summit racing and this switch is to be put into an oil passage point in the engine. The treads are not metric on the switch but are on the Subaru engines. So an adapter will be needed.
To see the instructions click on the the link here or in my first post then in the upper right you will find instruction sheet in a PDF and refer to diagram 3.
I have read in a thread that the crank position sensor will cut off ignition and fuel pump. If this is correct what is the voltage to the crank sensor? This would be a good place to tap into to kill the engine because the oil sending unit and crank sensor are very close to each other. What is the down side in this? Would you get a CODE if cranking the engine by not pressing a installed by pass switch and if so would the CODE clear once the by pass switch is activated?
Old 10-23-2009, 11:29 AM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Oil pressure is typically below 2psi when cranking, but can build a bit more if you keep cranking and cranking and cranking. You can really see this when you start your car after an oil change and the light stays on for a second or 2 after the car starts.
Old 10-23-2009, 11:37 AM   #16
falcon_view
Member#: 225651
04 Forester 2.5 XT
^^^added more need some help here in post 14.
Old 10-23-2009, 11:47 AM   #17
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
That's because 20psi at idle and 85 psi above ~3k RPM is normal for our cars. The above posted specs are the absolute bare minimum, if your oil pressure is below that then something is DEFINITELY wrong. Similarly, if your oil pressure is anywhere close to that number, something is probably wrong.
Old 10-23-2009, 02:14 PM   #18
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Oh really? My car sees around 14psi at idle and a maximum of 58psi at 7000rpm
wrxwhat is offline   Reply With Quote
Old 10-23-2009, 02:18 PM   #19
Member#: 51961
2005 STi
2012 WRX
Is your car stock? Or does it at least have the stock oiling system?
The oil pressure bypass opens at 85 psi, and it will hit the bypass pressure on a bone stock car all the way to redline (or at least close). If you're not hitting 85 psi from ~3k RPM and on, your oil passages are out flowing your oil pump. If you set it up this way by design (cross drilled crank, huge bearing clearances, etc), then fine, but if your car is stock, then something is probably wrong (failing oil pump, bypass stuck open, large oil leak (maybe a torn seal in the block), or your oil is too thin), because everybody else with a stock oiling system hits their bypass pressure to redline.
Old 10-23-2009, 02:39 PM   #20
newtothescene
Member#: 222368
2006 Cone Dodger
CGM
Ok, so how much in labour would it cost to replace the OEM pickup with an aftermarket one? Thinking of doing this before anything happens.
newtothescene is offline   Reply With Quote
Old 10-23-2009, 03:53 PM   #21
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
I have a stock oiling system. With "average" bearing clearances, not TIGHT, but not incredibly loose. My engine has been together for a long time though, so I don't think the "low" oil pressure is really doing any harm.
Old 10-23-2009, 03:59 PM   #22
Member#: 51961
2005 STi
2012 WRX
Maybe you have your oil pressure sensor near the end of the oil path?
Old 10-23-2009, 04:08 PM   #23
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
im glad we just got a bunch in, i've been hearing alot of failures as well
IMPORTIMAGE is offline   Reply With Quote
Old 10-23-2009, 04:12 PM   #24
richy_21
Member#: 58670
2005 got muuuuu?
bump for the oil deathhhh ps chris answer your phone i want to do work on the pan
richy_21 is offline   Reply With Quote
Old 10-23-2009, 06:03 PM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You leave a message? I was probably on the other line, phone has been ringing off the hook lately!
Broken OEM Oil Pickups... Pictures KillerBMotorsport Built Motor Discussion 35 04-25-2011 09:33 AM
OEM Oil Pickup Failures - Explained KillerBMotorsport Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 05-28-2009 12:19 AM
Ultimate Oil Pickup Groupbuy - Say NO to Oil Pickup Failure! KillerBMotorsport Vendor 'Group Buy' Classifieds 31 04-29-2009 03:57 PM
2.5 liter oil pan on 2.0 liter, oil pickup cabe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-07-2008 12:31 PM
CA: Perrin header and Sti oil pan w/oil pickup 1WRX2NV Engine/Power/Exhaust 2 02-18-2008 10:16 PM
