Old 04-09-2010, 10:21 PM   #51
4080wrx
Member#: 68129
Chapter/Region: HIIC
2001 Impreza RSTi
for those that have already removed the oil pan to install the new pick up tube. is there a oil pan gasket to replace? or do you use the Three Bond 1215 that the service manual says? I am almost certain the manual is correct but I just found it odd that there was no gasket to replace.
4080wrx is offline   Reply With Quote
Old 04-09-2010, 10:43 PM   #52
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
That's correct. Use a liquid gasket product. ThreeBond, HondaBond, Permatex, Fujibond are all products that are known to perform well.
KillerBMotorsport is offline   Reply With Quote
Old 04-10-2010, 12:06 AM   #53
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Glad i got one of your pick ups at a group buy. Will be installing it in the next 2 weeks. Will show pics of my OEM one that has 75,xxx miles on it.
BlackFighter is offline   Reply With Quote
Old 04-11-2010, 09:13 AM   #54
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Great, thanks!
Old 04-15-2010, 11:53 PM   #55
mike9807
Member#: 184913
2007 wrx sti
cgm
i received your pick up and installed it on my car KillerB. excellent construction quality and nice welds. looks like i caught mine it time. thanks for a good product. if you look at the photos it looks like a hair line crack was starting to form. 42,000 mi 25 some odd individual auto-x runs.
http://s289.photobucket.com/albums/ll239/mike9807/car/
mike9807 is offline   Reply With Quote
Old 04-16-2010, 09:38 AM   #56
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Good pics, you mind if I take a few to add to my ALBUM OF DOOM? Tough to say without having the part in my hands and with a strong eyeloop or microscope, but there appears to be a suspicious area.
Old 04-16-2010, 04:25 PM   #57
mike9807
Member#: 184913
2007 wrx sti
cgm
yeah i don't mind at all if you want to originals e-mail to you let me know, shot with a canon powershot sd750, pics aren't that great but some detail is present.
Old 04-27-2010, 07:59 PM   #58
mmetalmilitiaa
Member#: 160878
06 sti
sgm
Just replaced mine today. Thanks KillerB. I got lucky on this one!
2006 sti with 80,000 miles.
mmetalmilitiaa is offline   Reply With Quote
Old 05-14-2010, 03:34 PM   #59
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Old 05-14-2010, 03:36 PM   #60
M-dub39
Member#: 210599
2008 AW Sti
great product. We used 3 of them on our current Subaru Installs. Part looks great and alot of peace of mind. Very much worth it when doing a build.
M-dub39 is offline   Reply With Quote
Old 05-15-2010, 10:21 PM   #61
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the kind words!
Old 06-29-2010, 03:05 PM   #62
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Made a pickup video...
Old 06-29-2010, 04:52 PM   #63
Tenacious_B
Member#: 237770
Yikes, this thread has convinced me to use a killer b pickup when I do my rebuild...
Tenacious_B is offline   Reply With Quote
Old 07-29-2010, 10:02 PM   #64
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
MORE PICTURES ADDED!
And over 1,000 of our pickup units sold with not one single problem or return
Old 10-05-2010, 01:18 PM   #65
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
So here's another good reason to ditch the OEM oil pickup...
So I recently performed an install on a neighbor's 08 STi and I finally took some better pictures of the horrible factory pinch bend. While I've never performed flow tests, it seems pretty obvious that our part will have better flow performance compared to the OEM piece.
Here's a picture of the pinch bend (after I cut it). It tough to judge from the picture.
Here it is in cross section. Definitly not a nice smooth mandrel bend! Not only is the tubing squished you can see that it's necked down too
The inside diameter of out tube is slightly larger than OEM, but what you really notice here is the MUCH larger outside diameter. Notice how much closer our tube comes to the edge of the flange. Yes our flange is exactly the same as OEM except it is machined from solid steel, not stamped.
Another question regarding flow is with the screen and opening at the bottom. We use screen that is identical to OEM to maintain the same filtering properties. The screen area is larger which means there is more open area (total area of all the openings in the screen) for the oil to go through the screen. Lastly, to answer the "why is the bottom shaped so funny?" questions. That is to make sure if you ever smack your pan against something you don't EVER cut off oil flow. Flat bottom oil pickup = bad. That's the reason why the OEM one has dimples! Oh and the opneing on the bottom is larger than OEM too
Old 10-05-2010, 01:21 PM   #66
seekndestroy19
Member#: 209358
06 Sti
just got mine in the mail today and will attempt to install it this week. if anyone has any tips/tricks to installing this pm me please
seekndestroy19 is offline   Reply With Quote
Old 10-05-2010, 01:29 PM   #67
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the order! A few members have done install write-ups with pics and shortcuts. We have the "official" factory instruction on our website. If you find you're stuck on something, or have some questions, please don't hesitate to give us a call.
Old 10-15-2010, 09:37 AM   #68
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We get asked from time-to-time...
Our Ultimate Oil pickup includes a new O-Ring for positive sealing and the factory bolts can be re-used (torqued to spec please).
Old 10-16-2010, 12:43 PM   #69
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Broken OEM pickup = No oil flow = bad
Old 01-11-2011, 07:23 PM   #70
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Have been fielding questions lately about comparisons to OEM, etc and have added NEW PICTURES TO THE BROKEN OEM OIL PICKUP ALBUM
Old 01-12-2011, 03:39 PM   #71
lcjarrett
Member#: 133814
2008 AW STI
KillerB in Post #62 you guys introduced a EJ20 Oil Pickup. Do you guys still make that Oil Pickup?
lcjarrett is offline   Reply With Quote
Old 01-12-2011, 08:11 PM   #72
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We make the EJ20 pickups to order. We recommend andyone with an EJ20 that does any kind of performance driving to up grade to a 2004+ STi oil pan, or 2006+ Impreza, Forester or Legacy oil pan. They are more performance oriented and less likely to oil starve under high cornering forces.
95% of the time the EJ 20 "rugedized" pickup is sold to customers running a Cosworth or Arc oil pan that must use the OEM pickup.
Old 02-18-2011, 09:29 AM   #73
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
More pics added...
These cracks caused the "oil light flicker/on" at idle. We still see far more catastrophic failures with no oil light warning. Catching a crack on 2006-2011 cars is more common than the older gererations, but still a rare occurance.
Old 02-26-2011, 09:27 AM   #74
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Old 02-28-2011, 12:35 PM   #75
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Been getting some PMs lately, so just an FYI that this problem has been happening since the first EJ motors going back to 1993 (from what we've found) and even thought there have been changes to the pickups through model changes the failures still occur. The most recent design is used in all WRX & STi models from 2006 to 2011. We have our ultimate pickups installed in every model year from 1994 to 2010 so far.
Broken OEM Oil Pickups... Pictures KillerBMotorsport Built Motor Discussion 35 04-25-2011 08:33 AM
OEM Oil Pickup Failures - Explained KillerBMotorsport Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 05-27-2009 11:19 PM
Ultimate Oil Pickup Groupbuy - Say NO to Oil Pickup Failure! KillerBMotorsport Vendor 'Group Buy' Classifieds 31 04-29-2009 02:57 PM
2.5 liter oil pan on 2.0 liter, oil pickup cabe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-07-2008 11:31 AM
CA: Perrin header and Sti oil pan w/oil pickup 1WRX2NV Engine/Power/Exhaust 2 02-18-2008 09:16 PM
