Old 09-18-2012, 09:30 AM   #176
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by sjs0433 View Post
I'm pretty sure if I was to do the install a third time I could have the pan off in less than 10 minutes once all the bolts are removed.
You need to share your technique. I've done it more than that and it still frustrates me
KillerBMotorsport is offline   Reply With Quote
Old 09-18-2012, 09:56 AM   #177
sjs0433
Member#: 86061
I have the exhaust manifold completely removed as well as the oil filter. This gives me the most amount of room to work with. Motor is also jacked up with some 2x4 chunks under the motor mounts.
If you get a flathead screwdriver and put it in between the pan and motor mount silver plate (where it attaches to the motor on the passenger side) you can kind of pry at it and you'll see the pan flex a small amount right in that area. I then took a narrow putty knife and was able to just sneak the corner in where the sealant would be. Then take a hammer and lightly tap at it until it sneaks far enough into the pan (you wouldn't be able to do this without the header removed). You can watch the knife go right past one of the bolt holes and that's how you know it's getting into the pan. That completely breaks the seal in about a 2" wide area and once I got that much it pretty much let go everywhere else. I used a pretty dull putty knife and it didn't score the block in any way.
Again I think the key is having a lot of working room by having the header and oil filter removed. When I did it on the first STI I got lucky and my old gaskets didn't leak. This time I wasn't so lucky but I'll take an exhaust leak over oil pan leak any day. Much easier and less time consuming to fix.
sjs0433 is offline   Reply With Quote
Old 09-18-2012, 12:13 PM   #178
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Cool, thanks! I'll add this post to my list of techiquest to try next time
Old 09-19-2012, 04:39 PM   #179
allums34
Member#: 331631
2002 impreza wrx
blue
Default oil pick up tube
i am new to the subie world move over from hondas. i bought a 02 subaru wrx impreza. my oil was flashing, so i change the pickup tube right away. put everything back to gether went on a test drive, as soon as i came to a stop light oil light start flickering again. could it be from a low idle and some of the wiring in the car look hack i would love some feed back.
allums34 is offline   Reply With Quote
Old 09-19-2012, 09:54 PM   #180
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Is there a gauge on the car by chance? Is the flickering bright, as bright as it comes on when the ignition is turned on?
What oil pickup did you put on there?
Old 11-29-2012, 10:01 AM   #181
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Couple pics from a customer who swaped out his pickup earlier this month. The OEM oil light did not come on
Old 11-29-2012, 11:27 AM   #182
salvi
Member#: 188132
It's still good....
salvi is offline   Reply With Quote
Old 11-29-2012, 11:31 AM   #183
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
How I don't know. That is a bad crack.
Old 11-30-2012, 12:00 AM   #184
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Wow what vehicle??Also I just picked up another set!!pickup and baffle for my other block!
The one on my car has the full kit!!Love this mod!Also got a set of decals from you guys awesome,do you have the ones that acctually go right on the killer bee oil pan??like this?? http://img830.imageshack.us/img830/2397/wrxpic1.jpg
EROCS04SBRUSTI is offline   Reply With Quote
Old 11-30-2012, 12:24 AM   #185
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks!!
Thanks actually not a sticker. It's marked right into the pan Do you have a pan without one?
Old 11-30-2012, 04:08 PM   #186
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
I am swapping pistons this weekend and we popped the oil pan off last night and looked over the oil pick up and it seems to be doing good still at both ends are solid, not bad for 123,870 miles. Would love to get the oil pickup and baffle as preventive maintenance, but my budget is in the negatives atm.
WRXSteye20008 is offline   Reply With Quote
Old 11-30-2012, 04:22 PM   #187
iberian_wolf
Member#: 107228
2006 WRX Wagon
Other than some exhaust hardware annoyances, this pickup was pretty easy to put on my 2006. Didn't have to jack up the motor at all. On disassembly, the pan had to hang off the factory pickup until I unbolted it. But for reassembly, the Killer B piece was fully installed the the pan was able to be wiggled around and into place without even messing up the bead of sealant.
iberian_wolf is offline   Reply With Quote
Old 11-30-2012, 05:50 PM   #188
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Originally Posted by KillerBMotorsport View Post
Thanks!!
yup without one u want a pic??
Old 11-30-2012, 06:11 PM   #189
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The other end is the critical side. I've heard a few rumors of them breaking on the end you're showing here, but I've never actually seen one so until I can verify it for myself it's not a failure point IMO.
Check the other end VERY well (decent eye loop at the minimum) looking for the ques I noted here.
Originally Posted by killerbmotorsport View Post
You should have just changed it while you were there. If you're going to stick with the OEM pickup we recommend changing them every 20K miles to minimize the probability of failure. On more than one occasion we've had customer inspect and re-install only to have later failure. Highest mileage failure to date, 205K miles.
Here are a couple examples showing the stress tell, before the crack. Look for spidering in the flux that will eventually turn to little pieces flaking off. When I mean look carefully I mean you may need an eye loop or low power scope to see anything, like in these pics.
In this pic below you can see the tube's weld seam. 99% for the time, this is where the crack originates from. On the weld seam in the braze flux.
As it progresses a small crack will form. It's all downhill from here...
No. I want you to send me the pan so I can mark it for you
Old 11-30-2012, 06:47 PM   #190
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Will do when I disassemble the block,it's installed now<i have to pm you way later on.when I do.Make me a decal like this!!So much better than the round one to market you parts.
Old 12-01-2012, 08:40 AM   #191
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
I understand. I picked them up last week and the build quality is AMAZING! I feel 100% safer with this in my car over the oem pickup. The windage tray is nice as well
Old 12-28-2012, 01:48 AM   #192
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
possible bad tube in '13 FB engine;
http://www.subaruoutback.org/forums/...tml#post492494
1 Lucky Texan is offline   Reply With Quote
Old 12-28-2012, 06:45 AM   #193
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ I'll do some research, but those engines, and pickup tube, are VERY different than the EJ engines that are known for the pickup failures. Keep me informed as to what they find when they pull the motor.
Old 12-28-2012, 12:27 PM   #194
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
well, I said 'possible' - but should have held off completely because, now, they confirm it was missing!
I can only assume they mean the entire assembly was never bolted on at the factory - not that some portion fell off.
still 'second hand info' from a dealer, supposedly confirmed by conversation with SOA, and then reported on a Forum so......
Old 12-28-2012, 01:26 PM   #195
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
I have to order up a pick up and baffle.
-Mark
APM Tuned is offline   Reply With Quote
Old 12-28-2012, 01:46 PM   #196
Jdub.csu
Member#: 283784
2013 EVO X GSR
I won your guys pickup tube and baffle from rallysportdirect's facebook contest! So thanks I won't have to deal with the stock pickup. My friend just lost his motor because of it.
Jdub.csu is offline   Reply With Quote
Old 12-28-2012, 02:04 PM   #197
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
That would be SUPER rare to not have one bolted in there. Not to mention it run as long as it did. I just don't see how that's possible, but I am not nearly as versed with the RA engines as the EJs. See if the dealer can provide pics when they pop the pan off. If the tube fell right off, that would be useful info!
-Mark
We've got plenty ready to go
Awesome, congrats on the win! No one ever likes to hear of a downed Suby
Old 01-10-2013, 09:22 PM   #198
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
Had my oil pickup replaced today on a 2006 STi (71k) miles with a KillerBee pickup and baffle which is amazing quality. After looking at my old one it seems that its in good shape, no major cracks or anything but I think in the 3rd picture there is a slight surface crack, i'm not exactly sure though if anyone has any input please post. Its still good insurance to have though. After looking at the old one it seems like a 5 year old made it, very poorly made.
WaitTheresMore is offline   Reply With Quote
Old 01-11-2013, 10:41 AM   #199
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Tough to tell, more magnification is required to make a judgement on that. I see a couple things that may or may not be questionable, but no point in worrying over it now
Thanks for using our product!
Old 01-11-2013, 12:08 PM   #200
Larimer
Member#: 205191
2006 Saab 9-2X Aero
Is it possible to just weld the stock piece up instead of the braze? Seems like that would be a cheaper fix.
Larimer is offline   Reply With Quote
Broken OEM Oil Pickups... Pictures KillerBMotorsport Built Motor Discussion 35 04-25-2011 08:33 AM
OEM Oil Pickup Failures - Explained KillerBMotorsport Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 05-27-2009 11:19 PM
Ultimate Oil Pickup Groupbuy - Say NO to Oil Pickup Failure! KillerBMotorsport Vendor 'Group Buy' Classifieds 31 04-29-2009 02:57 PM
2.5 liter oil pan on 2.0 liter, oil pickup cabe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-07-2008 11:31 AM
CA: Perrin header and Sti oil pan w/oil pickup 1WRX2NV Engine/Power/Exhaust 2 02-18-2008 09:16 PM
