#1 |
Member#: 219426
Vehicle:2004 Subaru WRX WRB Stage II |
What seems to work better? I think ramps would allow for a more secure and bigger working space. However with being in college I need somethin I can take with me. I will mainly need it for changing oil, eventually installing a cat-back, and other repairs.
#2 |
Member#: 183247
E. Canada
Vehicle:2005 WRX WRB |
both... ramps are good for quick oil changes.. jack stands you'll need for exhaust work, brakes, everything else else..
if you can have only one then 4 good jack stands and a low profile jack.. |
#3 |
Member#: 195711
Vehicle:STi 04/05/06/07 JBP / OBP for now |
Jack stands are less likely to be in your way while working under the car...I also prefer them to ramps because I watched my girlfriends dad miss the ramp and mess stuff up lol.
I feel that stands are safer, and they aren't that expensive...even generic ones will be 95% as good as expensive ones IMO. Only thing they may lack is the adjust ability settings. 4 Stands for under 50 bucks... http://www.sears.com/shc/s/p_10153_1...0070921x00003a |
#4 |
Member#: 96951
Vehicle:2004 wrx sedan 1996 brighton coupe |
ramps are ok for oil changes, but thats about it. if you plan on doing brake work or anything else that involves pulling wheels or needing extra height, get a jack and jackstands instead.
#5 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2007 Lotus Elise (From General) |
You can build ramps with scrap 2x4's/2/6 or any scrap lumber. Just steps up. I had some like that back in the before time.
I use my jack stands all the time.......even though I've got a 4 post lift in my garage. jack |
#6 |
Member#: 179573
South East
Vehicle:2002 MBP Bugeye Flip Flop Tuned on corn |
#7 |
Member#: 159796
SCIC
Vehicle:2006 WRX |
if you'll be installing a catback.. i really dont think ramps will work. just get 4 stands and 1 low pro jack, as already mentioned above.
#8 |
Member#: 206806
Vehicle:1997 Legacy 2.5GT Dark Green |
Yeah both have their uses. I currently only use a jack and jack stands.
#9 |
Member#: 173755
Vehicle:05 STI Satin Black Specialized Allez Elite:) |
Install airjacks in your car.....then you'll never have any trouble bringing them with you
I would lean towards jack stands myself because like as said before they can be used for any project a ramp can and then some. And I've also seen a car get messed up from a ramp, my sister wanted to drive her own car up on them so my dad could do an oil change......more gas, more, little more, VROOM, STOP, BOOM. She drove up and over and got them jammed under the sideskirts hehehe |
#10 |
Member#: 152042
NWIC
Vehicle:2002 WRX WRB |
low profile jack if you have a lowered car and 4 4 ton jack stands. Mine go from 14-21". make sure your jack can lift at least the same height as the jacks. My dad has a pretty sweet jack that raises like 5 inches each pump until it touches the car then acts like a normal jack.
#11 |
Member#: 1403
TXIC
Vehicle:99 RBP GC8 Impreza |
#12 |
Member#: 88618
SCIC
Vehicle:1994 Legacy "The Silver Slug" |
#13 |
Member#: 211913
Vehicle:Nine 4drs & 4whls ಠ_ಠ |
id just go with jacks, the ramp is fine if you need to do quck fluid changes, but everything else a jack will be better for you to get under the car and especially if you only need to raise one side of the car, that and it takes less space
#14 |
Member#: 210513
SWIC
Vehicle:02 wrx sedan wrb |
#15 |
Member#: 149730
Vehicle:2002 Impreza WRX PSM |
+1 for Jack Stands
#16 |
Member#: 128492
HIIC
Vehicle:2002 WRX - Hybrid PSM |
You can do just about anything with the spare jack in the trunk. Well anything that doesn't require both wheels off the ground at the same time. But for your oil changes and catback, ramps and jackstands aren't needed IMHO.
IBblahblahblahwhatifitbreaksandfallsonyou. |
#17 |
Member#: 105796
South East
Vehicle:2006 WRX Pastelito Racing |
Yeah, I would say jack stands, but that's just because I absolutely suck at getting up on ramps.
#18 |
Member#: 189525
NWIC
Vehicle:2007 WRX Wagon Invisible Plain |
There is one major need for ramps that surprisingly nobody has mentioned.
Perhaps they don't use their car for performance driving applications, or they have a lift in their garage, bastards. Anti roll bar components must be torqued under load, I am only lowered 1.25" or so, but I can't get under the front to get to it. Yes the old 2x? wood makeshift setup works just fine, but I got some rhino Xtra duty ramps (fits up to 10" width) and they work great, but then I adjust, grease, and generally maintain my suspension components extremely regularly. Of course I also have tall jack stands and I couldn't do much without them either, because I don't have a lift in my garage like some people, bastards. |
#19 |
Member#: 219426
Thanks everyone for all your input. Seems the choice is obvious. Thanks again.
#20 |
Member#: 219426
Yeah if anyone is lookin for good cheap jack stands, I found these.... (from Harbor Freight Tools)
2- 3 Ton Jack Stands for $20 http://www.harborfreight.com/cpi/cta...emnumber=38846 |
#21 | |
Member#: 142029
Vehicle:2013 Fozz 2004 STi, 1991 Miata BRG |
I mean sure you can do it but why risk it? Jack stands cost like 20 bucks. |
#22 |
Member#: 187021
Vehicle:2004 WRX Sedan PSM FP18g, TXS FMIC,UP,TBE |
Ideally both but you'll get more out of the jack stands. Also you should be using jack stands with the ramps anyway for safety.
#23 |
Member#: 128494
NWIC
Vehicle:2004 WRX wagon Silver |
Jacks
#24 |
Member#: 1748
NESIC
Vehicle:'09 Outback Sport OBP over DGM |
#25 |
Member#: 219426
Yes, the jacks...I already found some nice ones from Harbor Freight Tools. just need a cheap jack
| Thread Tools | |
| Display Modes | |
| What is safer? ramps or jack stands? | mr2aniac | Service & Maintenance | 30 | 04-04-2008 10:53 PM |
| (VA) $20 for a Bunch of Stuff (Jack, Ramps, Jack Stands, etc) | DriveFast | MAIC Private Classifieds | 6 | 02-26-2007 02:39 PM |
| Swaybar install- ramps or jack stands? | roybfr | Brakes, Steering & Suspension | 15 | 04-21-2005 12:24 PM |
| Installing a catback … 2 or 4 jack stands? | 04.SPT.WRX | Service & Maintenance | 17 | 09-26-2004 01:05 AM |
| Axle stands vs. jack stands vs. axle jacks: I'm going under | Titanium Samurai | Service & Maintenance | 2 | 12-09-2002 11:11 PM |
