Old 09-14-2009, 01:26 AM   #1
greenc51
Member#: 154681
2012 135i
Alpine White
Unhappy Heard a Loud Crack and then the Clutch Pedal Flew to the Floor :(
So i'm driving along fine...accelerating ok with no problem. As I slow to make a turn around a corner, i push in the clutch to take it out of 4th and put into 2ndas i push in the clutch and put it in to 2nd, and slowly let up the clutch, i hear like a loud crack and then the clutch pedal flies to the floor. It then requires almost no effort to push in the pedal. So after this happened, it was next to impossible to put it in any gear. I was able to force it into first and kind limp it to where I was going, but after I got there, that was it. I could not put it into gear whatsoever. Someone helped me push it to the curb so it wasnt out in the middle of the street. And that was that...i had to have it towed to my house.
Tomorrow I guess Ill have it towed to the dealership and get a loaner or rental to hold me over.
Anyone have any ideas as to the issue??
greenc51 is offline   Reply With Quote
Old 09-14-2009, 03:28 AM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I'm betting the clutch fork broke or the clutch line ruptured.
Old 09-14-2009, 08:07 AM   #3
greenc51
Member#: 154681
2012 135i
Alpine White
is this a common occurrence?
Old 09-14-2009, 10:05 AM   #4
Button
Member#: 20620
2006 Outback 2.5 i
Willow Green Opal
Why were you goin' from 4th to 2nd?
Button is offline   Reply With Quote
Old 09-14-2009, 10:22 AM   #5
indoubt
Member#: 157470
08 WRX 4DR
he probably meant he was driving along in 4th, and pushed in the clutch to slow down when he got closer to the corner and put it in 2nd to make the turn
indoubt is offline   Reply With Quote
Old 09-14-2009, 10:36 AM   #6
mls1
Member#: 167607
2008 WRX
Thats what I got out of it also.
mls1 is offline   Reply With Quote
Old 09-14-2009, 10:48 AM   #7
02_scooby
Member#: 210513
02 wrx sedan
wrb
ya me to
02_scooby is offline   Reply With Quote
Old 09-14-2009, 10:58 AM   #8
twonb1
Member#: 129163
2011 evo x
Phantom Black
im thinking clutch fork cracked or the part that holds the clutch fork in place
twonb1 is offline   Reply With Quote
Old 09-14-2009, 11:02 AM   #9
forrealsss
Member#: 182954
2008 WRX hatch
SSM
It sounds like you tried to slip the clutch into 2nd... Try rev matching next time. Or double clutching if you don't want to wear the syncros either.
forrealsss is offline   Reply With Quote
Old 09-14-2009, 11:28 AM   #10
greenc51
Member#: 154681
2012 135i
Alpine White
i usually rev match...i dont like slipping the clutch at all. i dont remember slipping it this time around. i gave it some gas to get it up to around 2k rpm, and then let up on the clutch to catch, and as it caught, crack! the pedal had no feel to it. for 5 mins or so, i could still use the clutch pedal and it would grab at its normal point, but there was no feeling to the pedal, and it was difficult to get into any gears.
Old 09-14-2009, 11:43 AM   #11
kpluiten
Member#: 120273
06 WRBWRXWGN
Check the angle of the clutch fork on the top of the bell housing. Take a picture and post it up.
Old 09-16-2009, 11:36 PM   #12
greenc51
Member#: 154681
2012 135i
Alpine White
i got the car back and the clutch is SOFT...so so soft. but honestly, its easier to drive the car now and the entire clutch action is smooth and fluid
Old 09-17-2009, 01:15 AM   #13
MY00Forest
Member#: 75451
2000 Forester
black
uhoh!
recall?
MY00Forest is offline   Reply With Quote
Old 09-17-2009, 01:24 AM   #14
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
lolzz
m1r4g3 is offline   Reply With Quote
Old 09-17-2009, 01:26 AM   #15
MY00Forest
Member#: 75451
2000 Forester
black
spent springs?
how many miles on the car. didn't see it?
Old 09-17-2009, 01:29 AM   #16
greenc51
Member#: 154681
2012 135i
Alpine White
15,5xx
Old 09-17-2009, 01:32 AM   #17
MY00Forest
Member#: 75451
2000 Forester
black
damn i hate GM's
clutch pedal sucks to the floor during wot pulls wopdeeze Transmission (AT/MT) & Driveline 4 05-14-2009 05:10 PM
Problems after clutch install. Pedal goes to the floor then won't always retract Anhdalai Transmission (AT/MT) & Driveline 11 10-20-2007 10:02 PM
jdm 6 speed conversion: clutch pedal sticks to the floor akcel Transmission (AT/MT) & Driveline 5 05-08-2007 11:33 AM
Clutch pedal stays to the floor when car's hot RyansJDMgc8 Transmission (AT/MT) & Driveline 41 09-28-2005 04:52 PM
Clutch pedal sticking to the floor? AC Lerok Transmission (AT/MT) & Driveline 2 11-08-2004 01:11 PM
