Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 01-25-2012, 10:10 PM   #6226
.kyle
Member#: 174695
1983 antarctic blue
super sportswagon
Any specific cylinder or random?
.kyle is offline   Reply With Quote
Old 01-25-2012, 10:30 PM   #6227
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
Nope get them on all 4. Not one cylinder specific.
jrrevo1 is offline   Reply With Quote
Old 01-25-2012, 10:57 PM   #6228
.kyle
Member#: 174695
1983 antarctic blue
super sportswagon
crank sensor. may still be the flywheel. may be fine metal shavings on the tip of the sensor. may be an imperfectly machined crank pulley/tone wheel. may be lack of grounding on the engine harness (corrosion, etc).
Old 01-25-2012, 11:19 PM   #6229
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
well the crank pulley is stock and last i checked the grounds were all good. where is the sensor located to have a looks see?
Old 01-26-2012, 01:06 AM   #6230
.kyle
Member#: 174695
1983 antarctic blue
super sportswagon
straight below the alternator. and i'm talking about the cogged pulley that drives the timing belt that has the tone wheel on it. not the accessory damper.
Old 01-26-2012, 01:13 AM   #6231
.kyle
Member#: 174695
1983 antarctic blue
super sportswagon
also my note about ground is more in depth. if the threads of the bolt/frame/block are corroded where the strap goes through it will create a voltage drop/resistance issue. sensor response is greatly diminished by poor ground. ie; an o2 sensor that would typically switch 8-10 times in a 5k mS interval will only switch 4-6 times from poor ground. this will cause fueling issues due to the pcm receiving what it believes to be a lean response when the engine is actually just fine. weak ground. on a crank sensor it will show up as a low return voltage. resulting in what the pcm perceives as the crank slowing down/misfire.
Old 01-26-2012, 02:11 AM   #6232
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
so in other words the sensor is buried under the timing cover?
Old 01-26-2012, 09:43 AM   #6233
.kyle
Member#: 174695
1983 antarctic blue
super sportswagon
It's accessible from the outside. You an see it mounted to its' boss if you peak down there. 1/4 drive ratchet and a shallow 10mm to take it out.
Old 01-26-2012, 01:52 PM   #6234
Ethereal Drain
Member#: 292456
Anybody know of a good place to try out some snow tires? Old parking lots etc, somewhere I'm not likely to get a ticket for driving through? I dont wanna do anything stupid or dangerous, just curious to see how good the subie is with the new setup
Ethereal Drain is offline   Reply With Quote
Old 01-26-2012, 02:28 PM   #6235
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
Just a little "testing and comparing", right?
rmj is offline   Reply With Quote
Old 01-26-2012, 02:32 PM   #6236
Ethereal Drain
Member#: 292456
Something like that
I'm coming from two snowstorms with 17" aging summer tires, to 16" wheels with blizzaks. So now I'm curious to see how good these cars really are.
Old 01-26-2012, 05:58 PM   #6237
Suba Blu
Member#: 131989
2012 WRX Sedan
Plasma Blue Pearl Limited
If you are on Facebook you should join the Madison Subaru group as Shannon over at Don Miller East can tell you where to go play w/o issues.
Suba Blu is offline   Reply With Quote
Old 01-26-2012, 06:57 PM   #6238
SgtRauksauff
Member#: 29920
1998 OBS
Green! No Black! AAAAAAH!
Lake Dubay, Up by Stevens Point, this coming Sunday morning......
Event #4 of the CWSCC 2012 Ice-Rally Series.
Schedule:
Registration - 9am - 10am
Practice - 9am - 10:30am
Drivers meeting - 10:45am
First car out - 11:00am
Where:
Lake DuBay. Boat landing at the corner of County Road DB and County Road C in Knowlton, WI.
Trophies awarded at the end of each event.
Cost:
$20 for CWSCC Members / $30 for Non-Members
($20 to become a 2012 CWSCC Member)
Ice-Rally Classes:
AWD - All-Season Tires
AWD - Snow Tires
AWD - Studded Tires
FWD - All-Season Tires
FWD - Snow Tires
FWD - Studded Tires
RWD - All-Season Tires
RWD - Snow Tires
RWD - Studded Tires
Come have some fun! Get out of the house!
There's apparently a contingent of Chicago guys coming up this weekend, you can't let IL guys make you look bad!
--sarge
SgtRauksauff is offline   Reply With Quote
Old 01-27-2012, 12:31 AM   #6239
Ethereal Drain
Member#: 292456
I'm already on there, I'll ask him
Schedule:
Where:
--sarge
I've been wanting to try this stuff out, but I work every night starting at 4pm in the Madison/Fitchburg/Middleton/Sun Prairie area. I usually dont have time to attend events + make it to work on time
Old 01-27-2012, 03:51 PM   #6240
0225wrx
Member#: 142701
2002 bugeye/ 79 Brat
WRX=386hp/ Brat=alot less
Hi all, it is Nicole. I just wanted to invite anyone that knew Matt to his memorial get together tonight, from 6 to 10, at Hemingways in fitchburg. I am hoping to see a bunch of our subaru friend there as there is a lot of parking!
0225wrx is offline   Reply With Quote
Old 01-28-2012, 12:23 AM   #6241
BUGEYEDBADGER
Member#: 138611
Sedona Red
I totally brain farted and forgot about tonight. Very sorry that Katie and I weren't there.
BUGEYEDBADGER is offline   Reply With Quote
Old 01-28-2012, 02:42 PM   #6242
rmj
Member#: 276611
2011 STi 5-Door
Plasma Blue Pearl
I'm in Madison for the weekend - hopefully I'll see some other Subys out and about!
Old 02-05-2012, 07:07 PM   #6243
.kyle
Member#: 174695
1983 antarctic blue
super sportswagon
meet pending...will post details when finalized.
Old 02-06-2012, 09:07 PM   #6244
.kyle
Member#: 174695
1983 antarctic blue
super sportswagon
saturday the 18th 6pm.
ten pin alley in fitchburg.
boom, meet has been made.
Old 02-07-2012, 07:05 PM   #6245
poetic--playa
Member#: 175499
07 TL Type S 6spd
Kinetic Blue Pearl
Hi everyone, I just wanted to drop by and share my excitement of being an owner of a 92 Miata. It's so slow, almost unbearably slow, but I'll stick with it. I won't be driving it daily until summer comes around.
Kyle, had I seen that Forester you have for sale earlier, I'd probably be driving that instead.
poetic--playa is offline   Reply With Quote
Old 02-07-2012, 10:14 PM   #6246
.kyle
Member#: 174695
1983 antarctic blue
super sportswagon
yeah, that sold with the quickness. second person to look at it bought it.
Old 02-09-2012, 01:22 AM   #6247
poetic--playa
Member#: 175499
07 TL Type S 6spd
Kinetic Blue Pearl
If anyone is looking for a nice little laptop:
I'll do $300
http://madison.craigslist.org/sys/2842229813.html
Old 02-14-2012, 12:31 PM   #6248
Suba Blu
Member#: 131989
2012 WRX Sedan
My car will need a new owner in April
Old 02-16-2012, 11:53 PM   #6249
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
didnt think my rex was more tempermental than my lancer was in blowing off licp's.....plus it also didnt help that the t-bolt clamp busted causing it to blow...plus i have to send my pipes and ic up to brad in the sauk shop for him to clean the oily milkshake from the ic and pipes
Old 02-17-2012, 07:57 PM   #6250
simbat
Member#: 278576
08 FXT Sports
Infiniti M56X
Is there going to be a a meet on Saturday.Can I join ? I never have been on one of these meetings,but would love to meet some Subaru enthusiasts in Madison
simbat is offline   Reply With Quote
what is the song from the movie Billy Madison.... gc822 Off-Topic 8 02-18-2006 01:22 AM
New Rule: All threads that contain the phrase "this girl" in the topic... dr_wheel Off-Topic 14 10-07-2004 12:18 AM
Do The Best New Threads Make The Best Used Threads? MightyWRX02 Off-Topic 6 08-20-2003 05:23 PM
The New And Improved! Who's the biggest music geek? Thread! WagonMonster Off-Topic 54 07-03-2003 09:41 PM
