Old 09-16-2009, 02:26 PM   #1
DeathKing
Member#: 202277
2002 WRX Wagon
AW
Default 2002 WRX Stage 1 Open Source Map
Hi,
Is there a Stage 1 Open Source Map for a 2002 WRX MT?
Thanks
DeathKing
DeathKing is offline   Reply With Quote
Old 09-16-2009, 02:49 PM   #2
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
bluescoobywagon is offline   Reply With Quote
Old 09-16-2009, 03:46 PM   #3
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Open your current flash and turn up the boost a little. Log for fuel and timing to be sure its ok, which it should be. Bam stage 1.
TurboSetch is offline   Reply With Quote
Old 09-16-2009, 07:49 PM   #4
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
Default old man comment
Also, what do you define as stage 1?
When I ran COBB's Stage one I had:
UpPipe
UD pulleys
samco Y pipe
GP moto inlet
and a Helper spring
And way back in the day Vaus showed us all how to adjust wastegate preload on a TDO4.
Anyway, I would just do a log before as well to make sure you are not seeing any FLKC or FBKC as is.
R.
BlackEyeII is offline   Reply With Quote
Old 09-17-2009, 10:08 AM   #5
bluescoobywagon
Member#: 14911
Not A Wagon!
Most people consider the minumum requirements for a Stage2 flash to be a catless uppipe and a downpipe. A good cat back is needed to see the full benefits, though. That being the case, without those parts, you're stage 1.
Old 09-18-2009, 02:08 PM   #6
DeathKing
Member#: 202277
2002 WRX Wagon
AW
I consider Stage 1 an updated map for a stock vehicle.
Stage 2 is when you start throwing parts at it with at least a more free flowing downpipe.
Old 09-18-2009, 02:56 PM   #7
bluescoobywagon
Member#: 14911
Not A Wagon!
Most people think that just the downpipe is needed for stage 2, but I'll never flash a stage 2 map to a car that still has a cat in the uppipe as a safety thing.
Old 07-14-2011, 01:13 PM   #8
UnknownAlly
Member#: 277330
2004 WRX
To answer your question, I've searched and searched and they only provide a Stage 2 map so far for 02-07 WRX's (from XPT)
UnknownAlly is offline   Reply With Quote
Old 07-14-2011, 03:58 PM   #9
robtmc
Member#: 23659
Chapter/Region: HIIC
2002 WRX Sport Wagon
Platinum Silver
Assuming you are talking about free maps, here you go:
http://www.osecuroms.org/viewtopic.p...b34b4cf2f3d7d2
I played around with this map, and regardless of the "91 octane" claim, it was a detonation nightmare even with 92 octane. It truly knocks everywhere. Lots of low rpm, part throttle boost, so it feels very punchy. Then you log and see the IAM and knock correction values and get very nervous about hitting the gas.
I'd give Jaxscuby or one of the other tuners here a shot unless you are really up for tweaking this map on your own. It is NOT good to go.
robtmc is offline   Reply With Quote
Old 07-14-2011, 09:56 PM   #10
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
u could try the above map and pull a degree out of the adv timing map. being in HI robtmc it could be that ur intake temps r alot higher than where the map originally was made.
WhiteBgeye02 is offline   Reply With Quote
Old 07-18-2011, 11:12 AM   #11
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
UpPipe
UD pulleys
samco Y pipe
GP moto inlet
and a Helper spring
R.
Are you referring to adjusting the wg arm? This is a nono... Adjusting wg preload is not how you tune boost.
D0nets is offline   Reply With Quote
Old 07-18-2011, 04:53 PM   #12
robtmc
Member#: 23659
Platinum Silver
Hawaii temps where I live are usually no more than mid-80's. SoCal has hotter temps in the summer than here.
It will take more than a degree to tame this map. This is a pic of the spreadsheet I used to compare the original map timing and where I was at the time trying to get rid of knock. This is not a minor tweak. I gave up on the thing. The red is degrees pulled from the original, and this is on a higher octane than supposedly developed for:
Old 07-18-2011, 07:41 PM   #13
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
wow, yeah that should not be on the website to download if its that far off.
Old 07-18-2011, 08:12 PM   #14
robtmc
Member#: 23659
Platinum Silver
FWIW, that was with a gutted up-pipe, silicon intercooler hoses, all else stock.
07' 2.5i Open-Source Maps available here! deviantek Normally Aspirated Powertrain 146 02-09-2009 06:01 AM
FS: 2002 wrx stage 1 exedy clutch/exedy flywheel 2.5rsTurbo Drivetrain 27 06-16-2008 05:02 PM
Open Source map to AP map? shew Open Source Reflashes 2 04-27-2008 12:41 AM
07' 2.5i Open-Source Maps available here! deviantek Engine Management & Tuning 2 03-07-2008 03:10 PM
2002 WRX Stage 1 Q USF97J4x4 AccessPort 9 05-03-2006 10:46 PM
