Old 09-16-2009, 08:05 PM   #1
mlangejan
Member#: 205567
2000 Impreza rs
blue ridge pearl
Talking bc valve springs?
does anyone now if the bc valve springs from a wrx will work with sohc heads from an 2.5 rs as well as the retainers
mlangejan is offline   Reply With Quote
Old 09-16-2009, 08:42 PM   #2
subiidude
Member#: 141472
2008 shagg wgn STI
OG FP20g+e85 corn booze
the springs will not work, you need ones for your heads. don't know about the retainers...
subiidude is offline   Reply With Quote
Old 09-17-2009, 11:38 AM   #3
mlangejan
Member#: 205567
2000 Impreza rs
blue ridge pearl
are there any other springs availible for the rs other than techworks that you know of
Old 09-18-2009, 11:11 AM   #4
VIsubi
Member#: 187834
06 2.5i impreza
Red
rallitek has some springs for a good price check out rallitek.com and see if you like...
VIsubi is offline   Reply With Quote
Old 09-18-2009, 07:51 PM   #5
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i have the rallitek springs in my car, and so far they haven't had a single issue
olsen726 is offline   Reply With Quote
Old 09-28-2009, 07:12 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
What you might want to do is note the specs of the stock springs from the FSM, then pour over aftermarket spring makers to find something cross compatable.
Old 09-28-2009, 11:18 PM   #7
DSM_Outback
Member#: 56345
93 Swapped L
Green
No, they are way too short.
Ferrea lists some valves and springs in their catalog for EJ25D DOHC, I have purchased a set of these and their catalog and phone techs are mistaken, they were for SOHC EJ251 not the DOHC they listed.
DSM_Outback is offline   Reply With Quote
FS: Spearco IC, BC valves Subynoob763 Engine/Power/Exhaust 13 11-03-2009 03:43 AM
FS-Cosworth Hi/Capacity Oil Pan Kit, Cos. Rod/Main Bearings, BC Valves/Spring/Ret blackacres Engine/Power/Exhaust 22 02-14-2009 03:16 AM
JDMSpec-C 12L Water Tanks$250-BC Cams Free Valve Springs-ATP GT28/30/35 Now Available Gruppe-S Engine/Power/Exhaust 23 12-08-2008 08:17 PM
FS 04 STI long block,sti injectors,BC valve springs takeshi999 Engine/Power/Exhaust 0 05-31-2008 12:38 AM
Fs gsc 266 cams and BC valve springs monstersti Engine/Power/Exhaust 1 02-19-2008 05:30 PM
Message Board Statistics All times are GMT -4. The time now is 06:39 AM.
