Old 09-16-2009, 10:15 PM   #1
turbo01gc8
Member#: 217973
2001 turbo impreza L
acadia green
Default boost issues
is anyone familiar with a garrett T25 turbo? installed this kit 3 months ago with a pretty worn clutch and was making like 3psi and some cooler days was making like 4psi then it slipped badly. just replaced the clutch with a ceramic 4 puck disc and stock pressure plate. it seems like it will hold the power but i can't make over 2psi now??? i heard that there is a way to clock the compressor housing to adjust the internal wastegate but not sure if this is what i need to do. i also have a programmer that only controls 2 extra fuel injectors across the psi and rpm range. can anyone give me some advice??
turbo01gc8 is offline   Reply With Quote
Old 09-17-2009, 12:10 AM   #2
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
check for boost leak or bad actuator. you really cant clock the compressor housing for much other than where you need the outlet to be.
pressure plates are what gives you the holding force, not so much the disk.
legacydreamz is offline   Reply With Quote
Old 09-17-2009, 09:37 AM   #3
Odyknuck
Member#: 192866
2006 Impreza
Make sure your turbine is spinning freely and you are getting plenty of oil to it. The actuator is usally factory set for 7 to 8 psi.
Odyknuck is offline   Reply With Quote
Old 09-17-2009, 11:44 AM   #4
mlangejan
Member#: 205567
2000 Impreza rs
blue ridge pearl
sounds like a boost leak or there is something going on with your actuater get a air regulater and hook it up to the actuater and see when it is opening it should start to move around 6 psi if its opening with 1 or 2 psi thats your problem what type of ic are you running
mlangejan is offline   Reply With Quote
Old 09-17-2009, 08:35 PM   #5
turbo01gc8
Member#: 217973
acadia green
the intercooler is a pretty decent size. it came with the kit from Turbo Specialties and it's front mount. i just replaced the vacuum line from the compressor housing to the actuator with a rubber vacuum hose and small hose clamps and now it peaked at 4psi @ 5800rpm one time on the way home from work. it was feeling loose and it was that clear plastic junk with zip ties holding it on. the impeller spins freely and gets plenty of oil. about 80psi under load because i installed a pressure sender right at the feed line so i know at all times. i also fixed a slight exhaust leak at the manifold to the heads. still not happy with the boost i'm making how do i check the actuator?
Old 09-19-2009, 12:00 AM   #6
turbo01gc8
Member#: 217973
acadia green
checked the wastegate actuator today and found it was holding pressure. guess the next step is to triple check for charge pipe leaks at every coupler, then to shortening to actuator rod b/c it's not adjustable
Old 09-22-2009, 01:06 AM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
how did you check it?
Old 10-24-2009, 10:36 PM   #8
turbo01gc8
Member#: 217973
acadia green
with a vacuum guage and it pushed all the way open and held open. then i made the WG adjustment to almost a 1/2" shorter. now can make 7psi and peaked twice @9psi in 5th gear
idle issues and boost issues jdgrimm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-05-2006 09:45 PM
Boost issues or Gauge Issues? IwantONE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-12-2006 05:18 PM
Will Auxiliary Boost Controller fix Cobb AccessECU/AccessPort low boost issues? ImportVenom Engine Management & Tuning 2 06-23-2004 12:22 AM
Boost issues with the AVCR... Need help. AZScoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-02-2002 03:58 PM
VF23 Boost issues lbk16 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-23-2002 01:58 PM
