Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 09-17-2009, 02:58 AM   #1
Amnizu
Member#: 178854
2008 WRX, '11 BMW 1M
Red, AW
Default 2008 WRX 337HP / 344 TQ TD06 20g, Avo TMIC, 50/50 Meth, 92 Pump
Went down to Surgeline today, Tim Bailey tuned, as you can see there are multiple maps below, best numbers were 337 HP 344 TQ @ 21 PSI.
Boost is tapering pretty heavily at 5000 RPM due to the TMIC, I may switch it out for a FMIC we will have to see if I can tolerate loosing my bumper support.
Big thanks to Tim for fighting through a couple bumps in the road and to Kelly @ Speedware for building out the car.
Relevent Mods:
Deadbolt TD06 20g 7CM
Avo '08 WRX TMIC
DW 850 CC top fed injectors
Devils own stage 2 progressive Meth kit with DO7 spraying nozel.
Invidia catless Turbo back 3"
Cobb Sub-003 AP, Tim Bailey tuned
Walbro 255 fuel pump
Grimmspeed 3 port EBC
Iridium 1 step colder plugs
Ultimate racing CAI
Other mods:
Cusco Zero 2e coilovers
BBS RE 18x8 W/ toyo proxy t1r (summer)
Oz Ultraleggera 17x8 W/ dunlop wintersport 3ds (winter)
'06 STi front brembos w/ stoptech rotors, lines and pads
Raillitek front 22mm, Rear 19 MM sways w/ endlinks
Cobb short shifter and bushings
Momo shift knob
20% tint all around
Amnizu is offline   Reply With Quote
Old 09-17-2009, 03:37 AM   #2
slo-psm-sti05
Member#: 223954
05 1 slow sti
psm
wow thats awesome!!!
slo-psm-sti05 is offline   Reply With Quote
Old 09-17-2009, 03:47 AM   #3
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
nice numbers. post some pics of the engine bay if you can.
ramair18954 is offline   Reply With Quote
Old 09-17-2009, 08:55 AM   #4
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
Default nice numbers..
Nice:
You will have more room with a FMIC Jarrad tuned my TDO6h 20G 7cm internal with an ebay FMIC and it made 335hp and 365tq at 22psi tapering to about 19.5 at rl no meth.
Then again , do you really need it? I have often thought a TMIC with meth is a better route.
I guess that is up to you.
I forgot to mention that why I posted this was it was on the same dyno...
BlackEyeII is offline   Reply With Quote
Old 09-17-2009, 09:29 AM   #5
penusai
Member#: 102808
1995 Built EJ207 6sp
30r ***in progress***
Nice numbers.
You could also look into another EBCS/MBC and EWG, to better control/hold boost up top.
penusai is offline   Reply With Quote
Old 09-17-2009, 10:11 AM   #6
sutter2k
Member#: 92467
08 STI
I am pretty sure the perrin tmic flows more than the avo. If there are problems with cooling you could always throw a smaller nozzle pre intercooler.
Also, what is the meth kit diven by. Boost? injector duty cycle? maf?
sutter2k is offline   Reply With Quote
Old 09-17-2009, 10:19 AM   #7
UM-WRXer
Member#: 44623
wow,according to your mod list it sounds like a sick car....any pics?
UM-WRXer is offline   Reply With Quote
Old 09-17-2009, 10:52 AM   #8
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
nice power!
stock trans? looks like you have sti brakes so i assume not....?
boostdog is offline   Reply With Quote
Old 09-17-2009, 11:04 AM   #9
Amnizu
Member#: 178854
Red, AW
Originally Posted by BlackEyeII View Post
Nice:
Yeah, Tim said pretty much the same thing. It is a daily driver so I probably dont need it, but now that the seed is planted in my head I'll probably end up doing it...
Good suggestion, I'll look into it.
Yeah, the Avo is clearly the weakest link here. The meth kit can be driven off the boost line or the MAP. Mine is setup off boost.
Originally Posted by UM-WRXer View Post
wow, according to your mod list it sounds like a sick car....any pics?
They are comin, I will post in the detail section once I get the car cleaned up, it of course rained last night..
Stock tranny, just bolted on STi front brakes calipers with 5x100 rotors to help control the power.
Thanks everyone for the complements and suggestions. Keep them comin!
Old 09-17-2009, 12:17 PM   #10
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Now you just need the Cobb lightweight crank pulley, that's where my power came from.
Tim is a very good tuner and does tunes that are conservative, reliable, safe, and strong. I couldn't let anyone else tune my car. Enjoy your car.
UFOpilot is offline   Reply With Quote
Old 09-17-2009, 01:50 PM   #11
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Nice man - 20G's rock
Kastley85891 is offline   Reply With Quote
Old 09-17-2009, 04:03 PM   #12
UM-WRXer
Member#: 44623
so how did you mate an avo TM with a 20g? the 20g compressor outlet doesnt have a flange to mate to the AVO TM does it?
Old 09-17-2009, 04:12 PM   #13
papafrito
Member#: 181280
2008 WRX-Prn STG 2.5
Dark Gray Metallic
Jealous.... Nicely done!
papafrito is offline   Reply With Quote
Old 09-17-2009, 05:36 PM   #14
mls1
Member#: 167607
2008 WRX
I would also like to know this.
mls1 is offline   Reply With Quote
Old 09-17-2009, 05:57 PM   #15
Amnizu
Member#: 178854
Red, AW
Deadbolt makes a legacy / 3g WRX fit 20 gram turbo. Link below:
http://www.boostplanet.com/05_legacy_gt.htm
TMIC fits in stock location, just have to remove the plastic wire retention clip from behind the plastic TB. The turbo comes with 3 new bolt posts that you screw in and bolt up. Both are nicely designed and require little to no major manipulation.
I believe others make similar turbos. I went with the deadbolt because I got a pretty good deal on it from a fellow NASIOC user.
So to answer the question, I used a turbo designed to mate with the 3g WRX / Legacy GT intercooler flange and a intercooler designed to mate with the stock turbo compressor outlet flange.
Old 09-17-2009, 06:00 PM   #16
SEEK
Member#: 143040
2008 WRX
SWP with some gold
wow.. i really need to start piecing my parts now lol. very nice numbers.
SEEK is offline   Reply With Quote
Old 09-17-2009, 06:07 PM   #17
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
The AVO Tmic flow 60lb/min... Thats alot of air Gt30r only flows 52lb/min I dont think the perrin flow more than that....
TDagen is offline   Reply With Quote
Old 09-17-2009, 06:08 PM   #18
Amnizu
Member#: 178854
Red, AW
Turst me you will love it, thing pulls like a SOB in 3rd. Its stupid. And I got 35 MPG crusing back home from Portland to Seattle because the larger turbo is out of play below 3000 RPM.
Old 09-17-2009, 08:29 PM   #19
htowns_finest
Member#: 193645
09 WRX WFC# 2009
SPERM WHITE PEARL
man for that much you can just get a used 20g and front mount
but good stuff thats what im trying to get right now a 20g with a fmic on my 09
nice job
htowns_finest is offline   Reply With Quote
Old 09-17-2009, 09:18 PM   #20
BlackEyeII
Member#: 65140
Default no clutch...
I sense a very smelly clutch in your near future...
< and the swami fades out >
Old 09-17-2009, 09:19 PM   #21
sutter2k
Member#: 92467
08 STI
^^ In STI fitment perhaps. Not the legacy version.
Old 09-17-2009, 09:24 PM   #22
sutter2k
Member#: 92467
08 STI
In your setup, that may be less than ideal. Even though boost is tapering, maf is not. You could benefit from more flow in the upper rpms even though boost is tapering.
Old 09-17-2009, 09:24 PM   #23
sutter2k
Member#: 92467
08 STI
Old 09-17-2009, 10:01 PM   #24
SEEK
Member#: 143040
2008 WRX
SWP with some gold
my first choice turbo was the 20g but then i saw the hta68 and was like whoa nice. man.. decisions decisions..
Old 09-17-2009, 11:26 PM   #25
Amnizu
Member#: 178854
Red, AW
Hummmm, can you explain a little more?
The Meth kit comes on at 50% at about 9.5 boost PSI and is progressivly stronger untill full pressure at about 15 PSI and stays on full untill boost falls below 15 PSI, so untill I lift or engage the clutch. So in a WOT pull meth would be fully engaged at about 3800 RPM and held constant untill redline.
DB Td06 20g, Aps Tmic jester696 Engine/Power/Exhaust 10 05-26-2009 03:03 AM
New tune EJ205 TD06-20G + meth JonR Proven Power Bragging 53 10-17-2008 02:26 AM
05 STi: 344 WHP on Dyno Dynamics with a 20G and TMIC DroppedClutch Proven Power Bragging 11 04-05-2006 02:45 AM
EJ205 + DB TD05H-20G + 50/50 Meth/water Injection.... testes1010 Proven Power Bragging 39 03-06-2006 01:58 AM
SB 20g dyno plots on 93 pump and 50/50 alchy mpower22 Proven Power Bragging 32 10-28-2005 12:17 PM
