Alaskan Impreza Club
Old 11-17-2011, 03:51 PM   #426
7fc
Member#: 242078
2004 WRX
Took a few more shots and got some of the highs...
7fc is offline   Reply With Quote
Old 11-17-2011, 04:13 PM   #427
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
Originally Posted by inkpreza View Post
New goggles for the stomper
Dawg!
nice retina burners there!
Nomadgene is offline   Reply With Quote
Old 11-18-2011, 02:27 AM   #428
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
I should post some pics of my quad 05s. They're crazy bright.
cosseywrx is offline   Reply With Quote
Old 11-18-2011, 03:21 AM   #429
fishAK
Member#: 177680
'03 GMC Denali
White light w/flicker
I've been trying to get a fog retro done in my Denali for a while. I'm using these little tiny P1 Universal projectors that you can get off of ebay for about $50.00. They actually have a decent output, especially considering their small size. The problem with most retro's is not enough room for the projector. These are so small, I had too much room, and thus a lot of extra, unused "gap" space that just looked silly.
I am using an aftermarket Denali fog light housing. The little projector comes with a mounting bracket, but in this case it fits exactly into the existing bracket on this housing. Mounting was no issue, but as you can see there is all this space between the projector and the housing that just doesn't look right.
So, my quest to fill the space began.
Sonny let me have a couple shrouds he had lying around to try them. They almost fit, but were just too big enough not to work.
Off to Lowe's I went, bored son in tow, to wander the aisles. I came upon these 3"x2" rubber couplers that are even shaped like a headlight housing, and kinda went "hmmmmmm." $15 later, I was out the door and back home to check this out. The projector fits like it's made to go in one of these, and better yet, the 3" end fit perfectly around the edge of my housing! Aha!
I had to cut a couple of notches out of the rubber to access the adjustment screws, and used some JB Weld to attach the coupling semi-permanently to the housing. I can buy a 2" cap or plug to seal the end up, I just have to cut another little notch for the wires. And here's one of the finished lights:
I think it looks a thousand times better than leaving that gap space open, and it's pretty functional to keep the inside clean and dry. Obviously I still need to mount to the truck and attach the HID's, but I may wait for the weather to cut me a break before doing that.
These projectors plus the couplers would be an easy mod for anyone wanting that extra light.
Thanks for the ideas, Sonny!
fishAK is offline   Reply With Quote
Old 11-18-2011, 10:50 AM   #430
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
I can't wait to see these on the truck-great job! I love how you can see the opening for the bulb in the last photo. Post up more pics as you make progress, please!
Old 11-18-2011, 10:51 AM   #431
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
You should. I've never seen them lit up.
Old 11-18-2011, 01:33 PM   #432
fishAK
Member#: 177680
'03 GMC Denali
Here's the finished product. Or as finished as it can get without being installed:
From the right angle, you can see a bit of a gap around the projector. Once I cap off the end, though, that will be basically unnoticeable. I discovered it's very hard to get two projectors centered in the same photo...lol. One is slightly crooked, though. Not sure why and there is little room for adjustment in that direction, so I'm going to be throwing to one side a bit with one of them, which really isn't a bad thing in this case as long as I get full lane coverage from both of them.
JB Welded the coupling to the housing and that was it. Hopefully they stay put. Once I got this figured out, I did the second light in about 30 minutes.
Better shot of one of them:
Old 11-21-2011, 10:43 AM   #433
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
After seeing the finished pics I really want to see some output shots when you have them adjusted! Must be nice to run your fogs without all that spill and blinding oncoming cars. Great job!
Old 11-21-2011, 12:32 PM   #434
fishAK
Member#: 177680
'03 GMC Denali
Meh.
Came out ok. Honestly expected more light, but oh well. Looks pretty good, though.
Old 11-21-2011, 03:12 PM   #435
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Marlon Approved. Do mines?
Marlons101 is offline   Reply With Quote
Old 11-22-2011, 02:24 AM   #436
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Are you talkin' to Fish, or me
Old 11-22-2011, 02:41 AM   #437
cosseywrx
Member#: 276443
heres some shots of my 05 quads that whats his face did.
enjoy!!
lows
highs
Old 11-22-2011, 02:49 AM   #438
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Thats alot of light! In the last pic it looks like two diferrent color-temperature capsules are being used?
Old 11-22-2011, 03:02 AM   #439
cosseywrx
Member#: 276443
dont know what temp capsules are but lows are 4.3k and highs or 5k. gonna make them both 5k prollys
Old 11-22-2011, 03:16 AM   #440
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Originally Posted by aleutdude View Post
One is done! A comparision to stock:
Lit with ambient light:
Lit without ambient light:
Originally Posted by 7fc View Post
First of all, thanks Sonny for the retro work done on my headlights..i really like how they turned out and especially the lighting..
Due to the weather we have here in kodiak, i was only able to get some pics from inside the garage aiming at the door...ill get some outside pics as soon as it calms down and when its dark...i actually just got done installing them so i might need to do some more adjustments..and i did forget to take pics with the highbeams on..
gotta show off what were working with first
without light..
will post some more when i get a chance to take some more pics outside..
enjoy!!
lows
highs
This is making want to buy the kit tonight
subaru_steve is offline   Reply With Quote
Old 11-22-2011, 10:45 AM   #441
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
You're welcome. Its an addiction. If you have any questions, feel free to post them in this thread or PM me.
Old 11-22-2011, 11:49 AM   #442
coldfiremx
Member#: 285848
Have you done any climate control lighing modifications on a 06STi? I want to make them red. I also want my clock red.
coldfiremx is offline   Reply With Quote
Old 11-22-2011, 12:21 PM   #443
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
I haven't but it has been done. I'm not sure about the clock, though. Theres lots of good info in these threads:
http://forums.nasioc.com/forums/showthread.php?t=690922
Looks like a fun project, if a bit tedious.
Old 11-22-2011, 12:42 PM   #444
coldfiremx
Member#: 285848
Im doing it.
Old 11-22-2011, 12:56 PM   #445
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Sweet! Post pics, please!
Old 11-22-2011, 02:02 PM   #446
anthonyss
Member#: 246879
1999 audi
blue
I'm doing a retro fit on my mustang, and two of my buddy's wrx excited!
anthonyss is offline   Reply With Quote
Old 11-22-2011, 04:50 PM   #447
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Who did the lights? They look nice. My Lego needs lights. Por favor*
Old 11-22-2011, 07:46 PM   #448
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Ah, you must be talking about the foglights on FishAk's Tahoe. He did those himself.
Old 11-22-2011, 08:32 PM   #449
907scoobyrex07
Member#: 296069
05 Sti
Obp
Im gunna try it out when i get home
907scoobyrex07 is offline   Reply With Quote
Old 11-22-2011, 09:13 PM   #450
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
Sonny, did you get your vacuum table lens forming stuff set up yet? I thought I remembered you were talking about that a while ago. Maybe I'm mistaken. But if you did, I might have a commissioned project for you if you've got the time.
Edit: or at the very least, bounce some idea off of you.
Dominator is offline   Reply With Quote
Interior aftermarket light dimming... MK19 Electrical & Lighting 1 06-30-2003 01:35 AM
Aftermarket Lighting options SLKWrx Electrical & Lighting 2 02-12-2003 11:17 PM
GC8 Aftermarket light problems? sir_aspen_white Electrical & Lighting 5 02-12-2003 02:11 AM
Aftermarket lights for BE/BH cardin555 Legacy Forum 6 11-12-2002 01:19 PM
Aftermarket lights remarcable Interior & Exterior Modification 7 04-13-2001 07:23 PM
