Alaskan Impreza Club
Old 02-07-2012, 12:57 AM   #476
fishAK
Member#: 177680
'03 GMC Denali
White light w/flicker
Wow...I don't know if you're going to have enough light there, Sonny.
Looks good. I also took advantage of the warmer weather to trace my Hella's problem. I think it was a wet ground. All the other connections looked good. Cleaned it up a bit and re-did the ground and it's working so far.
Put those 5Five's in the Denali...lots of light!
fishAK is offline   Reply With Quote
Old 02-07-2012, 01:11 AM   #477
907scoobyrex07
Member#: 296069
05 Sti
Obp
Originally Posted by aleutdude
I finally got them installed!
I took advantage of the warmer weather and got the other Hella projector installed:
I hope to take some output pics soon!
Your car makes me want a bug eye soooooo bad! Good work lights and car look excellent! Two thumbs up
907scoobyrex07 is offline   Reply With Quote
Old 02-07-2012, 02:02 AM   #478
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Glad to hear those 50 watters are working for you and I'm glad you traced the wierdness with the Hellas!
Thank you! Mine started as a Hawkeye so if you ever want to join the Bugeye Mafia, let me know!
Old 02-29-2012, 01:24 AM   #479
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
im not the only one!! idk if i ever was? but i know in alaska i am!! lol
http://i1205.photobucket.com/albums/...-23-11_HDR.jpg
cosseywrx is offline   Reply With Quote
Old 02-29-2012, 01:47 AM   #480
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Not the best output pics but I finally took a couple. The projectors are the Hella EVOX-Rs from Theretrofitsource.com. They are a version of the Hella E55 with polished chrome bowls and clear lenses. I am using no-name 35 watt ballasts and Morimoto D2S capules(bulbs) in 4300k. The Hella Black Magics are wired to the factory highbeam outputs and are using 55 watt bulbs(halogen).
Lows:
Highs:
Old 02-29-2012, 01:58 AM   #481
cosseywrx
Member#: 276443
i have thought of goining to halogens for the brights as hids brights aren't really there when needed
Old 02-29-2012, 02:26 AM   #482
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Either Morimoto mini version(D2S or H1) don't do distance very well. The "hotspots" seen in the photos above are all the EVOX-R projectors as the Hellas are using 55 watt bulbs and really only provide some extra fill. I plan on running 100 watt bulbs in the Black Magics since they really deserve the extra photons and are waaay under-utilized with only 55 watts.
Old 02-29-2012, 02:40 AM   #483
cosseywrx
Member#: 276443
My minis do just fine. Better than stock id say
Old 02-29-2012, 03:03 AM   #484
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Retro using projectors designed for HID>halogen, every time agreed. Are you running high wattage ballasts for all 4 projectors on your setup?
Old 02-29-2012, 10:34 AM   #485
cosseywrx
Member#: 276443
55w ballasts
Old 02-29-2012, 11:34 AM   #486
JordyB
Member#: 20328
'05 Forester XT
'07 Legacy spec.B
I think it's time to retrofit the Fozzy, who's down???
JordyB is offline   Reply With Quote
Old 02-29-2012, 12:55 PM   #487
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
I can give you a hand, if you like. Shoot me a PM.
Old 02-29-2012, 01:50 PM   #488
AK_GT
Member#: 275567
2010 WRX
What about a bi-xenon setup for the stock location projectors, and retain the stock halogen highs? I know your quad retro'd but, maybe Sonny(sp?) can chime in on a bi-xenon setup. I have a set of e-46 bi-xenon's out of an M series that I need to get retro'd into my lights, maybe this summer.
AK_GT is offline   Reply With Quote
Old 02-29-2012, 03:09 PM   #489
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
A pair of Hella 500s running 100watt bulbs should be all the extra highbeam he needs if he retains his current setup. I'm interested in how those minis hold up since many on hidplanet say they don't do well above 35 watts. Of course, its very cold up there and winter is when they'd be used the most.
Old 03-10-2012, 03:20 PM   #490
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Default 2011 Forerunner
In progress:
Old 03-10-2012, 03:24 PM   #491
07_STi
Member#: 290953
'15 STi
ISM
In progress:
damn that's looking good man.
07_STi is offline   Reply With Quote
Old 03-10-2012, 03:52 PM   #492
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Thanks! These things are gigantic and a bear to get apart but I think the results are worth it. They are going on a black Forerunner and I'm sure the difference will be dramatic.
One is done:
Old 03-10-2012, 04:09 PM   #493
07_STi
Member#: 290953
'15 STi
ISM
One is done:
yeah it's a friend of mine haha can't wait to check it out in person when it's done.
Old 03-15-2012, 12:31 PM   #494
Trollden
Member#: 257870
2002 WRX Wagon
Default my first retrofit
Here some pics from my first retrofit that I just finished yesterday. All work was done by me except for sonny helped me with sealing the lenses/ schooled me on retrofit supplys SO A BIG THANKS TO SONNY!!! You rock dude.
Projectors are the fxr's from theretrofitsource with e55 shrouds, phillips 85122+ bulbs on 55w ballasts and led diode halo running lights.
I'll post better pics of cutoff / of highs later tonight once it gets dark.
I'm loving these things!
This last photo of cutoff is with my car parked on ground that isn't level. More pics of output to come.
Trollden is offline   Reply With Quote
Old 03-15-2012, 01:37 PM   #495
Quasimodo_ak
Member#: 310012
That looks sick man! Damn the more I see retro the more I want to try it myself. I guess I could start with my stocks as a side project. Only problem I I don't know where to start lol.
Quasimodo_ak is offline   Reply With Quote
Old 03-15-2012, 04:09 PM   #496
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Those turned out great! Good job on getting the rotation spot-on. Glad I could help.
Old 03-15-2012, 04:11 PM   #497
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
PM me if you have any questions. I'd be happy to point you in the right direction.
Old 03-15-2012, 08:11 PM   #498
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Originally Posted by aleutdude View Post
Like a fool I didn't have my camera with me when I installed crash907's E55s so I'm refreshing the thread so he can post the phone pix he shot. I'm also thinking of having another HID mini-meet. I'll post up with a date.
Did this ever wind up happening? I know my HIDs aren't aftermarket, but I wouldn't mind contributing a WRX Limited with STI HIDs into a pic.
Eventually I want to get 55w HIDs and different shrouds to get the output to be more crisp (cleaner cut-off). Plus I need to reseal my driver headlight anyway, so I figure while I'm in there I would like to mess with the orange reflector somehow. I think they're too orange to smoke them with spray-on tint, but I don't really want to just remove them like others have done, also. It just leaves this gaping hole in the headlight.
I also want to make my fog lights useful. One of the lenses is cracked and it's $100 to replace, so that'll have to wait for now. Once that's fixed I'd like to put a protective, clear vinyl over the fogs.
Otherwise there's a lot of good work going on in here! Thanks and keep it up!
Old 03-16-2012, 10:58 AM   #499
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
I'm going to get a time set when I get back from Maui. As for a cleaner cutoff, all you'd need to do is the clear lens upgrade. Making 55 watt ballasts work might be a challange since they would have to use adaptors to exit the headlights differently but anything's possible. You might want to look into better capsules(bulbs) before bumping to bigger ballasts. When I get back we can meet up & talk.
Old 03-17-2012, 03:28 PM   #500
Rookie J
Member#: 281747
2005 Legacy GT Wagon
Element Sponsored
Looks good. I want an led halo
Rookie J is offline   Reply With Quote
Interior aftermarket light dimming... MK19 Electrical & Lighting 1 06-30-2003 01:35 AM
Aftermarket Lighting options SLKWrx Electrical & Lighting 2 02-12-2003 11:17 PM
GC8 Aftermarket light problems? sir_aspen_white Electrical & Lighting 5 02-12-2003 02:11 AM
Aftermarket lights for BE/BH cardin555 Legacy Forum 6 11-12-2002 01:19 PM
Aftermarket lights remarcable Interior & Exterior Modification 7 04-13-2001 07:23 PM
