Alaskan Impreza Club
Old 02-10-2013, 03:24 PM   #601
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Let me know if you have any questions or need a hand.
Old 02-11-2013, 11:37 PM   #602
MOBBiN
Member#: 128441
2006 STi WRB
01 BRP RS, 01 Silver XJ
Lows and fogs:
Brights:
Lows and lightbar:
MOBBiN is offline   Reply With Quote
Old 02-12-2013, 01:32 AM   #603
nasiocjunkie
Member#: 80864
I'll have the tuna.
No crust.
Have any pics of just the lightbar? and is that a 10"?
nasiocjunkie is offline   Reply With Quote
Old 02-12-2013, 12:34 PM   #604
AK907TRE
Member#: 230886
02 wrx,in a coma
loaned a 2001 rs coupe
all finished... until i woke up this morning and saw some fog on the inside..
time to take em apart again..
any tips on sealant? i got a whole roll of it but didnt think that i needed any.
other than that, my god... theyre awesome. pictures soon; after theyre perfectly done.
AK907TRE is offline   Reply With Quote
Old 02-12-2013, 12:58 PM   #605
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Some fog is normal and usually clears up on its own. I always add some extra sealant when I reassemble just to be sure. How well are the lights sealed up in the rear?
Old 02-12-2013, 01:19 PM   #606
MOBBiN
Member#: 128441
2006 STi WRB
It's a 20" double row bar. There are picture on the previous page
Old 02-12-2013, 01:54 PM   #607
AK907TRE
Member#: 230886
02 wrx,in a coma
for the hid projectors, im confident that they are 99 percent sealed.. its hard to explain with a keyboard, but i went projector, bulb, rubber gasket, then end cap to screw on projector, then the (nice and snug) orange connection to the ballast, if that makes any sense to you. it all fit very snug without any movement whatsoever. i only had to do some very small trim work with the dremel to open up the hole enough for it all to fit in (thats what she said). the blinker and marker are still factory style, which seal 'good enough' as far as i know.
Im leery about my job putting the two halves of the coconut back together, however. maybe i didnt heat it enough, or press hard enough.
Old 02-12-2013, 05:05 PM   #608
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
If you go to the trouble of opening them up again more sealant is a good idea. I'd have to see them in person or look at pics to determine how well the backs are sealed. You can try heating and squishing more. Are they both foggy? Does the fog go away when they've been on for a while?
Old 02-12-2013, 07:03 PM   #609
AK907TRE
Member#: 230886
02 wrx,in a coma
so i went to lunch and after like ten minutes of those babies cookin all the fog dissapated..
i failed to mention this: last night after i finished everything i went and got a car wash...
thank you and i think i am okay now, ill let you know if i have any more problems.
If i fail to post pictures, they just look all blacked out with covers for markers and the stock amber covers for blinkers.
Old 02-14-2013, 07:10 PM   #610
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
After being backordered since October(!), my Morimoto matchbox projectors finally came in. They are bi xenon and hilariously small. I'll post pics as soon as I'm able.
Old 02-14-2013, 07:27 PM   #611
Dka67
Member#: 296721
11 5door
^Fogs?
Dka67 is offline   Reply With Quote
Old 02-14-2013, 09:03 PM   #612
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
They could be used as fogs but would need to go in a housing since they aren't self contained like the Blazers.
Old 09-09-2013, 10:40 AM   #613
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
I've replied to a couple PMs, and posted in one or two other threads so I felt it was time to bump this thread. I will be posting output pics of my current setup as well as pics of the matchbox minis-though I don't think TRS carries them anymore. I have a couple ideas in mind for them, though and when I get the time I'll start tinkering and post pics. The dark season is fast approaching and I'm always curious what everyone else is running.
Old 09-09-2013, 01:53 PM   #614
AKSubie
Member#: 6214
01.5 Audi S4
www.motorsportsalaska.com
Subscribing to this thread to track for later.
PFD season, I am thinking of picking up a 10" LED bar similar to Tribal's to install on the S4, for my jaunts out to the Glacier.
AKSubie is offline   Reply With Quote
Old 09-09-2013, 03:59 PM   #615
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
Carter is offline   Reply With Quote
Old 09-09-2013, 04:50 PM   #616
AK907TRE
Member#: 230886
02 wrx,in a coma
just finished the second retrofit on my bugeye. The first retro I used morimoto mini d2s projectors and 35w morimoto ballasts w/ 5k beams.
This project entailed morimoto FXR 3.0 projectors, 55w ballasts, completely new harness and 5k bulbs again.
Since i'm excited about the results, and i was reading this thread, i'll say my two cents on a 02/03 retrofit. Doing this project again, I'd definitely recommend the FXR projector.
It's bulky, it's harder to install, and you have to use plenty of messy kwik weld and steel stick, but the result is simply outstanding. Great Light output (55w is super bright), sharp cut off line (could be good or a bad thing), wide beam angle, and personally I like the construction of the FXRs, being they are almost fully encased and protected. The high beam flapper in the d2s mini's is rumoured to stick and not close when High beams are flipped off, and one of mine (passenger side) did just that.. frustrating. The FXR's are built with durability in mind; they installed with zero problems. I'd say the only downside is that they take more skill and meticulousness to install. I'll post with more updates once i've put some miles on the new setup.
Old 09-09-2013, 04:54 PM   #617
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Originally Posted by Carter View Post
If its worth doing, its worth over-doing!
Old 09-09-2013, 05:25 PM   #618
AK907TRE
Member#: 230886
02 wrx,in a coma
one of those puppies had 50,000,000 candle power. If Edison could only see us now..
Old 09-09-2013, 11:01 PM   #619
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
I'd want one just so I can say my light can "slew"
Old 10-11-2013, 12:23 AM   #620
MOBBiN
Member#: 128441
2006 STi WRB
Thanks again sonny for doing the harnesses for me.
Factory HID jdm lights:
For rhd:
Flash me if I blind you!
Old 10-11-2013, 02:17 AM   #621
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
My pleasure, but if I flash you it won't be when you're driving your "portable sun"!
Old 11-29-2013, 02:24 PM   #622
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
I'm thinking of getting a set of these to experiment with:
http://www.ebay.com/itm/like/261340516680?lpid=82
Interior aftermarket light dimming... MK19 Electrical & Lighting 1 06-30-2003 01:35 AM
Aftermarket Lighting options SLKWrx Electrical & Lighting 2 02-12-2003 11:17 PM
GC8 Aftermarket light problems? sir_aspen_white Electrical & Lighting 5 02-12-2003 02:11 AM
Aftermarket lights for BE/BH cardin555 Legacy Forum 6 11-12-2002 01:19 PM
Aftermarket lights remarcable Interior & Exterior Modification 7 04-13-2001 07:23 PM
