Old 09-17-2009, 10:35 PM   #1
SubarusRmyThing
Member#: 203031
2005 Baja Turbo
White/Silver
Default Heres a tricky situation for you. Lets see if anyone can figure this **** out.
So heres the scoop. I searched for EVER to find a nice baja turbo that was completely stock and unmolested by some ****ing idiot who didnt know what they were doing. nothing i hate worse than buying a used car and having to fix someone else problems. What a joke that tuned out to be on me. ha. ha. ha.....
So i bought a 2005 baja turbo 5spd. of course the nice factory 6 disk changer. i was pretty excited. had it for about 4 months and then pretty soon after hitting some bumps the sound would short out. Hit one bump, no sound, hit another sound might come back on, hit another, no sound again. get the drift? Stereo didnt shut off or anything, only the sound did.
i was like wtf... thats just great.
So figured since all 4 speakers were going out, and the deck wasnt shutting off, i figured it was just a short in the deck.
So i bought a brand new nice fancy, 7" indash touch screen, dvd, nav, bluetooth, ipod, tv, you know the works.
Pulled the old stereo out today and find Sub woofer wire spliced into the harness in like 4 spots... Im like .......
So out comes all the seats, door panels, carpet, dash, everything, took it ALL OUT. What i find is Kicker speakers in the doors (kinda cool right?) that are wired with sub woofer wire. Completely bypasses the car harness, just goes straight from teh speakers, and runs into the harness about 1" after the plug. And let me tell you, it was the worse splice job ive ever seen in my life. Im like great... so much for my unmolested car. i can see all the problems coming my way already.
Anyways so i plug my new deck in to see if everything works, didnt feel like doing any rewiring right now. Deck turns on, but no sound. Things are running about par... So i said **** this, i ripped out all that ****ty ass wiring, and hooked the speakers back up to the factory wiring, got rid of all the little blue splice clamps and had everything back how it should. Plug the deck back in... STill no sound. so first thought was maybe some how i got some negative and positive wires crossed. So i unhook everything except one speaker. I tried one speaker. no sound, switched the wires, no sound.
next thought was, well maybe he had problems with the car wiring, and thats why he did his own... So i skipped the car harness my self, and wired that speaker straight to my deck. No sound, switched the wires around, no sound. okay what gives right? Bad speaker? sure maybe. So i grab a set of speakers i had laying around, im 90% positive they work. Tried everything all over again. NO FREAKING SOUND!
I am completely 100% STUMPED.
Someone please shed some light on me lol. We all know how bad it sucks to not have tunes while driving.
SubarusRmyThing is offline   Reply With Quote
Old 09-17-2009, 11:13 PM   #2
NutBucket
Member#: 90804
'15 SJ, '05 GG
Dirty
Did you check the stock wiring to make sure it actually is intact? It could be broken somewhere behind/under the dash hence the PO running new wires to the doors.
NutBucket is offline   Reply With Quote
Old 09-17-2009, 11:38 PM   #3
SubarusRmyThing
Member#: 203031
2005 Baja Turbo
White/Silver
well the foot of it you can see looks good. but then it goes into the big wire loom of course. and you dont see it again untill it hits the doors..
from what i can tell it looks good.
Old 09-17-2009, 11:39 PM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
First of all, take a few shots and relax.
Second, what model and size are the speakers, and what spacers were used to mount them? My first suspicion is that you have a speaker terminal making contact with the metal of the door and shorting out. Kicker speaker terminals are in a retarded spot, and this is somewhat common in tight spaces such as your door panel.
Audiosavvy is offline   Reply With Quote
Old 09-17-2009, 11:43 PM   #5
NutBucket
Member#: 90804
'15 SJ, '05 GG
Dirty
Try to ring it out with a DMM. Even if it looks ok with that measurement there could still be some broken insulation causing intermittent shorts.
Sounds like someone tried to teach themselves wiring on your car.
Old 09-17-2009, 11:47 PM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Sounds like your new HU is toast to me.. If you wired a speaker directly to the HU harness and got no sound, either it's a setting somewhere or it's toast...
Old 09-17-2009, 11:48 PM   #7
NutBucket
Member#: 90804
'15 SJ, '05 GG
Dirty
Maybe he toasted it when he hooked it up to the existing f'd up wiring?
Old 09-17-2009, 11:49 PM   #8
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
That's what I'm thinking...
Old 09-17-2009, 11:55 PM   #9
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
I think modern HUs are a little hardier -- a shorted or open speaker line probably wouldn't blow the output stage. Maybe touching +12V to the wrong place would.
Did the HU appear to be working (other than no sound)? Does it have line outputs you could check to see that it's still being a radio or CD player?
+1 on checking the continuity on the speaker wires.
SVXdc is offline   Reply With Quote
Old 09-18-2009, 06:14 PM   #10
SubarusRmyThing
Member#: 203031
2005 Baja Turbo
White/Silver
Well first off, thank you EVERYONE for the responses. Between all of you i figured out the problem.
Audiosavvy - You were on the right track, if only i woulda stuck on your track. I had both from door panels off, and the front speakers were fine. Not even close to grounding out, so i was like naaa thats not the problem. Something eles...
So my next thought was to check the continuity since that seemed pretty obvious. I didnt know why i didnt do that in the first place. First door i tried, nothing. Second door, nothing, third, nothing.... So i figured okay.. something massively wrong under the dash in the wiring... And figured besides the fact this guy sucks ass at wiring... maybe he was kinda smart and thats why he had all brand new wires ran. So i said screw it, ill just do what he did, BUT, im clipping the plug from the car so its not attached at all, because it was obviously grounding its self out or something. Once i cut the plug from the car and wired it to the deck harness and into the front speakers, the fronts were working. So was like okay. heres the fun part, i get to rewire the entire stereo system now! yippie... not.
So i spent the day doing that. Got the interior stripped out, the front end all wired threw the looms and everything, took my time, did a professional job with everything. Tested the front, everything worked. Then was like okay... Time for the back.
and i figured well i really dont wanna pull the back panels off and the piller panels off and run new wires threw those, ill just use his wiring since that part wasnt the worst...
Ran the wiring, hooked it up. NO SOUND AGAIN ANYWHERE!
boy was i pissed. So then i was like okay. unhook it, im ripping out the rear panels.
Thats when i got the most pissed off about a car that i have ever been in my entire life.........
Audiosavvy. You were 100% correct. I pulled off the left rear door panel, and one of the speakers that was only held up my 1 freaking bolt, the bolt broke. The speaker fell. And grounded out the entire system......
I just spend all last night, and all day today ****ing with this god damn car, spending money on new stereo equipment, rewiring everything, and blah blah blah, all to find out the only problem was a speaker that wasnt properly supported, fell down and was grounding out. That was the ONLY problem....
But oh well, **** happens. i have tunes again, i have a bad ass new head unit im in love with. I guess it all turned out a happy ending right?
Thanks for the help everyone. Ill post some pictures later of my mess
your absolutly right about new age decks. especially when it comes to decks like mine. You should see the inline fuse built right into the harness for the machine. its massive! lol If you short this thing out, Im suprised your still alive... haha
Old 09-18-2009, 10:18 PM   #11
anthony_delprete84
Member#: 88254
nice ride by the way. what u got in mind for future mods? Im still in a pickle with my car audio and no one told me to take a shot
anthony_delprete84 is offline   Reply With Quote
Old 09-18-2009, 11:46 PM   #12
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
gald you found the problem, when i read your OP I would have called the same problem, that is a typical response from a deck when I speaker grounds out, the amp shuts down to protect itself.
nice ride BTW i want to see pics!!
Chp_Stix is offline   Reply With Quote
Old 09-19-2009, 01:07 AM   #13
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
wow... Glad you got it sorted, but man that sucks.
Thank god we have access to these guys
V6TurboTA is offline   Reply With Quote
Old 09-19-2009, 04:31 AM   #14
SubarusRmyThing
Member#: 203031
2005 Baja Turbo
White/Silver
Thanks. I really need to get my utec, 4" down pipe, and full exhaust so i can put on my VF39 ive had sitting around for ever, and get a protune. Thats in the future. I really want a set of megan racing coils, and a set of STi BBS's, along with a nice set of brembo's. And obviously a 6spd tranny lol. but thats all a LONG ways out. and a LOT of money. probably wont happen till the car is paid off in 4 years. Need to get my front windows tinted to match the back, CF hood. PAINTED! i hate cf unpainted most the time. Switching to front mount IC, intake of course when that happens, and i dunno, bunch of stuff. it will all happen, just not sure in which order yet lol. Also going to do some polyurethane liner work on it in misc places. I own my own business, and a service i offer is spray in bedliners, so i want to do some cool things with the baja to help promote that and its unlimited number of uses.
Ill try to take some recent ones tomorrow. But heres a couple from the first day i bought it, and the first 3 mods i did in the first 5 hours of ownership haha.
Perrin Upper and Lower Intercooler hoses.
De-ambered head lights and Rallitek LIcense plate frames
STi REAL carbon fiber pedals. not walmart knock off ****.
ANd this is a VERY ****ty photoshop of what im going for
Ill take some pictures tomorrow, of the deck and all around shots.
Old 09-19-2009, 04:40 AM   #15
02CWRX
Member#: 196013
2002 WRB WRX
EJ207 6-Speed
That overall look is awesome. I love how its a rear wheel photochopped into the front, and the caliper is in the way wrong spot, haha. I picked up my Brembos for my STi swap the other day, and I was joking about how just putting a rear caliper on the front would probably be an improvement, so its especially funny to see it photochopped like that to me.
~T.J.
02CWRX is offline   Reply With Quote
Old 09-19-2009, 05:43 AM   #16
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
nice man! STi swap FTW
Old 09-19-2009, 07:00 AM   #17
Arctic Cougar
Member#: 223815
2005 WRX STi
have you tested all the wiring with a multimeter? I found the first basic rule in troubleshooting to be the most helpful...Step 1: check the setup.
sounds overly simplistic, I know...but, even as an electronic technician, I catch myself skipping that step and regretting it a LOT!
without actually sitting down in the car and looking at the hack work done, I can't really give you any accurate advice. if you have any specific questions, I'd be happy to address those. but as a general blanket piece of advice, I'd say focus on getting the stereo wired back in through the factory wiring...start with figuring out what the issue is (if any) with the factory harness.
Arctic Cougar is offline   Reply With Quote
Old 09-19-2009, 02:09 PM   #18
The Satch
Member#: 149174
that 's cool. i
have a goldfish.
have you actually read the thread?
The Satch is offline   Reply With Quote
Old 09-19-2009, 03:03 PM   #19
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
Brand New Decks Have Problems Too Sometimes
feint05 is offline   Reply With Quote
Old 09-19-2009, 03:42 PM   #20
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
[email protected] 3 corners of the car, re-wiring, only to find out that 4th corner was the problem...
It's a beyoch sometimes, but the lesson learned is sometimes more valuable than the time money spent...!!!
Congratz on finding the issue...
Old 09-20-2009, 12:04 AM   #21
SubarusRmyThing
Member#: 203031
2005 Baja Turbo
White/Silver
~T.J.
haha yeah like i said the photoshop sucked! i couldnt find a good picture of BBS's with the caliper in the right spot for the front haha. so it got rear!
Nice thing about the bajas, is they basically have a STi short block. Same block, pistons, rods, heads, yadi yada. All it really needs is the vf39 turbo, and a different intake mani with a more performance based tune and your talking sti numbers.
When i get my exhaust, and tune done, im aiming for 300 whp. But to achive that, ill probably sell the vf39, and find something a tad bigger. My buddy has a bug eye making 340 whp right now, maybe ill try to get him to sell me his turbo and upgrade. Im sure he will be getting bored in the near future haha.
wow dude.... wow. Heres a monkey for your troubles.
**** happens! But a good lesson! your absolutly right.
Snap a few pictures today, as promised, Was at the drag races all day, so only got a couple, but here ya go.
Pictures from my mess lol.
Damn that ****ing speaker!
But it has paid off!
Old 09-20-2009, 12:23 AM   #22
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Nice Baya...
Now, paint that sucker all one color and proceed with your master plan..!!
Baya STi...!!!
Old 09-20-2009, 09:00 PM   #23
Back Road Runner
Member#: 60082
2004 Forester STI
Haha, great story. My first guess would have been the right one. If an entire system cuts in and out, it's a speaker, learned long ago from experience.(not my fault ).
It doesn't matter. It's good to run fresh wire and correctly anyways, despite the hassle.
The Bajas are neat cars. It's strange so few were sold. I'd own one if they started making them a few years earlier and dropped into my price range.
Lets see if OT can figure this out.. pgtkid Off-Topic 19 04-27-2008 10:54 PM
ej18+ej20g+ej20K powerFC. crazy idea. i wonder if anyone has figured this one out. stupidguy Subaru Conversions 6 05-11-2006 02:37 PM
Let's see if anyone knows what this is...? AdmireWantWillLove Off-Topic 4 04-03-2004 02:00 AM
Feeling bored today, lets see if i can stir things up... AaronWRX Mid Atlantic Impreza Club -- MAIC 11 09-13-2003 02:06 AM
Ok guys.. lets see if we can repeat the 1st KAMINARI MEET! rayder Southern California Impreza Club Forum -- SCIC 113 10-25-2002 07:36 PM
