Old 09-18-2009, 02:15 AM   #1
NotMyGT
Member#: 194599
2005 Legacy GT
Default Twinscroll GT3076R
Does anyone have any experience with these? I see ATP sells them. Only thing I'm concerned with is the .78A/R hotside, sure it'll help with the bottom end, but I really don't want to lose out on the top end. I want the best of both worlds, which may be too much to ask for.
Come to find out they have a T4 Twinscroll only available with the 1.06 hotside. Don't know if I want to go that big.
Also, rumor has it the A/Rs indicated aren't accurate. Supposedly the cast divider creates a smaller A/R. Can anyone confirm or deny this?
Edit: The T4 fitment has been confirmed by ATP.
NotMyGT is offline   Reply With Quote
Old 09-18-2009, 03:20 AM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Deja vu.
Old 09-18-2009, 03:21 AM   #3
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Check out the Airwerk's S200SX 75/70 (here), it has similar spool to the GT3076R, but flows more air for more whp. It also has a larger selection of twin-scrol housings available too.
And the best thing is, it is only half the price of the ATP twin-scroll GT3076R
Leslie
wrxsti.l is offline   Reply With Quote
Old 09-18-2009, 05:04 AM   #4
socalLGT
Member#: 89752
08 STI
Leslie
That is exactly the turbo that is going on my car in conjunction with a twinscroll Full-Race manifold/uppipe. I've been very happy with my single scroll GT35R, so this is just a great opportunity to test out a "new" turbo and see if I can get very close to the same peak power with significantly better spool. Given what I have already experienced with BW turbos and the Full-Race TS manifold I doubt I'll be disappointed
socalLGT is offline   Reply With Quote
Old 09-18-2009, 05:33 AM   #5
badmammajamma
Member#: 84419
2005 WRX STi
380whp ATP 35r
I cannot find anyone using this turbo anywhere looks nice and priced right if this is as good as it looks they will be sold out soon.
badmammajamma is offline   Reply With Quote
Old 09-18-2009, 07:38 AM   #6
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Kelly at Covert Performance is making a twinscroll 200SX turbo for me. Should be on the car in about a month. Borg for the Win.
ASU is offline   Reply With Quote
Old 09-18-2009, 11:34 AM   #7
NotMyGT
Member#: 194599
2005 Legacy GT
There are a couple reasons why I don't really want to go with the S200sx. 1: It's a marmon flange on the hotside to downpipe. 2: It's a journal bearing turbo.
I've looked extensively into turbos and options, I like that the Garrett turbos are DBB with a V-Band flange.
There's a guy local to me who's building a S300sx kit and the downpipe to the marmon flange doesn't look too sturdy because of the lack of room he has to play with.
Sure I could go with the S200sx and machine the flange down to a V-Band and call it a day but that'll add extra costs to the kit.
I'm glad to hear everyone likes BW Turbos, but I specifically asked about Garrett GT3076R with the twinscroll housing.
Old 09-18-2009, 11:45 AM   #8
Badler
Member#: 133597
Geoff @ Full Race probably has all the info you are looking for. He has tested countless combinations. Maybe he will chime in here.
Badler is online now   Reply With Quote
Old 09-18-2009, 12:20 PM   #9
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Out GE coumbustion turbine natural gas feed lines and turbine section bypass lines extensively use marmon flanges. I'm going to say if its good enough for a jet engine, its good enough for my ride.
Old 09-18-2009, 12:28 PM   #10
NotMyGT
Member#: 194599
2005 Legacy GT
I didn't say the flange isn't up to par, the downpipe built to fit it isn't.
Old 09-18-2009, 12:45 PM   #11
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
In your first post you said the GT3076R twin-scroll uses a T4 flange - the S200SX also uses a T4 flange.
T4 is T4
These new Borg Warner turbos use the most recently designed journal bearing technology, with fully floating dual sleeve bushing bearings and a 360deg axial thrust bearing. They are not your old ass journal bearing turbos of the 80's.
Any benefit the Garrett turbos gain from ball bearing CHRA is gained back by the Borg Warner with its extended tip technology.
The Airwerk's turbos have been shown to be just as good as Garrets (if not better) at the same compressor flow rate, even with with more compresor flow, they still spool very well.
If you buy the S200SX from FullRace, then it can come in the exact same setup - T4 twin-scroll turbine housing with 3" v-band. So no difference there.
If ppl can fit a rotated GT40 in the WRX's engine bay, you will have no problem fitting an S200SX.
Also, there are a few companies now that make rotated borg warner kits for the wrx, so again you should have no problems fitting it
Check out the Yimisport's ugly betty with Fullrace S300SX rotated kit thread HERE. If it fits, the S200SX will too.
As above, from FullRace it can come with 3" v-band. eg:
np at all. I've corrected the incorrect info and I'll leave you to it now.
Leslie
EDIT: Just found this comparison of the Bullseye S200 (not exactly the Airwerks S200SX) and GT3076R - interesting results indeed:
With the Airwerk's SX housings, it should performeven better then the Bullseye.
You really have to ask yourself why you want the Garret, when the S200SX is over $1000 cheaper and performs equally as good (if not better)
Old 09-18-2009, 01:20 PM   #12
NotMyGT
Member#: 194599
2005 Legacy GT
Thank you for the great comparison with logical reasons why the BW has advantages.
My concern came from the builder when he said this regarding the marmon flange:
"well the turbo is mounted as far forward in the car as possible without hitting the brake lines on the strut tower and the intake manifold. But that damn marmon flange setup and the transition from 3.5"-3" takes up way too much room (2" in length to be exact) and cant fit a down pipe on it. Customer wanted the way it came from the factory isntead of spending the money and getting the 3.5" marmon setup machined off and welding on a 3" v-band. Totally stuck now and its the last thing i need."
Is that TS vs TS? Or SS vs SS?
Old 09-18-2009, 01:30 PM   #13
Badler
Member#: 133597
Isn't a T4 flange the same size. TS or SS?
Old 09-18-2009, 01:41 PM   #14
NotMyGT
Member#: 194599
2005 Legacy GT
Yes, but if the spool up time differs on the dyno, I want to know if we're comparing apples to apples.
Old 09-18-2009, 02:00 PM   #15
Badler
Member#: 133597
I thought you were talking about actual size. Like if the SS was shorter with more room for the DP. Now I see you were talking about the dyno plot. Whoops!
Old 09-18-2009, 02:10 PM   #16
NotMyGT
Member#: 194599
2005 Legacy GT
Notta problem.
I'm not completely sold on the TS 30R, but I do want to find out more information specifically on that turbo, whether in real world experience or dyno plots.
Old 09-18-2009, 02:18 PM   #17
Badler
Member#: 133597
Notta problem.
I wanna say from what i've seen most just go with the 35 and that you really need the 1.06ar on these motors. Similar spool with more top. Wish I could find which thread i'm thinking of.
Old 09-18-2009, 02:33 PM   #18
NotMyGT
Member#: 194599
2005 Legacy GT
I'm looking for similar or close to similar spool times with about 350whp. I don't know if that's attainable, which is why I'm asking all these questions. I searched and searched, I don't think anyone is really running a TS 30R. I don't want to go more power because if I do my transmission will be a ticking time bomb, literally. Sure once the transmission goes, it's time for an upgrade.
Old 09-18-2009, 03:07 PM   #19
Badler
Member#: 133597
You don't need rotated to hit 350whp. An EWGd 20g will get that on an "average" reading dyno. Whatever that means.
Old 09-18-2009, 03:52 PM   #20
NotMyGT
Member#: 194599
2005 Legacy GT
It'll be a mild 350 until the tranny goes, then I turn up the powah.
Old 09-18-2009, 04:04 PM   #21
Badler
Member#: 133597
Gotcha. Well then it's settled, TS 35R running about 15psi.
Old 09-18-2009, 04:08 PM   #22
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
I have a TS 3076 with a .82 euro spec v-band T3 hotside, on Full Race's second generation manifolds and uppipes with the twin 44mm v band dumps.
It's mighty impressive. It pulled very hard to redline, easily made over 400 on a low reading dyno, and no cams then.
I don't get the pricing that's being kicked around - The 3076 is $1300, I think the Airwerks is similar, maybe $900? Certainly not $1000 LESS than Garrett.
In any case, I'm positive either turbo would do very well.
Zornorph is offline   Reply With Quote
Old 09-18-2009, 04:24 PM   #23
NotMyGT
Member#: 194599
2005 Legacy GT
Do you recall when you hit full boost?
Old 09-18-2009, 04:43 PM   #24
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Can you point me in the right direction to get this TS 30R? From what I've found the 30R is ~$1300 without the TS housing + housing = ??????? I want one too and was thinking about going with the BW but I would prefer a water cooled CHRA. I can car less if its BB or journal bearing as long as the spool is similar.
EDIT: Nevermind, ATP has them for the right price.
Old 09-18-2009, 04:58 PM   #25
Angry Toaster
I'm not angry
Member#: 62555
1993 FD3S
E92 / CBR600RR
OMGHi2U
You can check out this thread for the shop that is using the ATP TS 30R on their TS turbo kits.
And now the shameless plug for my FS ad for the same ATP TS 30R turbo.
Angry Toaster is offline   Reply With Quote
SoCal: STi heads, GT3076R, Invidia DP, rear o2 sensor & twinscroll dp flange BlueFish Engine/Power/Exhaust 25 10-12-2009 01:03 PM
STi heads, GT3076R, invidia DP, rear o2 sensor & twinscroll dp flange BlueFish SCIC Private Classifieds 26 10-12-2009 01:02 PM
SoCal: STi built heads, GT3076R turbo, o2 sensor and twinscroll flange BlueFish Engine/Power/Exhaust 29 09-21-2009 02:05 PM
SoCal: GT3076R, APV1, o2 sensor and twinscroll downpipe flange BlueFish Engine/Power/Exhaust 28 08-16-2009 11:45 PM
FS: Garret GT3076R Twinscroll Turbo MartinSTi05 Engine/Power/Exhaust 15 07-04-2008 10:50 AM
