Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 09-18-2009, 01:14 PM   #1
hockydog11
Member#: 200478
Default Noise from clutch/driveline just started
My 2005 Legacy GT MT just developed a rattle, or cricket/treefrog noise. I makes the noise when the car is moving, and when the clutch is fully engaged meaning the clutch pedal is not being depressed. If I depress it just slightly, just .5 inches, the noise goes away. The clutch is not engaging at all at that point. The clutch is operating just fine and has not been slipping, nor is it now. Any suggestions on what this is would be helpful! The car has 56,000 miles on it. Not sure of the age of the clutch. Would like to figure out what I am facing before I take it to the service center.
hockydog11 is offline   Reply With Quote
Old 09-18-2009, 02:04 PM   #2
doug*E*fresh
Member#: 116794
02 wrx
sedona red
my guess would be throw out bearing
doug*E*fresh is offline   Reply With Quote
Old 09-18-2009, 02:19 PM   #3
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Ding ding ding.
The fact that when you put a nudge or pressure on the clutch pedal makes it stop is a dead giveaway to a noisy TOB.
09rexwagon is offline   Reply With Quote
Old 09-18-2009, 03:19 PM   #4
hockydog11
Member#: 200478
Thanks..... I was thinking that as well. Any idea on repair costs?
Old 09-18-2009, 03:26 PM   #5
09rexwagon
Member#: 216135
2011 Civic SI
A noisy TOB does not necessarily imply a bad TOB. You could potentially get 10s of thousands of miles on it without issue. On the other hand, sometimes a noisy TOB can develop into a bomb and vibrate and break into many parts and possibly kill your input shaft and pressure plate. So you just have to weigh the risk (granted the latter scenario is very rare).
If you really want to just get it fixed, it won't be cheap. $500+ on labor alone to replace a $30 bearing. If you pay that much labor, you mind as well do a clutch and pressure plate while they are in there.
Old 09-21-2009, 03:53 PM   #6
hockydog11
Member#: 200478
[quote=If you really want to just get it fixed, it won't be cheap. $500+ on labor alone to replace a $30 bearing. If you pay that much labor, you mind as well do a clutch and pressure plate while they are in there.[/quote]
I was wondering that too. Dealer I bought it from says they think the previous owner replaced the clutch before trade in (yeah right). I am inclined to get an estimate after my guy looks at it. What should the clutch and pressure plate run?
Old 09-21-2009, 04:02 PM   #7
09rexwagon
Member#: 216135
2011 Civic SI
OEM or Exedy or ACT.
squeaking noise from clutch pedal? sjw Newbies & FAQs 5 05-28-2004 10:10 AM
Help: Squeaky/Creaky noise from clutch pedal... Robmat Transmission (AT/MT) & Driveline 3 10-15-2003 04:41 PM
question about noise from clutch/tranny jjshin Transmission (AT/MT) & Driveline 15 10-18-2002 11:29 PM
"Spring" or "Rattle" noise from clutch pedal bjteel Warranty Issues & SOA Problems 7 05-30-2002 04:17 PM
Strange noise from clutch pedal 555wagon Normally Aspirated Powertrain 7 02-21-2001 01:45 AM
