Old 05-08-2002, 06:50 PM   #1
ninrex
Member#: 9851
'07 WRX Wagon
Question Need help with fog cover install
Alright, I'm just not seeing how these are supposed to go on. I'm assuming this one goes on the driver's side?
ninrex is offline   Reply With Quote
Old 05-08-2002, 06:55 PM   #2
ninrex
Member#: 9851
'07 WRX Wagon
And this one goes on the passenger side? Anyway, there is no way these brackets will mount on the fog light screws and reach all the way up to the cover. I thought it was just a matter of removing one screw from the lamp, installing the bracket on that screw, inserting the tabs from the cover, and then screwing the bracket and cover together. What am I missing here?
Old 05-08-2002, 06:58 PM   #3
ninrex
Member#: 9851
'07 WRX Wagon
See the little 'L' in the first pic? I'm assuming that means left side of the car. The bracket in the second pic has an 'R' on it but it isn't really visible. The fog covers actually fit better reversed from what I've shown, but that places the mounting hole for the bracket even further away so I don't know if that's right. Help, please!
Old 05-08-2002, 09:50 PM   #4
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
Those look like replica covers, so not sure if they'll fit as good, but..
The covers fit very tight - at first I thought they weren't going to fit at all - but they actually 'snap' in pretty good. try to insert/line up the little tabs at the top.
The brackets do bolt right on. Take out the lower outside screw and put it through the 90 deg. end of bracket and then put screw & bracket back in under light. Really can only go one way. When cover is 'snapped' in all the way, screw and bracket pretty much line right up.
CTKAG is offline   Reply With Quote
Old 05-08-2002, 10:03 PM   #5
ninrex
Member#: 9851
'07 WRX Wagon
Yeah, they are replicas from Vivid. Thanks for the advice, I'll just try pushing harder. I didn't realize I'd have to force them in.
need help with fogs on with high beams Spy Interior & Exterior Modification 5 07-14-2005 10:05 AM
need help with fog light covers! EJ22Boom Interior & Exterior Modification 11 03-07-2005 10:00 PM
need help with bumper cover CalcVictim Interior & Exterior Modification 0 05-20-2004 09:01 PM
Need Help With Fog Lights!!! Andursun0013 Electrical & Lighting 5 04-20-2003 10:48 PM
Need help with Zex nitrous install...yes I did a search, I need pics!! wrx_in_efx Texas Impreza Club Forum -- TXIC 13 04-10-2002 01:26 PM
Message Board Statistics All times are GMT -4. The time now is 12:57 AM.
