Old 09-19-2009, 09:40 AM   #1
tPW
Member#: 214848
2010 WRX Limited Sdn
Default Will stock 02 wrx wheels fit a 2010 wrx?
Will stock 02 16" wrx rims and tires fit a 2010 wrx?
I'm planning on using it for a winter setup.
The tire size seems to be the same so this could be a good deal and better than a steel rim. I cant find the offset of my wheels in the manual, but I know the 02-03 are +53 to +55
tPW is offline   Reply With Quote
Old 09-20-2009, 03:18 PM   #2
tuskenraider
Member#: 65699
15 WRX
WR Blue
Yes, they'll fit.
tuskenraider is offline   Reply With Quote
Old 09-21-2009, 10:36 AM   #3
Ruthless671
Member#: 150300
Chapter/Region: HIIC
2006 STi
^^+1, 5x100, yes they will fit.^^
Ruthless671 is offline   Reply With Quote
Old 06-16-2010, 10:24 AM   #4
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
I'll dig this one up since it is exactly what I'm after...
Will the 16's clear the rotor/caliper's?
I'm looking to do the exact same thing > '02 WRX wheels on a '10 WRX for winter.
ki4syr is offline   Reply With Quote
Old 06-16-2010, 11:31 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by tuskenraider View Post
Yes, they'll fit.
is there some part of the above that was not CLEAR?????
Old 06-16-2010, 03:23 PM   #6
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
Doesn't say anything about calipers, unless I'm blind. 5x100 is bolt pattern. '02 has 16" stock, '10 has 17" stock and bigger front&rear brakes.
If you have nothing useful to add, don't reply.
Old 06-16-2010, 07:14 PM   #7
tuskenraider
Member#: 65699
15 WRX
WR Blue
08+ basically has the same 02-05 front brakes(just .2" bigger rotors, 1" bigger and now vented in the rear), as mentioned, they fit.
Old 06-16-2010, 08:17 PM   #8
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
Ok that's what I was worried about. Thank you.
Old 06-16-2010, 11:08 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
Yes, they'll fit.
that is 1000% conclusive to me
how could anybody mis****ing interpret THAT????
Old 06-17-2010, 02:18 AM   #10
kickniteasy
Member#: 201661
2013 STI
2002 Forester
ok...so some random person on the internet says nothing but "yes they will fit" and we're all supposed to take it as the be all end all. Heaven forbid someone try and double check an internet based fact in order to make sure they don't waste money on a purchase or worse, mess up their car.....
kickniteasy is offline   Reply With Quote
Old 06-17-2010, 04:32 PM   #11
Halfaed
Member#: 241658
2010 WRX
Lightning Red
I have put said wheels on said car and they do fit. I am going to run them for the winter also. Snow tires for 16" wheels are a lot cheaper than snow tires for 17" wheels.
Halfaed is offline   Reply With Quote
Old 11-05-2011, 10:36 AM   #12
changd123
Member#: 233794
'15 STI
Crystal White
Reviving old thread!
hey guys! I put 02 wrx wheels on my 09 etc.. But for some reason I hear a metal to metal swoosh swoosh noise as I pick up speed.. Doesn't sound healthy .. Anyone have any idea what it could be? i'm lowered on epic springs and koni if that helps. No aftermarket brake upgrades other then brake lines.
Thank you!
David
changd123 is offline   Reply With Quote
Old 11-05-2011, 11:00 AM   #13
kickniteasy
Member#: 201661
2013 STI
2002 Forester
have you looked under the car to see if anything looks rubbed?
Old 11-05-2011, 11:48 AM   #14
changd123
Member#: 233794
'15 STI
Crystal White
Yeah doesn't seem like anything is rubbing.. could it be my dust Shield behind the rotor?
Old 11-05-2011, 01:09 PM   #15
changd123
Member#: 233794
'15 STI
Crystal White
Would lug bolts make a difference? I have tuner lugs from my rotas that i'm using....
will 05 sti bbs wheels fit a 03 wrx? IvanFA20 Tire & Wheel 3 04-07-2010 05:28 PM
Will 16" 2002 WRX wheels fit a 2008 WRX ??? Shawn S Tire & Wheel 29 05-05-2009 11:51 PM
Will any Rota Torque wheels fit my 04 wrx sti? ceecel Tire & Wheel 4 05-04-2008 06:21 PM
will evo ix mr wheels fit on a wrx dontgiva Tire & Wheel 1 01-10-2008 10:56 PM
Will a 17X8.5 wheel fit on a WRX wagon? JB1 Brakes, Steering & Suspension 3 04-26-2002 10:40 PM
