Old 09-20-2009, 07:25 PM   #1
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
By hotmetal5 at 2009-09-20
i thought i would be closer to 270-280hp like tuned vf34 and vf39. This is with a version 8 motor and functional avcs. Its basically a stage 2 STi with Walbro 255 fuel pump. Stock jdm IC, stock intake, stock TS manifolds and uppipe. catless 3" catback. The downpipe is hacked at the oem head and welded to 2.5" piping.
open ecu tuned to 18lbs.
scoobystas is offline   Reply With Quote
Old 09-20-2009, 07:47 PM   #2
jutes85
Member#: 127232
E92 M3
98' Foz
DD read low. Those numbers look about right at that boost level and mods. You'll hit 280hp no problem on a brahdyno.
jutes85 is offline   Reply With Quote
Old 09-20-2009, 07:50 PM   #3
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Looks about right to me!
renosubby is offline   Reply With Quote
Old 09-20-2009, 08:29 PM   #4
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
the car was tuned in 4rth gear. I did some datalogging and it hits full boost at about 4100 in third gear....thats a bit high no? especially since i have avcs?
Old 09-20-2009, 10:07 PM   #5
tplumsti
Member#: 144791
2004 Forester XT
dyno dynamics run low? thats news to me, i thought dd was in the closest range?
tplumsti is offline   Reply With Quote
Old 09-20-2009, 10:24 PM   #6
darranNW
Member#: 203616
stg2 08wrx TimBailey
Tuned 251/322 @15psi
Originally Posted by scoobystas View Post
i thought i would be closer to 270-280hp like tuned vf34 and vf39. This is with a version 8 motor and functional avcs. Its basically at stage 2 with 255 fuel pump. Stock jdm IC, stock intake, stock TS manifolds and uppipe. catless 3" catback. THe downpipe is hacked at the oem head and welded to 2.5" piping.
do you have any pics of your down pipe? i've been thinking of doing that
darranNW is offline   Reply With Quote
Old 09-20-2009, 10:55 PM   #7
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
darrenNW,
its not pretty trust me. there are no leaks but the SS piping post the cast head are not perfectly smooth, the shop just has a pipe bender so the bends are not mendrel bents. I'm thinking of buying a 3' downpipe and having a shop weld the IA performance vf37 flange. The neck of the oem jdm downpipe actually tapers to 2.25", so i think its holding me back.
Old 09-20-2009, 11:51 PM   #8
ZaQSTI
Member#: 142543
05 STi
...Its basically a stage 2 STi...
Sounds like a bit of a stretch to me. With those numbers you are still 50 whp behind what most stage 2 setups make. Looks good all the same.
ZaQSTI is offline   Reply With Quote
Old 09-21-2009, 12:14 AM   #9
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
What does a stock STI put down on this dyno?
Old 09-21-2009, 10:39 AM   #10
Badler
Member#: 133597
You think most stage 2s hit 300whp on DDs? This is a 2l right?
Badler is offline   Reply With Quote
Old 09-21-2009, 11:09 AM   #11
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
It's right where Stage II USDM STi's are on the Mustang Dyno that my car gets tuned on. 245-265 day after day after day.
That's decent numbers for a 2.0 and you're holding it passed 7300. Nice.
UFOpilot is offline   Reply With Quote
Old 09-21-2009, 01:01 PM   #12
paul_p1
Member#: 77372
2005 Spec C
WR Blue
What turbo is this?
paul_p1 is offline   Reply With Quote
Old 09-21-2009, 01:41 PM   #13
Rokkit
Member#: 84181
NASA #530 GTS2
I put down 305/305 full spool at 3550(ish) on my version 8, stock vf37...
21 psi - basically stage 2 like yours.
Rokkit is offline   Reply With Quote
Old 09-21-2009, 05:10 PM   #14
BamBooI
Member#: 10945
2006 Evolution IX
Don't compare dyno numbers. Take it to the strip and see what your MPH is with good driving.
BamBooI is offline   Reply With Quote
Old 09-21-2009, 06:07 PM   #15
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
[IMG] and welded to 2.5" piping.
well....most name brand tbe are 3".
and many "stage 2" folks also have headers, up pipe, tgv deletes, and intake.
Old 09-21-2009, 08:30 PM   #16
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
well from what i understand the oem twinscroll header thats on this motor is really well built and designed from the factory. the intake manifold has no tgv since its jdm. I think if i were tuned at 20 or 21lbs i would have made much better numbers.
I know this is going to be off topic and belong in ecu forum but i've already got the dyno chart here, etc.
if i raise target boost and crank up the wastegate duty cycles just a bit to actually hit the 21lbs or so, what else would i need to change on my map? I'm assuming i should take a few degrees of peak load timing out, since increased boost in those ranges will raise cylinder pressures and it might knock??? My afr is 11.2 i believe at redline, so wouldn't need to mess with that too much, or is it dynamic and will change once i alter boost?
Old 09-23-2009, 12:41 AM   #17
Badler
Member#: 133597
You have a wideband o2? Essential for that.
Old 09-23-2009, 01:42 AM   #18
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
you get my PM.. ?
Not sure what gear that log was, but your timing doesn't look right
BUILTSTI is offline   Reply With Quote
Old 09-23-2009, 01:06 PM   #19
LateApex31
Member#: 135686
darrenNW,
2.25 pipe FTL. Cars that make good power have 3" from the turbine outlet to the exhaust tip, period.
Stage 2 STis make 260-280 WHP on this dyno. Stock STi makes 195-210 depending on the year. 2,0l WRX makes 145-155 stock.
LateApex31 is offline   Reply With Quote
Old 09-27-2009, 01:45 PM   #20
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
i don't have a wideband 02, unfortunatley. I guess i'm gonna search for an IA flange to fit a proper 3" downpipe and then see what happens.
car was tuned in 4th gear, so the dyno pull is also 4th. I do my logging in 3rd because a 4th to redline pull hits rediculous speeds.
Old 09-27-2009, 04:50 PM   #21
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
...on what dyno? I'll bet it wasn't this one.
CKxx is offline   Reply With Quote
Old 09-27-2009, 05:47 PM   #22
tplumsti
Member#: 144791
2004 Forester XT
i put down 302/299 on a dyno dynamics. vf39 , fmic , step colder plugs, k&n typhoon.
Old 09-27-2009, 09:55 PM   #23
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
This is why you cannot use dynamometer numbers as empirical fact. Before and after on the same dyno, back to back yes. Everything else is a waste of bandwidth.
OP: Glad you got some decent power out of your car, I hope you enjoy it.
Old 09-28-2009, 12:09 AM   #24
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
thanks ufo....i do enjoy it. i'm getting some FBC and FLKC here and there so i'm fine tuning the timing tables. I really want to push this turbo harder however, but i'll need the bigger downpipe and a wideband o2 for tuning it.
Just looking for some feedback...maybe some ideas pana24 Member's Car Gallery 49 11-06-2009 12:23 AM
Looking for some info on my subie glenb1991 Newbies & FAQs 8 12-12-2008 08:55 PM
looking for some input on a awesome deal for a 04 wrx!!! please look bl02wrx General Community 6 12-06-2007 07:22 AM
ran my wrx at etown the other day, just looking for some pointers bluesubaru Proven Power Bragging 3 03-06-2007 09:26 PM
looking for some info on my engine? BREWPUBEAVER North West Impreza Club Forum -- NWIC 7 11-17-2005 10:16 AM
