Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Car Care & Detailing
Closed Thread
Old 07-21-2008, 04:53 PM   #1
Touge Factory
Vendor Sales Rating: (17)
Member#: 182232
2005 STi
Default Eneos / Royal Purple / ATE / KAAZ
Eneos
0W-50
ENEOS Motor Oil 0W50 is the ultimate 100% synthetic oil for gasoline engines. Applying the advanced oil technology developed for auto racing by the Nippon Oil Corporation, this motor oil has an ultra wide 0W-50 viscosity range, so it provides outstanding performance from the very coldest to the very highest temperatures. ENEOS Motor Oil 0W50 is especially suited for sports cars with large engine displacements and high outputs.
5W-40
ENEOS Motor Oil 5W40 is a high-performance motor oil for gasoline engines that meets the latest SM standard of the American Petroleum Institute (API). It also meets the standards of the European Automobile Manufacturers Association (ACEA), so it is especially suitable for European cars. It meets the API CF standard as well, so it can be used in passenger cars and small trucks with diesel engines
5W-30
ENEOS Motor Oil 5W30 is a high-performance gasoline engine oil that meets the latest SM standard established by the American Petroleum Institute (API). With a viscosity grade of 5W-30, it has been specially designed for good engine starts and good oil-film protection of moving components of the engine at high temperatures. This motor oil brings out the best performance from all types of gasoline-engine vehicles.
Royal Purple
Motor Oils 20W50, 10W-40, 5W-30
Royal Purple Motor Oil is recommended for use in all four-cycle gasoline engines and both two-cycle and four-cycle diesel applications including cars, trucks, motor homes / RVs, boats, commercial fleet and stationary industrial diesel engines. Royal Purple Motor Oil is a tough, long life, high performance oil that delivers superior protection and enhanced performance to gasoline and diesel engines. It gains its performance advantages from a blend of synthetic oils plus Royal Purple's proprietary, synthetic Synerlec additive technology.
Synerlec additive technology greatly reduces engine wear, including ring, cylinder and bearing wear. It is extremely tenacious, adheres to engine surfaces and remains after shutdown, which provides protection upon initial startup.
Max-Gear 75W-90
Max-Gear is recommended for use in truck, motor home / RV, and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid. Max-Gear is an ultra-tough, high performance, GL-5 automotive gear oil designed to provide maximum protection to heavily loaded gears while maximizing power output throughout the drive train. It outperforms other GL-5 gear oils because it combines the highest quality synthetic oils with Royal Purple's proprietary Synslide additive technology.
Max-Gear makes gears run smoother, quieter, cooler and longer without overhauls.
Purple Ice
Purple Ice is a high performance, synthetic, radiator coolant additive for both gasoline and diesel engines. It is formulated to reduce the surface tension of the coolant, which improves heat transfer through the cooling system while providing additional protection against rust, corrosion and erosion. Purple Ice prevents the formation of scale deposits in the radiator for optimum coolant flow and lubricates the seals of the water pump. It is ideal for use in straight water racing applications or in antifreeze / water mixtures.
Purple Ice is compatible with traditional ethylene glycol antifreeze (green) and GM Dex-CoolŪ antifreeze coolants.
ATE Super Blue/Gold
ATE Super Blue/Gold DOT 4 Racing Brake fluid is an ideal choice for handling the high demands placed on your brake system, regardless of whether you are involved in autocross, road racing or high performance street driving. ATE Super Blue Specifications:
DOT Rating - 4
Dry Boiling Point - 536°F
Wet Boiling Point - 396°F
Compatible With Other Fluids - Yes
Container - One liter metal can
Note: ATE Super Blue and ATE Type 200 (Amber) Brake Fluid have identical characteristics but are different in color. To assure that you have flushed out all of the old fluid in your system, alternate between the two every time you change your fluid.
KAAZ 80W-90 GL-4
PM ME FOR PRICING ON FLUIDS.
Touge Factory is offline
Old 09-29-2008, 12:38 PM   #2
Touge Factory
Member#: 182232
2005 STi
Bump.
Old 08-04-2009, 11:45 AM   #3
Touge Factory
Member#: 182232
2005 STi
bump it up.
__________________
Check us out on
PM me for BEST PRICING: VOLK / ADVAN / HJC Motorsports Helmets / Whiteline / TOMEI / Work Wheels / RECARO / OMP / Weds Wheels / Enkei / Full-Race / Nardi / Personal / Works Bell / SWIFT Springs / CL Brakes / AMS / AEM / AME / CompetitionClutch / Ferodo / KEY!S ....and many more!
For fastest response and best service, call us direct and ask for Nick!
Old 08-07-2009, 12:17 PM   #4
Touge Factory
Member#: 182232
2005 STi
we also now carry redline, motul and amsoil!
__________________
Check us out on
Old 08-10-2009, 12:29 PM   #5
Touge Factory
Member#: 182232
2005 STi
keep your car in tip-top shape with these fluids!
__________________
Check us out on
Old 08-17-2009, 01:38 PM   #6
Touge Factory
Member#: 182232
2005 STi
bump up the fluids.
__________________
Check us out on
Old 09-29-2009, 07:51 PM   #7
Touge Factory
Member#: 182232
2005 STi
bump it up!
__________________
Check us out on
Old 10-16-2009, 04:17 PM   #8
Touge Factory
Member#: 182232
2005 STi
bump!
__________________
Check us out on
Old 10-20-2009, 03:37 PM   #9
Touge Factory
Member#: 182232
2005 STi
bump.
__________________
Check us out on
Old 10-27-2009, 06:33 PM   #10
Touge Factory
Member#: 182232
2005 STi
bump.
__________________
Check us out on
Old 10-30-2009, 03:35 PM   #11
Touge Factory
Member#: 182232
2005 STi
bump.
__________________
Check us out on
Closed Thread
Royal purple Purple ice Coolant additive bjonga Engine Management & Tuning 3 08-08-2004 08:47 AM
Royal Purple Engine Oils???? JoeBloggz23 New England Impreza Club Forum -- NESIC 6 04-24-2001 07:41 AM
('93-'01) Vendors who resell Royal Purple or Redline North Ursalia Impreza Forum 1 04-13-2001 07:06 PM
Royal Purple Racing Oil STi-Nismo Dood Normally Aspirated Powertrain 15 02-15-2001 05:38 AM
Royal Purple Oil. wrxman555 Normally Aspirated Powertrain 15 10-23-2000 05:12 AM
