Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 09-21-2009, 06:23 AM   #1
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Default GC/ GM suspension setups
So I'm wondering what everyone else runs for suspension setups on the GC/ GM chassis cars that autoX in classes that allow suspension changes.
I'll start.
XP class
600# front and rear springs on Koni yellows in stock housings
22mm front bar
No rear bar
0 toe all around
-3.1 camber front
-1.5 camber rear
Based on tire temperatures it looks like I need less front camber next year. Based off pictures during hard cornering I think I need to increase the roll stiffness. I am thinking about going to a 25 or 27mm front bar and a 13 or 18mm rear bar with -2.7 front camber and 500# rear springs.
Thoughts and suggestions are welcome.
speedyHAM is offline   Reply With Quote
Old 09-21-2009, 07:49 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Class: FSP
600F / 450R springs
no bars
Single adjustable D2 coilovers
-3.5 front, 1/8-1/4" toe out
-0.5 rear, 0 toe
Based on tire temps and wear, I need to get rid of the toe out up front and add a little more front roll stiffnes. I'm scrubbing the inside fronts more than I'd like and seem to be overheating them. I like the way the rear stays planted when the front doesn't roll over too far. It's transition from grip to slip is predictable, but the car must be driven hard to get the most from it. We used to run with no toe up front and were still happy with turn-in, but loved the longer wear. Rideheight changes have messed with the toe and I just hadn't gotten back on the rack to zero it out. Me= lazyass.
Jay Storm
Old 09-21-2009, 10:49 PM   #3
recnelis
Member#: 92778
2000 Impreza 2.5RS
Class: ST
500 lb/in front, 450 lb/in rear - RCE T2s
22 mm FSB, 22 mm RSB
-3.2* front, 0 toe
-1.5* rear, 0 tie
My front tires are still rolling over a bit too much, so I have an Addco bar I want to try out at some point. I also need to do something about the RSB though, it rubs on the gas filler neck if I put it on full stiff.
recnelis is offline   Reply With Quote
Old 09-22-2009, 01:01 PM   #4
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
DSP
750lbs/F 600lbs/R, Zzyzx coilovers Koni 8611's (may go up to 700's in the rear to get it to rotate better on the concrete at Lincoln)
Camber -3f, -2r
1" front bar, 20mm rear(going to a 22mm rear adjustable one.)
Patrick L is offline   Reply With Quote
Old 09-22-2009, 09:43 PM   #5
madlib
Member#: 16149
2001 impreza 2.5RS
blue
DSP
9 kg/mm - F, 550 lbs/in - R
Koni 8611 in stock housings
7/8" hollow front bar, 1.25" hollow rear bar
-3 F, -2 R
madlib is offline   Reply With Quote
Old 09-23-2009, 11:56 AM   #6
neilschelly
Member#: 94902
1988 911 Carrera 3.2
FSP
Springs: Front 10k (~550lb), Rear 8k (~440lb)
Megan Racing Street Coilovers (single adjustable)
Sway bars: 25mm front Tribeca bar, 20-22-24 Whiteline rear bar on full stiff
Toe: 1/8-1/4" front toe out, 1/3-1/2" rear toe out
Camber: -3.5 degrees front, -3 degrees rear
Tires: 255/40R13 Hoosier A6 on 13x9" wheels
I never got the time to really play with the alignment this year. I ran too much rear toe out, which helped with rotation immensely, but I think if I reduced the rear camber, I'd have gotten the same effect with more stability. In general, all those numbers are exaggerated a bit for concrete and should be a little closer to 0 for tarmac, but the following pic seems to suggest that I was just about maximizing my lateral grip in Nebraska.
neilschelly is offline   Reply With Quote
Old 11-10-2009, 05:18 PM   #7
DougM
Member#: 799
2000 2.5 RS Coupe
Mitsubishi EVO IX
been on here researching swaybar options for the 2.5RS that are larger than 22mm... Addco doesn't seem to make the 1" anymore and the Tribeca bar measures 22.25mm. So what's left looks to be the whiteline BSF20XXZ measuring in at 27mm adjustable. Incidentally, I've seen a lot of people referring to this bar as 27/29. From what I've been reading their adjustable bars are listed at their maximum size (27 in this case) and then adjust down from there. So, it would seem the bar is really a 27/26.5 or so. thoughts?
Is that (27mm) too much bar for a street tire autocrosser? If not, what would you recommend for the rear then?
our specs:
ST class
400# front and 340 rear springs on T2's
22mm front bar (BSF19X)
18-22mm rear bar
.25 toe front
0 toe rear... this might change
-3.2 camber front
-1.0 camber rear
OP, are you on race rubber?
DougM is offline   Reply With Quote
Old 11-10-2009, 07:17 PM   #8
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Yeah- 275-35R15 Hoosier A6's.
With your 400# front and 340 # rear springs the 27mm bar could be just the ticket for you.
Old 11-10-2009, 07:31 PM   #9
DougM
Member#: 799
2000 2.5 RS Coupe
Mitsubishi EVO IX
yeah, I'm debating... that or trying to fit the Addco 1" legacy bar...
are you happy with the balance of your car as is? if so maybe just back off the camber for now and see if your times improve/temps get more even. I'd also triple check to make sure your toe is actually at zero/no scrubbing.
Old 11-12-2009, 11:31 PM   #10
mofugga
Member#: 19540
2000 old skool RS
BRP
i've got a 24-26mm whiteline on my car and love it at 26mm. i get a bit of a rub on the header but nothing too serious.
koni's w/prodrive p1
-1.2 front (my alignment guy sucks)
-.8 rear
0 toe all around
18-22 rsb set at 22
mofugga is offline   Reply With Quote
Old 11-12-2009, 11:48 PM   #11
DougM
Member#: 799
2000 2.5 RS Coupe
Mitsubishi EVO IX
thanks for that, do you happen to know the part number for the 24/26? that's not a size listed in their application guide.... (and pretty much exactly the size I'd like to have). Do you have an aftermarket header?
Old 11-12-2009, 11:55 PM   #12
mofugga
Member#: 19540
2000 old skool RS
BRP
yeah, i've got borla's. i believe it's this one WLBSF20XZ
Old 11-13-2009, 12:13 AM   #13
DougM
Member#: 799
2000 2.5 RS Coupe
Mitsubishi EVO IX
the bsf20xz is listed as the 24mm adjustable.. adn if you believe this here, they're saying that's 24/23.5~ish
good to know it mostly fits ... can't imagine their 27 would though
Old 11-13-2009, 11:09 PM   #14
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Nothing Special:
FSP/STX:
WRX Eibach Pro Springs from SPT
06 Front WRX Struts
07 Rear STi Inverted Struts
25 mm Tribeca front Bar
20-24 Whiteline Adj Rear set at 22
Cusco WRX Front Camber Plates rotated for max Caster and -2.5 Degrees Camber
Kartboy Front Endlinks
Kartboy original Rear Spherical Endlinks
All Diff, Trailing arms, Lateral link Bushings Replaced...
Very Neutral handling...
Bill
Old 11-17-2009, 11:56 AM   #15
gr8r rex
Member#: 155652
2002 PSM WRX
www.forced4s.com
I got a buddy real serious about building a fully competitive BSP STI over this winter. He is very up in the air about what kind of rates to run. For coilovers hes most likely going JRZ Pros but deciding on spring rates is the hard part.
So what do you guys think? Math wise, 900 front and 650ish rear should be good for weight distribution, but he was thinking around 900 all around to start off and work from there? Anyone have an idea? Or does anyone know close to what stompy was running?
gr8r rex is offline   Reply With Quote
Old 11-28-2009, 07:55 PM   #16
roadkil
Member#: 196623
excellent thread. anyone(cough, Jay, cough, Patrick) want to throw up their baseline ride heights and any geometry corrections(roll center, can you even do this in -SP?)
thanks- zach
roadkil is offline   Reply With Quote
Old 11-28-2009, 11:30 PM   #17
Storm
Member#: 5218
96L Most Over-
Developed Beater
Can't measure from the fender lines anymore.....they're not exactly stock. Start with the control arms a little shy of being flat (hub ends lower than chassis ends) and go from there.
Can't do roll center adjustments in SP, but you can make something reasonably good if you don't slam the car too much.
Jay
Old 11-29-2009, 02:28 AM   #18
bdi
Member#: 66033
05 STi
This is a better place to get your question answered:
http://forums.nasioc.com/forums/show....php?t=1193491
bdi is offline   Reply With Quote
Old 12-11-2009, 12:28 AM   #19
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
I've got a WRX wagon, which I believes shares the GC/GM/GF track width up front. The 27mm Whiteline bar does work out for me width-wise with spherical endlinks and using my advanced degree in washer stackology. But, I don't know how header clearance would work out for you guys.
flyboymike is offline   Reply With Quote
Looking for a temporary setup in my GC/GM darksc00by Interior & Exterior Modification 3 10-23-2007 10:26 AM
Ultimate GC/GM Autocross suspension speedyHAM Brakes, Steering & Suspension 7 06-14-2006 11:39 AM
Help a noob. How close will my suspension setup be to a stock WRX wagon-GC (FWD) pittkid333 Brakes, Steering & Suspension 1 04-04-2004 10:05 PM
FS - GC/GM Aftermarket Suspension mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 1 03-12-2003 01:23 PM
GC/GM E-Manage info BOY Engine Management & Tuning 29 12-16-2002 03:25 PM
