Old 09-21-2009, 10:25 PM   #1
Taras
Member#: 146018
Default Replacing starter on 2001 Outback 2.5
Hey everyone! Going to be replacing friends starter on his 01 outback. I looked at it and it looks like its very easy to get at. Its on the driverside right at top just below the airbox. Are there potential surprises that i might be faced with when doing this job? How many bolts are holding the starter, just 2?
Thanks, Taras
Taras is offline   Reply With Quote
Old 09-21-2009, 11:07 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Two bolts on the starter. One nut on the wire. And one plug on the other wire. You can do it without removing much more than the airbox.
Old 09-21-2009, 11:36 PM   #3
Taras
Member#: 146018
sweet, thanks.
Old 09-21-2009, 11:37 PM   #4
Taras
Member#: 146018
do you know how much a dealrship would usually charge for this kind of job?
Old 09-22-2009, 02:22 AM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Originally Posted by Taras View Post
do you know how much a dealership would usually charge for this kind of job?
Waaaayyyyyy too much. You should be able to do it in 15-30 minutes with normal hand tools.
Old 09-22-2009, 06:37 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
Thin wrists and double joints are helpful in getting the bottom one out, but it's not a difficult job by any means.
Jay
Old 09-22-2009, 08:15 AM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Jay
Sometimes, putting the car up (jackstands, ramps) allows doing the bottom bolt from underneath.
Also, sometimes the bottom one is a nut on a stud, NOT a bolt.
Old 09-22-2009, 08:52 AM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
On a 2001 it will be a bolt. That's an 8 bolt engine/transmission assembly.
Old 09-25-2009, 07:55 PM   #9
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
You just HAD to say that, didn't you.
HAHAHAHAHA...ROFLMAO.....
I guess I need to work on more newer Subarus.
Old 09-25-2009, 09:51 PM   #10
quicklook2
Member#: 219662
2000 legacy gt ltd
disconnect the battery FIRST before messing with the starter.
quicklook2 is offline   Reply With Quote
Old 09-26-2009, 11:36 AM   #11
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
dont drop it on your face if you do it from underneath
moogoob is offline   Reply With Quote
Old 09-26-2009, 02:11 PM   #12
WagonMafioso
Member#: 222641
OUCH!!!!!!!!!
WagonMafioso is offline   Reply With Quote
Old 10-06-2009, 09:30 PM   #13
Taras
Member#: 146018
i did it. Was super easy. Instead of jacking up the car i just tied a rope around it and lowered the old on on the ground. The new one went in the same way with a rope.
The sad part that after i put it in the car started and 10 minutes late it would not start. I figure the problem was that the starter was not getting enough juice. The owner of the car changed the battery with thinner terminals so he had to change the terminals on the wires and did a really ****ty job. He did not crimp or solder the wires. The metal part of the wire was almost not touching the terminals. So it was not even the starter that was causing the problems. I got 80 bucks for just about an hour and 15 minutes of work.
Old 10-07-2009, 05:27 PM   #14
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Good for you!
Wanted:Cat for 2001 Outback 2.5 Automatic mclmk8d Private 'Wanted' Classifieds 0 05-19-2010 11:03 AM
2001 Impreza 2.5 RS Axel replacement-Will WRX ones work? JamesNUTT General Community 5 09-21-2009 06:48 PM
2001 RS 2.5 sideskirt on 02 WRX? elsuicida Interior & Exterior Modification 1 03-24-2009 10:06 PM
Huge Blow Out Sale On Oem Parts For 2000-2001 Impreza 2.5 Rs spudnyo Private 'For Sale' Classifieds 5 11-04-2005 09:53 PM
ABS light on 2001 Impreza 2.5 RS salaki Texas Impreza Club Forum -- TXIC 15 05-15-2002 10:19 PM
