Alaskan Impreza Club
Old 09-22-2009, 02:44 PM   #1
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
Default I have a problem...
Ok...Im having a drivetrain issues with my front axle/bearing/hub? Now I can drive normal, go through all the gears and do full turns right and left. But whenever im in the higher rpm and try to mash it...It goes for a few hundred rpms then cuts power to the ground...Not engine power. NO power gets to my wheels...I dont believe its my clutch as it doesnt bounce of the rev limiter when i floor it in 5th nor does it feel like it is slipping when I pull off from a stop. Just seems to have a total loss of power that gets to the wheels.
I had a bad cv on my pass thinking that was the problem. changed it last night and problem still there.
My driver side hub bearings are on the way out and I believe my driver side axle is still good.
My only thought is the splines on the axle or hub (driver side) are smoothed down to where itll catch with a small amount of power given ,but with a lot itll just slip and not do anything?
stumpedd n confused...dont wanna spend money on things I dont have to, cause i don have any..
Obvious is a new bearing and maybe a new hub?
Marlons101 is offline   Reply With Quote
Old 09-22-2009, 03:10 PM   #2
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
clutch is still your best bet. 9/10 clutches only slip under hard acceloration and moderately increase revs. Marlon I'll take a looksy for you tonight pm me for my # or get it from turbopedobear
greenspeed is offline   Reply With Quote
Old 09-22-2009, 03:30 PM   #3
Hi-Speed Solutions
Vendor
Member#: 143099
2008 AW STI
Rockin' the hatch!
most likely the clutch, are you hearing any noise when its happening? any kind of metal on metal squeal, things like that?
Mike
oh and if you think you destroyed the splines then you need to dump that gear oil asap before it causes a real problem with the rest of the tranny, like getting into the diff's, which more then likely its already in the front one if the splines are chewed up
Hi-Speed Solutions is offline   Reply With Quote
Old 09-22-2009, 04:00 PM   #4
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
yes the bearing on the driver side squeals when turning only. when aimed straight, theres no sound. Im not leaking any fluid from the trans or any of the axles. But I think the splines on the outside of the axle are toast...the ones in the hub where the bearing is... Im just going to get a hub from a JY and see what happens with that...
Old 09-22-2009, 04:00 PM   #5
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
also ive been through 3clutches and this problem is way different.... very confused here.
Old 09-22-2009, 04:17 PM   #6
missiceblast
Member#: 142304
are all your lugs tight?
missiceblast is offline   Reply With Quote
Old 09-22-2009, 04:27 PM   #7
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
before you do that just pull the tire and pop the ball joint to pull out the axle , and look at the splines, if there toasted your not gonna want to keep driving on it anyhow
tribalwrx is offline   Reply With Quote
Old 09-22-2009, 04:30 PM   #8
tribalwrx
Member#: 32993
vf39 Best trap 110
you know what you may not have to even do that, put that tire in the air and see how much play you got at the end
Old 09-22-2009, 05:11 PM   #9
AK SloPok
Member#: 56464
12 Ram
I had a similar problem when I blew my rear axle. The car would drive fine but under any acceleration the engine would spin and I wouldn't go anywhere. The limited slip rear diff and center dif would allow forward movement but it was delayed. My axle looked fine, however the "ball retaining cage" was shattered.
AK SloPok is offline   Reply With Quote
Old 09-22-2009, 06:56 PM   #10
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
ya, I think I will just go ahead with a new hub n bearing...as there is forward side to side backward, all of the above movement in the wheel... but, I guess I would need to pull the hub to see if the axle is still good? but my problem sounds exactly like yours chad
Old 09-22-2009, 07:23 PM   #11
tribalwrx
Member#: 32993
vf39 Best trap 110
yeah definately check that axle to be sure its not fubar
Old 10-06-2009, 05:23 PM   #12
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
okay...the problem was a collapsing hose...I wasnt looking at the boost gauge when the problem happend untill after I fixed my hub and the problem was stil there...peeked under the hood and the aftermaf hose was folded up lol...soo changed out the stock box and put a cai. Problem solved.
Old 10-06-2009, 05:35 PM   #13
Brando5185
Member#: 189926
2006 GC 5.7L
Glad to hear you got it fixed.
Brando5185 is offline   Reply With Quote
Old 10-06-2009, 05:51 PM   #14
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Aspen White, WRB interior
Yessir...Now should be rompin people!! Glad I had your fix. No homo!
coqui2004miguel is offline   Reply With Quote
Old 10-06-2009, 06:37 PM   #15
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
Had my car done on Saturday, tried to take it out to break it in and had a similar problem... turned out I had a bad front axel. Replaced the axel yesterday and all is right in the world.
Racer Dubya is offline   Reply With Quote
Old 10-06-2009, 08:17 PM   #16
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
damn thas no good. I got a spare axle in my trunk lol....glad you got it fixed though...
i have a problem today and it should have been an awesome sight 949 Tire & Wheel 21 03-31-2007 01:23 PM
1st gear problems. Anybody else have this problem? Travis Graham Transmission (AT/MT) & Driveline 4 04-21-2006 06:28 PM
Still Having a problem... anyone have any ideAS??? carguyx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 09-03-2004 11:46 PM
('93-'01) anyone ever have this problem starting your RS? IMPRZME Impreza Forum 7 05-09-2001 01:02 AM
('93-'01) Houston we have a problem! SuBart Impreza Forum 7 04-30-2001 06:51 PM
