Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 09-22-2009, 09:42 PM   #1
street_racen_va
Member#: 222488
2003 WRX Sedan
black
Default Oil line issues!! PLEASE HELP!!
Hey guys, so i just purchased a vf39 turbo and it didnt come with a oil return line. so my question is will the stock turbo oil line work with the vf39 turbo?
My second question is, if I install the new turbo will i need a new boost controller solenoid?
street_racen_va is offline   Reply With Quote
Old 09-22-2009, 10:15 PM   #2
Haelan
Member#: 151045
2013 Subaru STI
CBP
Stock oil return line should be fine...
Your second question is actually quite scary...I hope you know what you're doing.
Haelan is offline   Reply With Quote
Old 09-23-2009, 12:30 AM   #3
street_racen_va
Member#: 222488
2003 WRX Sedan
black
im just trying to make sure i dont mess anything up. Ive done a lot of research but It seems like everytime I read about the solenoid i tend to get different answers.
Thanks for the feed back on the oil line.
Old 09-23-2009, 12:36 AM   #4
Haelan
Member#: 151045
2013 Subaru STI
CBP
Stock solenoid should be fine, but you need to get tuned for your setup or at least use an OTS map. People use aftermarket solenoids to decrease spool time or cut down on wastegate duty cycles (prolonging the life of the solenoid). Changing solenoids means a custom tune to include the new device's characteristics, which are different from stock.
It all depends on what you want out of your setup.
Old 09-23-2009, 01:22 AM   #5
street_racen_va
Member#: 222488
2003 WRX Sedan
black
Thanks for the input! I have an accessport and I'm getting it tuned as soon as everythings bolted down. Machv motor sports is actually not to far from here so I'm gonna have them tune it.
Oil Line Part Number Help cynet2k Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-02-2009 12:05 PM
Broke hard oil line to turbo...HELP! SupraScooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 12-31-2004 09:58 AM
UTEC/USB Interface Issues - Please Help T-WRX Engine Management & Tuning 18 12-09-2003 04:30 PM
5MT SVX....clearence/balance issue please help 5spd Alcyone Transmission (AT/MT) & Driveline 10 04-10-2003 10:42 PM
Sti Injector issue please help WRC WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-01-2003 01:45 PM
