Old 09-22-2009, 08:42 PM   #1
cthor
Member#: 202584
04 Impreza STi
Default Mysterious hose?
After looking at my engine, i found this hose loose. The engine is an 07wrx. Can you help me locate where it goes? I looks at the surrounding areas and cant find a disconnected fitting. This was after I did my inlet install. Thanks
cthor is offline   Reply With Quote
Old 09-22-2009, 09:22 PM   #2
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Crankcase vent?
09rexwagon is offline   Reply With Quote
Old 09-22-2009, 09:28 PM   #3
sorrowfulkiller
Member#: 170439
I <3 Lamp
oh god you found jumbled mess of subaru's evap hoses.... I pity your soul, I hope you have small hands
sorrowfulkiller is offline   Reply With Quote
Old 09-22-2009, 10:09 PM   #4
cthor
Member#: 202584
04 Impreza STi
So where does it go?
Old 09-22-2009, 10:12 PM   #5
sorrowfulkiller
Member#: 170439
I <3 Lamp
not sure I took out all that crap
Old 09-22-2009, 10:37 PM   #6
cthor
Member#: 202584
04 Impreza STi
anyone know anything?
Old 09-22-2009, 10:57 PM   #7
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
If I'm correct, that hose should connect to a plastic vacuum fitting that comes off another hose or two that is tucked down below the jumble of hoses you can see in the picture, and slightly behind the alternator.
So down and behind.
Take a look with a flashlight. You'll see it.
I think that it ties into a vacuum control valve so you won't hear a vacuum leak with the engine running at idle.
Old 09-22-2009, 11:17 PM   #8
cthor
Member#: 202584
04 Impreza STi
damn...i may take the alternator off to do this...unfortunately my hands arent small...keep the suggestions coming...
Old 09-23-2009, 12:34 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d0000000000d....that is part of the evap emissions system and if ya **** that up you will have the CEL from hell
it looks like you are missing the little piece that connects the 2 hoses that are shown and you DO have a VAC leak from the one that goes to the manifold
Old 09-23-2009, 12:47 AM   #10
cthor
Member#: 202584
04 Impreza STi
I figured it out. It connects to a sensor under there....
mystery hose josedwrx Newbies & FAQs 1 05-20-2009 10:58 PM
Mystery hose disconnected, rough idle, P0457?? buccilli15 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-01-2008 10:23 AM
Mystery Hose Mitsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-22-2007 12:28 AM
Mysterious hose Ireneusz Subaru Conversions 6 01-15-2005 03:35 PM
Identify this mystery hose cheebus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-29-2004 08:57 PM
