Old 12-02-2012, 08:03 PM   #926
bridgestone24
Member#: 268817
2009 Stg 2+ HB WRX
What suspension and fender work is done? Looking at similar setup. Thanks!
bridgestone24 is offline   Reply With Quote
Old 12-02-2012, 09:29 PM   #927
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
GTWORX/Bilstein Impreza Cup Sport Kit
RCE Yellow Springs (in these pics)... RCE Black (Regular Guy) Springs now.
RCE Camber Plates (front)
Whiteline Rear Camber Adj. Bushings Kit
And lots of other stuff.
Rear fenders rolled. Front fenders pulled.
QwaktastiK is offline   Reply With Quote
Old 12-07-2012, 10:20 PM   #928
SlverEJ20
Member#: 157158
05 WRX stage 2
Does anyone know if drag sells touch up paint ? I was in a rush the other day while rotating my tires and dropped the spline drive socket on the lip. Now I have a pea size cheap on a set of wheels that were other wise spotless
SlverEJ20 is offline   Reply With Quote
Old 02-10-2013, 12:37 AM   #929
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
Hi, I just ordered 17x7.5 Drag Dr-21's . I do not like the center caps. Any suggestions on what I could use instead? Could I use honda caps and paint over them like you can with the RPF1?
Daddy_Digital is offline   Reply With Quote
Old 02-10-2013, 10:23 AM   #930
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Search for WRX or STI center cap decals on eBay. That's what I run.
Old 02-10-2013, 02:19 PM   #931
Daddy_Digital
Member#: 274205
World Rally Blue
No no no. You dont understand. I dont like the center caps AT ALL that come with the DR-21s. Putting a Subaru sticker over those caps would be like spraying perfume on feces.
Its pretty obvious I want RPF1s but dont have the $$ right now to get them. I dont even like the center caps the RPF1s come with. It is common practice for people who have a set of RPF1s, they use the Honda center caps because they fit. You sand them down, paint to match your rim and your ready. So, since the DR-21 is a replica of the RPF1, would the DR-21 have the same size center cap? I only ask because I Goolged for the answer 3 times and came up with nothing.
Old 02-11-2013, 12:14 AM   #932
wagon_war
Member#: 320092
02 WRX WAGON
Originally Posted by SkiWrex View Post
DR31 17X9 38 offset
215 54 R17
I love this setup Did you mean 215/45 not 54?
wagon_war is offline   Reply With Quote
Old 02-11-2013, 04:37 PM   #933
Daddy_Digital
Member#: 274205
World Rally Blue
I found a possible solution. Electrical knock out plugs. When my DR-21s arrive, ill see if they fit/work. Stay tuned!
Old 02-17-2013, 11:59 AM   #934
Redbolt04
Member#: 329226
2002 WRX Wagon
Drag DR-31 17x8 in bronze. Sitting on H&R springs. I see a little rub in the back but my wagon is suffering from a bit of saggy butt syndrome. I plan to get that lifted up before the drags go on again come summer.
This is the only decent pic I have of the drags on her.
Redbolt04 is offline   Reply With Quote
Old 02-20-2013, 12:32 PM   #935
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Bump! Going on this weekend! Agreed on hating the center caps...looking for a solution.
mechatricity is offline   Reply With Quote
Old 02-20-2013, 12:47 PM   #936
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Originally Posted by jura11 View Post
Here is our wagon with the Drag DR31 ET28 with Toyo R888 255/45 R17
Jura
Impressive. I see sedan front- i'm assuming you have a massive pull and quite a bit of camber in the rear?
Old 02-20-2013, 06:11 PM   #937
SlverEJ20
Member#: 157158
05 WRX stage 2
Sick wagon, whats its suspension setup?
Old 02-23-2013, 08:11 PM   #938
xsv141
Member#: 231904
2007 WRX
UGM
finally got the drags on 17x9 +28 235/45/17 wish i would of went with a 40 series tire but 45s will do for now... need to get little camber and roll the fenders
messing around with the tire cleaner at the car wash!
xsv141 is offline   Reply With Quote
Old 03-03-2013, 02:30 PM   #939
vto
Member#: 261641
2009 Impreza 2.5i
Got a set of DR-31's but the lug nuts I have do not fit, can anyone tell me what I can get for these, where I don't have to spend $60 for a set? thanks in advanced.
vto is offline   Reply With Quote
Old 03-03-2013, 03:58 PM   #940
predent
Member#: 171606
2006 Saab 9-2X Aero
Try finding a used set in the classifieds or maybe ebay... I wouldn't cheap out too much on lug nuts though.
$60 isn't expensive, you gotta pay to play.
predent is offline   Reply With Quote
Old 03-03-2013, 04:28 PM   #941
Daddy_Digital
Member#: 274205
World Rally Blue
Drag DR-9, 17x8 w/ 235/45/17 tires. Plasti dipped Blaze (Neon) Green.
Old 03-03-2013, 04:33 PM   #942
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
That green is amazing.
Old 03-03-2013, 04:40 PM   #943
Daddy_Digital
Member#: 274205
World Rally Blue
^^ thanks! i was really surprised how well the color came out. i dont even like the color green. actually, my son had suggested the color choice.
Old 03-03-2013, 09:53 PM   #944
vto
Member#: 261641
2009 Impreza 2.5i
Any brand or model you suggest that will fit?
Old 03-03-2013, 10:05 PM   #945
Juniorsabc
Member#: 348861
03 wrx
midnight blue
dr 33
Juniorsabc is offline   Reply With Quote
Old 03-03-2013, 10:57 PM   #946
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
http://www.wheeldude.com/catalog/ind...?cPath=176_226
McGard Spline Drive Lugs
Old 03-03-2013, 10:59 PM   #947
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Neon green goes so well with WRB. If I could do it all over again I might get WRB just to run Green wheels.
Old 03-04-2013, 12:12 AM   #948
Daddy_Digital
Member#: 274205
World Rally Blue
The neon green is definitely turns a lot of heads.
Old 04-05-2013, 04:45 PM   #949
Daddy_Digital
Member#: 274205
World Rally Blue
I dont like the center caps that came with my drag wheels. Does anyone knos of what caps can be used instead? i had DR-9s.
Old 04-05-2013, 07:50 PM   #950
SlverEJ20
Member#: 157158
05 WRX stage 2
to use the 5X100 holes you have to use spline drive lug nuts
The Official Wheel Thread. Teh Legacy Legacy Forum 33 10-30-2016 04:14 PM
The wheel thread aakrusen Member's Car Gallery 94 03-08-2016 08:35 PM
The Colored Wheels Thread WRXSIG Member's Car Gallery 2882 03-08-2015 06:34 PM
The BBS Wheel Thread CTI-Distributing Wheels/Tires 7 02-17-2005 09:23 PM
The Gold Wheel Thread adam555 Member's Car Gallery 39 03-05-2004 03:15 AM
