Old 09-24-2009, 09:33 PM   #1
ajg10730
Member#: 219334
Unhappy Motor wont turn on need help
I have a 02 bugeye and just finished my motor swap today and my motor won't crank. I checked the fuel and it is circulating fine I also changed the fuel injectors, and new spark plugs. The Fuel is fine. The motor sounds like it wants to turn on but it dosn't crank, it almost did today but it turned of after 5 sec. My check engine light is on. And people have been telling me the timing could be off. Can this be the problem any suggestions would help alot thanks.
ajg10730 is offline   Reply With Quote
Old 09-24-2009, 09:46 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
oh dear me......
Old 09-24-2009, 10:41 PM   #3
Krems
Member#: 198624
06 tr
UFTS-YEH
holy ****ing run on paragraph
Krems is offline   Reply With Quote
Old 09-24-2009, 11:06 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
with spelling/grammar like that, no wonder you can't get a complex machine to run. There are many threads on non-starting engines, start your search by, well, searching.
Old 09-24-2009, 11:22 PM   #5
ajg10730
Member#: 219334
well im not writing an essay so give me a break just in a hurry and im being lazy and just dont care i just need to know what can be the problem
Old 09-24-2009, 11:30 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
ya wont last long, here
your car, either, I'm betting
Old 09-24-2009, 11:44 PM   #7
ajg10730
Member#: 219334
okay, I did the best I could on rewriting my thread. So could you guys plz help! I would really appriciate it. I love my car and I'v been having alot of bad luck since i got it. So please give me a break!!!
Old 09-25-2009, 12:24 AM   #8
Haelan
Member#: 151045
2013 Subaru STI
CBP
Buy a code reader and pull the codes. That's the obvious first step here...
Haelan is offline   Reply With Quote
Old 09-25-2009, 01:12 AM   #9
gilg2533
Member#: 35332
Me thinks you should have never tried to swap your own engine
gilg2533 is offline   Reply With Quote
Old 09-25-2009, 01:25 AM   #10
ajg10730
Member#: 219334
dude the engine was like that when I pulled it out. It had oil in the turbo and in the intake manifold. Taking out an engine and putting it back in its not hard. This motor came from a car that was flipped over i bought it for 700 bucks. If I get it to turn on it would be a steel and you now that its not blown because it turned on for like 5 sec and it turned off but it sounded healthy.
Old 09-25-2009, 03:35 PM   #11
spinningcain
Member#: 176490
2005 STI
Dude it could be a lot of things. What did you do with the em? What year did the motor come out of?
spinningcain is offline   Reply With Quote
Old 09-25-2009, 05:04 PM   #12
gilg2533
Member#: 35332
If an engine is sooo easy to swap why doesnt it run?
Old 09-25-2009, 05:42 PM   #13
penusai
Member#: 102808
1995 Built EJ207 6sp
30r ***break in***
easy to swap, but hard to get started =)
Ok, so you have a 2002 wrx according to your profile.
did you swap in a 2.5 short block? 2.5 long block?
If yes, what EM are you using? is there spark?
a 2.0 short block? 2.0 long block?
Double check grounds, etc.
Also, you bought a motor from a rolled car, and didn't bother to check timing on the motor?
Yeah $700 is a STEAL, not steel. but if the timing is all screwed up, you just lost out on $700.
penusai is offline   Reply With Quote
Old 09-25-2009, 09:02 PM   #14
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Back to basics first.
You said there is fuel, now check for spark. The third item is air...but that usually isn't the problem.
Next, as someone said, get a code reader and see what it is telling you. Just in case you didn't know, the CEL is always on if the car is on, but the motor is not running.
Third, deal with and codes you have thrown. Also, check the battery voltage. It may just be dead from being old, or sitting, or from numerous failed attempts at starting the motor.
After all that, then get into taking off the timing covers and being sure the marks were aligned. Was the flipped car bumped in the front at all?
There's more to do, but that is a start.
CKxx is offline   Reply With Quote
Old 09-26-2009, 12:34 AM   #15
ajg10730
Member#: 219334
Thanks dude yea its a 2.0 we have spark cause i just got new spark plugs. And i checked to see if it was sparking. The ground is fine. Believe me we have tried everything now i think its the timing so tomorrow I am going to check it out and if its not timed Ill time it & see what it does. (The motor didn't start on the car it was originally from but a engine has to start even if it has knock well at least my other one did.)
Old 09-26-2009, 12:37 AM   #16
ajg10730
Member#: 219334
Well if it's not timed I will time it. The motor almost starts. sometimes it starts for like 2 sec and turns off but its a good motor I can hear that it has potential. (It's a 2.0 going in a 02 bugeye.) Just a regular motor swap. Stock Em.
Old 09-26-2009, 04:00 AM   #17
penusai
Member#: 102808
30r ***break in***
so you bought a motor that wasn't starting in another car...
swapped it into your car...
having trouble starting...
so yeah, check the timing...
if its off, let us know how many teeth on whichever side, etc.
Old 09-27-2009, 02:33 PM   #18
ajg10730
Member#: 219334
So it turned out that my timing is way off. I pulled all the information so I am going to start on it today with a friend. Thanks for all the help can't wait to start up my car for the first time.
Old 09-28-2009, 11:36 AM   #19
KnifeyMcShanker
Member#: 193874
2003 Impreza WRX
Sonic Yellow
Good Luck, pray for no bent valves...
KnifeyMcShanker is offline   Reply With Quote
Old 09-28-2009, 11:52 AM   #20
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Hopefully there are not valves that got tweeked during your starting attempts!!!
dangerousatom is offline   Reply With Quote
Old 10-01-2009, 02:58 PM   #21
ajg10730
Member#: 219334
Everything turned out good the car started and it sound's great. Thanks everyone.
Old 10-01-2009, 06:32 PM   #22
mikebdubsuby
Member#: 209195
2004 Impreza
SRR
Congrats!
mikebdubsuby is offline   Reply With Quote
abs light turning on need help!!!! pearlwrx Newbies & FAQs 3 05-15-2009 12:16 AM
need help asap: brake lights wont turn on snipe99 Electrical & Lighting 3 04-18-2007 09:40 AM
fuel pump wont turn on after motor install. oldbluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-15-2005 12:01 PM
Car starts but wont stay on... need help mofoporn Service & Maintenance 2 02-24-2004 01:36 PM
