Old 09-25-2009, 06:48 PM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default Dailydevil dynoes does decent on Mustang dyno.
Dynoed today.
On a Mustang dyno (GP MOTO here in Portland, basically a privately owned dyno), 21psi netted me 294 whp, 300 torque. At 15 psi on the Mustang I did about 245/250. I compare this to the 292/298 I put down on a dynojet at 15 psi.
Sorry, no dynograph.
The good thing is I was safe in the tune, and the 292 whp was FLAT from 5000 rpm to 6500.
I do have a crapload of blowby. But car runs well and doesnt smoke just driving around. Will be trying to go out to PIR 2nite and see what happens. If I can't break 13.3 I am gonna shoot something...
Oh yeah, the ever important mods.
1990 Legacy wagon
2.5 NA block
100mm Mahles
twinturbo heads
Borla header with custom up and down pipes, 2 1/2 and 3" exhaust
NA intake manifold
8000cc sidefeed injectors
Blow through Modded JECS MAF
EBAY T3/T4 turbo
BigAss FMIC
Greddy TRUST manual boost controller
6puck disk and 550torquepressure plate
Tuned with PerfectPower6 (PP6)
Old 09-25-2009, 07:01 PM   #2
penusai
Member#: 102808
1995 Built EJ207 6sp
30r ***in progress***
should be fine. at 245whp on a Dyno Dynamics, higher reading than a mustang dyno, i ran a [email protected] with a 1.9 60ft.
penusai is offline   Reply With Quote
Old 09-25-2009, 07:37 PM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
man, you sure have gone through lots of motors and setups for < 300whp
No more supercharger?
And are you planning a serious turbo upgrade? 8000cc injectors should be good for a gt9000
Old 09-25-2009, 07:39 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
This is not the reddevil, this is the daily devil, the family wagon. The dailydevil has only lost ONE motor due to a sensor wire falling off under load. It had nothing to due with setup or tune. This setup has been the same (other than slowly improved) since day one.
Old 09-25-2009, 07:43 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
my bad. i thought u went through the stock motor, then another one.
is it like a 2.8L now with those 100mm pistons?
Old 09-25-2009, 07:46 PM   #6
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Hey, I wanted to come out to PIR tonight and run, but I have some plans from 8-10 or so. It is only Fridays right ? Is this the last weekend for the season or are there more ? I heard it gets pretty thin around 10 because of the noise. I wonder if I didn't tell them about the atmospheric wastegate if I could get a run in anyways..... hmmm.
UFOpilot is offline   Reply With Quote
Old 09-25-2009, 08:27 PM   #7
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Naw, this was built and installed last November. I lost two Mahle pistons when the PP6 wire came off the MAF signal line.... I simply replaced the two pistons.
IF, and a big IF, I was able to drive over and dyno on the dyno jet and get the same numbers as before (292/294 @ 15 psi), then the Mustange numbers equate to about 350/350 on the dynojet...... But only if the trap speeds 2nite support this. If I don't hit over 105, I am going to get pissy.
Old 09-25-2009, 08:40 PM   #8
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
The most inflated 294whp is definitely good for 12s. If you don't beat 13.3, it's not due to lack of power .
On a Dynomite dyno, with my stock 2.0/EvoIII 16g, I was making 265whp/268wtq, and it was good for [email protected], with a craptastic 1.8 60ft with a 12lb flywheel. You have a SOLID 12-sec car, whether the pass shows that or not
Audiosavvy is offline   Reply With Quote
Black on Black DMR STI 455 whp on mustang dyno turbo222 Member's Car Gallery 23 11-04-2008 05:04 PM
Latest dyno results: 145hp, 144ft-lb on Mustang dyno Patrick Olsen Normally Aspirated Powertrain 39 08-27-2008 03:19 AM
530whp-450tq WRX on Mustang dyno Las Vegas mycal Proven Power Bragging 282 10-04-2007 04:35 PM
276whp & 253wtq on Mustang dyno today =) Hunt3r Proven Power Bragging 12 09-28-2005 05:32 PM
04-05 stock sti #s on mustang dyno anyone 005sti Proven Power Bragging 7 03-30-2005 08:48 PM
