Old 09-26-2009, 05:31 PM   #1
MrMakesitRain
Member#: 168333
2006 STi
CGM
Default HID Retrofit Problem, OEM Ballast, OEM bulbs, PNP Wiring Harness.. Please help
So I purchased a set of bugeye retrofits with infiniti fx35 projectors. everything wired up easily with the pnp harness but my low beams and high beams were switched on the stalk and the highbeam indicator would always be on (it would be high beam when i was on low beam and it would be low beam when i switched to high beam on the stalk)
Anyways I heard that the pins on the plug might be switched
and it should be blue brown white instead of white brown blue. One is +12v, and the other two are the high beam ground and low beam ground
So then I switched the pins around and now on my low beam my high beam comes on and I have no light output at all when i switch to high beam on the stalk and when i engage the foglight switch during lowbeam the highbeam indicator turns on.
any ideas of what the problem can be?
MrMakesitRain is offline   Reply With Quote
Old 09-27-2009, 12:13 AM   #2
02boxer
Member#: 139853
2002 wrx....its tsxy
I can't for the life of me remember which goes where. I had a similar issue when I did mine. I'd say get a mulitimeter and test which wire is which on the car side plug and reset the lamp side pins accordingly...thats pretty much what I did. I wish I could help more.
chris
02boxer is offline   Reply With Quote
Old 09-27-2009, 12:42 AM   #3
bend_bugeye
Member#: 210459
'03 WRX 2.5 20G
You need to disconnect the DRL under the glove box if you are running HIDS. Wire your harness back like it was and check out this thread http://forums.nasioc.com/forums/show...079&p=10997214
bend_bugeye is offline   Reply With Quote
Old 09-27-2009, 01:01 AM   #4
MrMakesitRain
Member#: 168333
2006 STi
CGM
i've disconnected my drl through the glove box a long time ago, maybe ill try disabling the other one. turns out how they were wired was correct.
Old 09-27-2009, 02:11 AM   #5
bend_bugeye
Member#: 210459
'03 WRX 2.5 20G
Are your fog lights on? After I did my retrofit and had the fog lights on caused very similar issues to what you are experiencing. If that is the problem you will have to do the fog light mod by bypassing the fog relay.
Old 09-27-2009, 02:20 AM   #6
MrMakesitRain
Member#: 168333
2006 STi
CGM
my foglights do not work at all. when you switched the fog to power up independently did it fix the mixed up high/low beam problem?
Old 09-27-2009, 02:22 AM   #7
bend_bugeye
Member#: 210459
'03 WRX 2.5 20G
Yeah worked perfectly after that.
Old 09-27-2009, 02:35 AM   #8
MrMakesitRain
Member#: 168333
2006 STi
CGM
nice, i read about it but can you describe to me the procedure you went through to do it?
Old 09-27-2009, 02:52 AM   #9
bend_bugeye
Member#: 210459
'03 WRX 2.5 20G
Old 09-27-2009, 02:31 PM   #10
MrMakesitRain
Member#: 168333
2006 STi
CGM
i just did the mod. I have function of my foglights now which is great but my high beam and low beams are still switched. Any other ideas? If I can't figure this out i'm going to just electrical tape the high beam indicator on the gauge cluster and run the stalk switched.
Old 09-28-2009, 09:32 PM   #11
MrMakesitRain
Member#: 168333
2006 STi
CGM
bump
HID light went out: Ballast or Bulb Fatguy1069 Electrical & Lighting 6 12-10-2008 03:04 PM
Wiring Harness Hell - help please Fitz New England Impreza Club Forum -- NESIC 19 04-05-2007 02:23 PM
Help with head unit wiring harness please kogs Car Audio, Video & Security 4 08-04-2006 10:44 AM
PnP wire harness ATERYU Electrical & Lighting 9 10-28-2004 07:44 AM
PnP wiring Harness for EDM & JDM STi Projector Headlights tsn97 Private 'For Sale' Classifieds 5 01-27-2004 12:41 PM
