Old 09-27-2009, 09:52 AM   #1
digitalmethods
Member#: 33734
2002 used to be cool
02' Snow donkey FTL
Default P0065 and P0328 question.
I have a 2.5ts wagon that just had a head gasket replaced. The car has almost 145k on it. I noticed that I was getting some hesistation just after I had it done in the throttle and it seems to be pretty bad now. I see the PDF's that have been posted for the P0065 code (which was an air asist injector solenoid). I am almost leaning toward a clogged injector though. I have tried searching but those PDF's aren't helping me locate the air assist valve. I have a hard time reading the wiring diagrams. Any thoughts on what it might be? The P0328 code is a knock sensor which lead me to think it may be a clogged injector.
digitalmethods is offline   Reply With Quote
Old 09-27-2009, 11:48 AM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
did you reset the ecu after work was done?
Old 09-28-2009, 10:15 AM   #3
digitalmethods
Member#: 33734
02' Snow donkey FTL
Yeah I reset the ECU and it came right back on. The car has a slight stutter in the throttle so I'm leaning toward clogged fuel injectors. I'm not really sure where that air assist injector solenoid is or what it is.
Old 10-08-2009, 07:22 AM   #4
digitalmethods
Member#: 33734
02' Snow donkey FTL
The soleniod was located and tested but seems to be fine. Today I'm going to try and pull the plugs to see if I can locate the the cylinder that may be dry. I have a feeling a clogged injector is the issue because of the unmistakable stutter and power loss. I'll keep you guys posted in case anyonw else comes across this issue in a high mileage car.
Old 10-20-2009, 12:42 PM   #5
digitalmethods
Member#: 33734
02' Snow donkey FTL
I pulled the plugs and they seemed to be the issue here. I also had a knock sensor that needed a little tighten.
P0065 and P1507 Darkmuzzle Service & Maintenance 3 07-25-2008 06:30 PM
throwing P0172 and P0328 on EJ25 (2002 2.5TS) 02GD_Wagon Normally Aspirated Powertrain 12 04-17-2008 03:18 PM
P0065 and reflash subiebosch Normally Aspirated Powertrain 3 12-06-2007 07:33 PM
2001 2.5RS CEL: P0328 Question sonicsuby Normally Aspirated Powertrain 2 10-29-2006 07:16 PM
OL/CL delay and P0328? Parsons Engine Management & Tuning 3 08-08-2006 10:52 PM
