Welcome to the North American Subaru Impreza Owners Club Wednesday August 20, 2014
Alaskan Impreza Club
Old 09-27-2009, 04:12 PM   #1
SubLine
Member#: 131962
02 impreza
95 impreza
Question Help clutch replace
Need some info on how to take apart the tranny from the motor is there a trick ??
SubLine is offline   Reply With Quote
Old 09-27-2009, 06:39 PM   #2
suby_do
Member#: 154711
1997 swap rotated
ppg impreza L
are all the bell housing bolts out? use a pry bar between the subframe and the front diff. my tranny wont slide off the studs unless i do that.
suby_do is offline   Reply With Quote
Old 09-27-2009, 06:55 PM   #3
polish man
Member#: 200087
01 IS 300
99 cbr f4
hammer and chizzel or flat screw driver
polish man is offline   Reply With Quote
Old 09-27-2009, 06:58 PM   #4
Brando5185
Member#: 189926
HEMI Jeep GC
06 R1 50th Anniv.
More gym time?
We had to use a pry bar and rock it to get it to break loose I think.
Brando5185 is online now   Reply With Quote
Old 09-27-2009, 06:59 PM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Did you remove the clutch fork pivot?
Old 09-27-2009, 07:59 PM   #6
kbeefy
Member#: 197417
no more subaru
mostly dirty
x2 DON'T pry it off before that.
On mine it was on the drivers side towards the top of the tranny, recessed (10mm allen I think) screwed into the side.
kbeefy is offline   Reply With Quote
Old 09-27-2009, 11:44 PM   #7
SubLine
Member#: 131962
02 impreza
95 impreza
thanks for the help guys i got that allen plug out now what am i suppose to do??
Old 09-28-2009, 12:51 AM   #8
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
take one of the bolts out of the timing belt cover and and screw it in the pin that is behind that 10mm allen plug and pull and wiggle the pin out, sometimes someone need to wiggle the clutch fork at the same time. then you can pull the tranny apart,
Alaskan EJ20 is offline   Reply With Quote
Old 09-28-2009, 12:54 AM   #9
kbeefy
Member#: 197417
no more subaru
mostly dirty
I used a bolt that was holding down my coil-pack.
Clutch replacement help Agkelos Transmission (AT/MT) & Driveline 20 09-03-2005 09:27 PM
Asking for help.....4/17.....clutch replacement/ mini install day in Canton WRXtasy! Mid West Subaru Owners Club Forum -- MWSOC 59 04-19-2005 10:46 PM
Help. 96 L - Clutch replacement - Confused. Hitokiri Transmission (AT/MT) & Driveline 6 10-19-2004 01:08 PM
Clutch replacement help wolf8314 Mid Atlantic Impreza Club -- MAIC 5 06-20-2004 01:40 AM
Next Garage Day Project....Help me replace my clutch fastfood New England Impreza Club Forum -- NESIC 21 05-15-2003 09:49 AM
