Closed Thread
Old 09-27-2009, 10:20 PM   #1
gomba
Member#: 218439
Default STI Yellow Side Feed Injectors -- Flow Rate?? A Mystery it seems..
Hello All,
I am trying to find out what the flow rate is for the STI yellow side feed injectors that were on the '04-'06 STIs I believe.
Some people think it's 565cc and others think it's 520cc and others some other number. Does anyone know the real flow rate @ 3 bar on these?? I can't find any concrete information anywhere.
Thanks!!
gomba is offline
Old 09-28-2009, 11:30 AM   #2
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
I had mine flowed by both RC Engineering and Witchhunter.
RC reported around 520cc.
Witchhunter reported around 500cc.
t
WolfPlayer is offline
Old 09-28-2009, 11:44 AM   #3
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
t
The problem is different companies use different fluids to test them. I would go by witchhunters though.
2gnt2wrx is offline
Old 09-28-2009, 11:56 AM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I believe the scaling in the factory ROM is 503
the suicidal eggroll is offline
Old 09-28-2009, 03:12 PM   #5
gomba
Member#: 218439
So we have ratings from 500cc to 520cc
hmm, that range isn't too bad. So it's definitely not 565cc?
gomba is offline
Old 09-28-2009, 03:45 PM   #6
BenFenner
Member#: 223054
I too am very interested in the answer to this question. It would help me to know the real flow rate to make tuning with them easier on many levels. I've heard both ratings as well. Which is it?
BenFenner is offline
Old 09-28-2009, 03:52 PM   #7
R4ND0M_AX3
Member#: 67483
2005 WRX STi
Def not 565. 500 is close.
R4ND0M_AX3 is offline
Old 09-28-2009, 04:14 PM   #8
BenFenner
Member#: 223054
Anyone have any idea where the 565cc (or sometimes truncated to 550cc) number comes from? Is that what Subaru rates them?
Old 09-28-2009, 04:47 PM   #9
arch4life
Member#: 172588
2005 saab 9-2x sti
i've done alot of searching and reading on this subject, and after playing with my flow rate within my tune, i can say that yellow sidefeeds are NOT 565-550cc.
i've left them at the stock value, 503cc. works best, easiest to dial in maf scaling.
if your targets are off, change your maf scaling.
arch4life is offline
Old 09-28-2009, 07:18 PM   #10
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
bcblues is offline
Closed Thread
sti yellow side feed injectors, oem td04 turbo, oem wrx top feed injectors, etc. arrowscooby Engine/Power/Exhaust 57 06-25-2009 10:06 PM
STI Yellow side feed injectors Junior2JZ Engine/Power/Exhaust 1 01-26-2009 09:44 PM
Sti Yellow Side Feed Injectors Tripinray Engine/Power/Exhaust 0 07-07-2007 12:25 AM
stock sti yellow side feed injectors azn2nr Engine/Power/Exhaust 4 11-09-2006 01:55 PM
sti yellow side feed injectors 250 obo azn2nr RMIC Private Classifieds 5 10-03-2006 06:41 PM
