#76 |
Member#: 241881
AKIC
Vehicle:2013 P3 Import Auto Custom Tunes, Mods. |
Intermittent leaks will not show up always, especially if they may only happen during open loop fueling. Remember leaking BPV or failing BPV is already metered air getting recirculated.
Based on what I see here so far and the little I know about this car it seems the BPV is a possible issue. As I have mentioned I have personally had cars in the shop that would surge, shudder, and or hesitate when the BPV was doing something strange. If you look at whats going on during part throttle boosting its quite a balancing act. Intake turbulence from recirculating air can cause all sorts of fun things to happen. I'm not ruling out other possible issues, heck it could even be a damage turbine wheel. Who knows its hard to play doctor when your thousands of miles away...lol
#77 | |
Member#: 159325
Hesitation alway occurs:
- in Close Loop - light load 0.3-0.4 - Vacuum around -10 PSI - 2000-3200 RPM Once I go in Open loop, the car accelerate fine. Mart Quote:
#78 |
Member#: 241881
AKIC
Alright. Cap the recirc line from the BPV to the intake and cap the BPV. Lets rule this thing out. This test would take a few mins to do if you can find a cap for the end of the hose. While you have the hose off and the car running put you hand over the open end of the BPV and see if you feel any air being moved. At idle the valve should be shut.
Once you have the line capped off go drive around. Avoid excessive boost just try the areas you have the problems in. If the problems still exist I would visit the MAF. Swap with a known good one. Sometimes depending on the intake configuration you can get turbulence around the MAF sensor, swirling air , etc. This is why some people have had to put in air straighteners, screens before the sensor and other methods. I realize you have logged this and see nothing but you also have to remember that at low loads like this the computer will respond and could make decisions much faster then you can log it. One last thing...You can go into open loop at low loads as well depending on variables in the tune. Don't always assume your on closed loop especially if you zeroed the OL/CL delay tables. |
#79 | |
Member#: 159325
I will try the BPV trick.
I have swap with a working MAF, same problem. I have run without a MAF, same problem. I have run without a front 02, same problem. I have run without the rear 02, same problem I have developped a tool of my own monitoring important parameters and displaying it real-time talking SSM. That's how I know that: hesitation alway occurs: - in Close Loop - light load 0.3-0.4 - Vacuum around -10 PSI - 2000-3200 RPM thanx you for your input. Mart Quote:
#80 |
Member#: 241881
AKIC
Well it sounds like you have covered a lot of the bases then. If your able to log quickly I find in hard to believe you don't see something standing out while this is happening.
Did you try roughness monitoring on each cyl? Look for one that stands out and check plug, coil, and injector. If you can isolate a cyl then you just move the coil pack to a difference cyl and see if the roughness moves, then do the same with the injector as well. This method would help identify a leaking injector or bad coil back or even a plug. |
#81 | |
Member#: 159325
I cannot log faster than romraider ( 4800bauds limit) with my tool. My next project is to overwrite the baud rate in the ecu to help resolution. I got an ecu on my bench and I am only missing some times at this point. It has been done by Freon a little while ago.
I did log Roughness on each cylinder while hesitation and I had no hit at all. Mart Quote:
#82 | |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
This hesitation is a fairly common problem with stock Subarus. There are a bunch of threads about it on LegacyGT.com, those cars seem to be particularly prone to it. It doesn't happen to everyone, only a minority, but it happens often enough to stock cars that I don't think it makes sense to assume that the problem is or isn't mechanical in nature. I suspect that there is a mechanical aspect to it, just because hardware varies more than software... but not by much. Some people have claimed that the problem went away with a tune. However people have also reported that the problem came back after a while, which leads me to think that it just doesn't happen consistently enough for anyone to really know what's up. It's common enough that whoever gets to the bottom of this will gain instant fame. Almost makes me wish my car had this problem, just so I could really get to work on it. Last edited by NSFW; 08-17-2010 at 01:11 AM. |
#83 |
Member#: 159325
#84 |
Member#: 159325
I was about to pull the trigger on a Forge BPV but now I am confused
#85 | |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
I thought the MRP based fuel trim tables was curing it for most people? Get the MRP log done again Martin..... |
#86 |
Member#: 159325
#87 | |
Member#: 159325
A quick google search for "BPV Hesitation" gives several people claiming that putting a FORGE BPV cures their hesitation problems.... now is it true...
Mart Quote:
#88 | |
Member#: 241881
AKIC
I have tuned and worked on dozens of Subarus and have never run into this issue with a stock setup unless the stock valve was faulty or modified..Crushed BPVs do this as well. I notice your using learning view to determine fueling trims, keep in mind this is only an averaged snap shot. The short term trims are still applied on top fairly quickly but not enough to effect the long term averaged trims. Not sure if you have tried a log of just MAF volts but you may want to look for flat spots or signs of turbulence as I mentioned can also cause this. A swap with a stock air box may be worth the effort if you have not tried that yet. I think your problem will end up being a simple fix once you find it. |
#89 | |
Member#: 159325
I have logged MAF voltage and everything was fine. I swapped with another MAF with no changes at all.
I do run a stock airbox with a Perrin foam filter now (had a k&N before) the FORGE BPV... uhm... Mart Quote:
#90 |
Member#: 241881
AKIC
Before I spent the cash on a forge bpv I would buy a used STI valve from the forums. I have seen them for $25. Good luck and keep us updated.
#91 |
Member#: 159325
#92 |
Member#: 159325
that is right. Learningview is just another way to confirm that I have no leaks (unmetered air). I do notice a jump in the AF Correction when the hesitation usually occurs. Also, when I left the gas off and go back... I can clearly see that with my SSM monitor tool live.
Mart |
#93 |
Member#: 241881
AKIC
It would be rare unless it was modified. Most people pull them off working fine to replace them with after market ones.
One more thought, If you can get a wideband gauge (borrowed or bought) it would be interesting to see the fuel reading during the hesitation if you can keep it going for a long enough to read. |
#94 | |
Member#: 241881
AKIC
Which way does the correction go when you get the hesitation. negative or positive and how much. If you still in closed loop you can log the #1 O2 sensor and that will show a very accurate fuel reading. I find these cars are slightly delayed with the short term trims and they can trim after the event which then leads to a new event if the trim is nasty enough.
#95 | |
Member#: 159325
I do have an LC-1.
#96 | |
Member#: 159325
From what I recall, it is positive.
#97 |
Member#: 36033
SCIC
Mart, are you sure you're in closed loop? Your time delays are 0, so any pedal % should throw you into OL immediately.
Can you do a hesitation log and log the CL/OL parameter and all the fueling parameters. |
#98 |
Member#: 159325
From my live experience using my SSM tool (even with time delay to 0), you can stay in Close loop with light pedal input. There is more than that in the algorithm to makeit switch I believe.
#99 |
Member#: 159325
#100 |
Member#: 36033
SCIC
from my experience...even within the last couple weeks logging my neighbors 06 sti....you pretty much have to be at a constant throttle input....or coming down from say12% to 10% to be in CL.....if the throttle % is increasing it should kick you into OL pretty fast.
His car was going ol cl ol cl ol cl ol cl ol cl every second or two.....so if you're just glancing over at your ssm monitor you wouldnt really notice that |
| Thread Tools | |
| Display Modes | |
| FS : 06 sti trans | EmaciatedCow | Drivetrain | 14 | 06-04-2011 10:46 PM |
| 06 STI VACUUM Hesitation | Daluv | Factory 2.5L Turbo Powertrain | 16 | 09-09-2010 01:01 PM |
| FS: MS: 06 STi Silver BBS Wheels with tires | JAPSTi | South East Region Private Classifieds | 6 | 06-24-2010 10:19 AM |
| FS : 06 sti trans | EmaciatedCow | Tri-State Area Private Classifieds | 9 | 06-13-2010 11:08 PM |
| 06 sti throwing codes and hesitating badly | pints99 | Newbies & FAQs | 3 | 02-04-2008 09:51 PM |
