Old 09-13-2010, 03:05 AM   #151
guilty_619
Member#: 244075
2015 Honda Fit 6MT
'54 WILLYS CJ3B
hmm... keeping an eye on this thread. i have a 4eat wrx stage 2, mods include: invidia up-pipe, invidia 3" down-pipe, spt exhaust and spt intake with heat shield.
my car started to hesitate right after i got my stage 2 tune, just after i pulled out of the shop actually. didn't think anything of it at first, but then it started to occur more often (haven't contacted tuner about the problem). it only seems to hesitate in 3rd gear at 3,000-3,250. the rpm fluctuates rapidly between said rpm's for about a second or two, maybe longer, depending on how much throttle i put down. basically, the faster i accelerate, the less amount of hesitation i have. if i start from a stop and go full throttle, then switches into 3rd gear at higher rpm than normal, it doesn't hesitate at all. very weird.
if its in 3rd gear, under normal driving conditions (not going over 75% throttle) chances are it will happen. hopefully you guys can understand what i'm talking about, i kinda have a reputation for not explaining very well
if i remember anything else, i'll be sure to post. been thinking of posting a video of it, if that will give people some ideas.
guilty_619 is offline   Reply With Quote
Old 09-13-2010, 07:41 AM   #152
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Originally Posted by Phatron View Post
I tried various throttle mappings and I believe another tuner did also.
There could be a loose/bad ground somewhere causing voltage fluctuations to the ecu or through the pedal angle sensor wires.
Mart have u done a compression check? I just inspected a car and it had a lopey idle and hesitation and one of the cylinders was completely dead, compression was 0.
well what i was really getting at isnt the map itself but a small spot in throttle position where throttle voltage doesnt change or is incorrect. basically tps not reading correctly for throttle angle. i think no matter how much you play with your maps you would never tune it out. dont know if this has been ruled out but older outbacks are common for bad tps, but i dont think you can replace tps with DBW you have to replace whole TB assembly.
bswilmington is offline   Reply With Quote
Old 09-13-2010, 07:59 AM   #153
spec_bg
Member#: 226517
04 FXT dom1.5xtr
psm
is there a diagram that shows all the grounding points? i have a meter and ive cleaned the grounds that i could see and the one on the firewall.my hesitation seems to get worse when im low on fuel. it was doing it bad yesterday with quater tank. what about the avs like mentioned above?
again my idle is perfect and it starts right up
spec_bg is offline   Reply With Quote
Old 09-13-2010, 08:48 AM   #154
Daluv
Member#: 159325
nope, no compression test done. I guess it will be the next step.
The car under boost is as fast as any stage 2 STI... so compression should be good I guess...
Mart
Daluv is offline   Reply With Quote
Old 09-13-2010, 10:28 AM   #155
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
My partner was running 12.0's in his vf Sti with a cylinder that had cracked rings that was below 100 psi.
Old 09-13-2010, 10:30 AM   #156
Daluv
Member#: 159325
Ok, was it hesitating?
Mart
Old 09-13-2010, 12:32 PM   #157
Phatron
Member#: 36033
CEO PhatBottiTuning
my point was that the cars can run fine and make power with cracked rings.....in response to you saying "but it still makes power, so its probably not the rings"
Old 09-13-2010, 12:37 PM   #158
Daluv
Member#: 159325
understood.
Old 09-13-2010, 07:58 PM   #159
spec_bg
Member#: 226517
04 FXT dom1.5xtr
psm
man, i hope thats not the case. thats some money right there to have the motor rebuilt.
Old 09-13-2010, 08:35 PM   #160
Phatron
Member#: 36033
CEO PhatBottiTuning
i really doubt thats it as its been happening since 2500 miles off the lot...
try going through and cleaning all your grounds, subaru likes to ground on top of the paint, just take em off and sand off the paint
Old 09-13-2010, 09:32 PM   #161
spec_bg
Member#: 226517
04 FXT dom1.5xtr
psm
ive cleaned them already. most of them thread in .they should be getting good contact maybe not on the surface but the bolt should. im thinking its something tune based since between all of us we've pretty much changed all the parts that could have to do with fuel delivery. there's a bunch of threads on the forester forum about this issue.
Old 09-13-2010, 10:07 PM   #162
Phatron
Member#: 36033
CEO PhatBottiTuning
Try using this spreadsheet....many people have reported it to stop their hesitation
http://www.romraider.com/forum/viewt...hp?f=32&t=5483
Old 09-18-2010, 03:33 AM   #163
hatched91
Member#: 224630
2012 wrx
bump guys, 04 sti here, 95k miles. it's been hesitating for the last 4-5k miles. Tried everything the OP has, and still no fix. I agree with the consensus of it being a mechanical issue. My compression test was fine, and i'm still hesitating. I think it's an intake leak or a failing sensor. I will try to have someone log some data for me soon and post it up.
hatched91 is offline   Reply With Quote
Old 09-20-2010, 04:20 PM   #164
Snakebot
Member#: 61602
2004 STi
Originally Posted by Snakebot View Post
I have a different DBW throttle body that I'm about to try.
Just an update since I last posted.
I pulled the intake manifold/TGV and replaced all of the vacuum lines and gaskets with new ones. I also installed the spare (used) DBW throttle body that I had. I didn't replace any sensors.
The hesitation's still there. It doesn't consistently happen now. For example it didn't do it this morning but I noticed it a couple of times yesterday.
I guess the next step is to start replacing sensors one by one. Any suggestions on which one I should start with?
Snakebot is offline   Reply With Quote
Old 09-20-2010, 04:22 PM   #165
Daluv
Member#: 159325
Have you pressured tested the intake for leaks after everything was back on? If not, I would make sure I can hold pressure before doing anything else.
Mart
Old 09-20-2010, 07:42 PM   #166
hatched91
Member#: 224630
2012 wrx
possibly a smoke test? i'm going to try and have one done on my car. If you're unfamiliar with it, it's where smoke is injected into your intake. It will come out where ever there is a leak in your intake system.
Old 09-20-2010, 07:57 PM   #167
Daluv
Member#: 159325
even better but you still need to pressurized the system. A standard evap leak tester does not have enough pressure alone.
Old 09-20-2010, 09:13 PM   #168
hatched91
Member#: 224630
2012 wrx
true. don't just hook up pressure to your turbo inlet and go to town. there is a specific procedure so you don't blow out seals/grommets, etc. It's like 5psi for the inlet, and then only like 20max for intercooler to the heads. There are some things you have to remove, so be sure to read up on it BEFORE trying it lol
Old 09-21-2010, 12:42 PM   #169
Snakebot
Member#: 61602
2004 STi
Wouldn't the symptoms be different if the post tubo intake track wasn't holding pressure? Like not being able to hit boost targets? I haven't noticed a problem with hitting peak boost.
Maybe my logic is flawed but it seems to me that if there was a leak in the intake tract, the symptom would occur across a wider RPM range.
The hesitation I'm experiencing only occurs between 2500-3000 RPM, during throttle tip-in on light throttle application (> 10%) and off boost (boost gauge shows vacuum). There's no problem at other RPMs under the same conditions.
I've had a compression test done about 6 months ago and the results were normal. The idle vacuum is normal when checked at the brake booster port.
The problem has existed with two different motors, the stock motor and the current built (RAW Performance) motor. Three tunes, OTS AP, Opensource and AP ProTune.
Old 09-21-2010, 12:46 PM   #170
Daluv
Member#: 159325
My hesitation ALWAYS occurs pass -9.8PSI (vacuum)... light throttle... yours?
Old 09-22-2010, 01:54 PM   #171
Snakebot
Member#: 61602
2004 STi
Yup, I'm experiencing the hesitation at approx. the same vacuum level.
I can reproduce the problem pretty consistently by cruising at 2500 RPM in 3rd gear and slowly rolling in on the throttle and keeping the throttle opening low (~<5%). The car will hesitate, it feels like the ECU is pulling timing. The hesitation is gone by 3000 RPM.
However, I've only noticed the hesitation once or twice since I replaced the all of the vacuum hoses and manifold gaskets.
Old 09-22-2010, 02:01 PM   #172
Phatron
Member#: 36033
CEO PhatBottiTuning
Will all you guys please try this sheet and see if it works
Old 09-22-2010, 02:38 PM   #173
Daluv
Member#: 159325
I tried but it feels like it has "move" the hesitation or changed the way it occurs. I asked if it was an iterative process in the thread... maybe you need multiple iteration to dial it in perfectly.
Old 09-29-2010, 01:50 AM   #174
acjdmb18
Member#: 225734
hello guys i have a 06 sti and having the same issue for the last two days around 10psi vacum 2500-3000 rpm crusing and accelerating cant figure out the issue either
acjdmb18 is offline   Reply With Quote
Old 09-29-2010, 08:24 AM   #175
Daluv
Member#: 159325
Mileage? Mods? What have been done to try the cure the issue?
FS : 06 sti trans EmaciatedCow Drivetrain 14 06-04-2011 10:46 PM
06 STI VACUUM Hesitation Daluv Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 09-09-2010 01:01 PM
FS : 06 sti trans EmaciatedCow Tri-State Area Private Classifieds 9 06-13-2010 11:08 PM
06 sti throwing codes and hesitating badly pints99 Newbies & FAQs 3 02-04-2008 09:51 PM
