Old 09-28-2009, 01:15 PM   #1
WRXINTX
Member#: 96712
Default injector latency values between two different injector designs...
a few quick questions.....
1. What is the stock injector latency number for a 2004 Forester XT (same injector as STI Yellow tops) ?
2. If I switch from the old-style 850cc Helix Red Top Side feeds that my tune is currently for, and go to a modded yellow top flowing the same 850cc's, how much change can I assume will be needed on my tune aside from changing the injector latency values, because the flow scaling will be identical?
3. I can only assume that the injectors will obviously have different spray patterns and therefore will probably require a different tune across the fueling map, am I wrong?
4. I do have Wideband, and I will be watching it closely and tuning with only 12-13psi of boost for now, until I am confident in the fuel map....
WRXINTX is offline   Reply With Quote
Old 09-29-2009, 07:21 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
modded yellows?..deschtwerks?
if they are modded stockers there is an excellent write up
on them somewhere on here..search & they should pop up..
I would rather use the modded stockers than 850 red tops..
Injector Latency Value Database hawker800mech AccessPort 18 08-18-2014 10:44 PM
Difference between two turboxs fmic's? im lost noonagon Newbies & FAQs 6 02-03-2009 09:12 AM
Injector Scaling and Latency Values..... Chp_Stix Engine Management & Tuning 9 05-10-2007 09:11 PM
deatschwerks 650cc latency values? 69_Lex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-30-2006 08:47 PM
Need latency values please kingtut12 Engine Management & Tuning 2 05-24-2006 11:56 AM
