Old 09-28-2009, 01:44 PM   #1
Panops145
Member#: 200310
1999 2.2l-2.5rs conv
silver-dark grey metallic
Default Gear Grinding in 99 impreza?
What can i do to fix the fact that if im tryin to switch from first to second very fast and it grinds like a bitch haha. I have to give it time to switch otherwise it grinds horribly...this happens to first gear if im in neutral at a light and im not payin attention and try to change to first very fast, but the grinding isnt as drastic....Any info on how to fix it or wat to do to change it would be awesome....
thanks in advance
Pete
Panops145 is offline   Reply With Quote
Old 10-13-2009, 06:03 PM   #2
nategr8ns
Member#: 198413
1999 Impreza OBS
Ninja 650r
I have the same problem with reverse: I just pumping the clutch but that doesn't work. Shifting into 2nd/1st a bunch of times seems to get it in though.
nategr8ns is offline   Reply With Quote
Old 10-14-2009, 12:43 PM   #3
hunter15
Member#: 151168
99 OBS
sounds like maybe if youre trying to shift fast, that youre possibly going into the gear before the clutch grabs all the way..but if it grinds other times even if u dont shift fast, id try changing the trans fluid 1st IMO. go with the Uncle Scotty's cocktail. that seems to work with a lot of people
hunter15 is offline   Reply With Quote
Old 11-22-2009, 10:18 PM   #4
dgsblb2
Member#: 197278
1999 Lifted OBS
I know your problem, I used to have it. You need new syncros. I had my transmission rebuilt and there is such a big difference when you get new syncros that sometimes I swear it shifts from 1st to 2nd by itself at high RPM. This is in my 99 OBS.
dgsblb2 is offline   Reply With Quote
Old 01-18-2010, 12:29 AM   #5
Panops145
Member#: 200310
Default Re: Gear Grinding in 99 impreza?
thank you i didnt realize it but its true. the clutch wasnt grabbing all the way i realized it randomly one day lol
Sent from my Droid using Tapatalk
Small amount of gear grinding in first Massive Transmission (AT/MT) & Driveline 2 01-17-2005 08:56 AM
HELP!!!gear grinding in 2nd/3rd? anthonyrb98 Transmission (AT/MT) & Driveline 1 08-12-2004 09:02 PM
5th gear grind in STi & repairs PA04STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-10-2004 05:53 PM
Gear Grind in XT XT_Mike Forester Forum 2 11-24-2003 09:52 AM
4th Gear Grinding in GC8 JohnP555 Transmission (AT/MT) & Driveline 3 08-10-2003 05:40 AM
