Notices
Old 09-28-2009, 03:22 PM   #1
JonJ
Member#: 78484
2006 Impreza WRX
Default Secondary Air Pump Solutions?
So my 06 WRX is kicking out P1410 and P2442 right now, so I took it by the dealership this morning and they just called and informed me that it was the secondary air valve and gasket on the drivers side. Said repair would run just under $600.
Now I've read that the whole air pump system can be removed with no problems.
My questions are, if removed would I have problems with more codes getting kicked out? Would I have any problems passing state inspection? (I'm in Texas)
From what I understand the air pump is to help emissions off of a cold start but once the engine is up to running temp, then it serves no purpose.
If I must spend $600 on the car for any reason right now I would much rather by an AP.
TIA for any suggestions on this matter.
JonJ is offline   Reply With Quote
Old 09-28-2009, 04:04 PM   #2
Mechie3
Member#: 120152
06's can ditch it no problem (it's the 07's that have issues with pressure sensors).
Either get an accessport and have someone tune the codes out (if it's not a true custom tune, just turning off codes, some tuners do it for $25) or have someone opensource tune it locally to turn off codes.
You could also find a valve from someone who ditched the system.
Mechie3 is offline   Reply With Quote
Old 09-28-2009, 04:27 PM   #3
JonJ
Member#: 78484
2006 Impreza WRX
Just making sure I understand.
If I remove the entire system, and either get a tuner to clear the codes or get an AP and clear them myself then. I can go get it inspected with no problems?
I don't really have any interest in fixing something that serves little function like this, especially if it will still be "clean" enough for the state regs.
Old 09-28-2009, 04:38 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Actually, to clarify, you need to tell the ECU to "ignore" the CEL. The way to do this is program the ECU with such a wide range before it trips the CEL, you never get a CEL showing.
If you just "clear" the CEL, it will be gone, but all the readiness indicators will also be reset and you can fail for that.
Old 09-28-2009, 04:48 PM   #5
JonJ
Member#: 78484
2006 Impreza WRX
So can the AP do that? Sorry for my ignorance I'm new to the electronic tuning, always been a mechanical type.
Old 09-28-2009, 05:06 PM   #6
Mechie3
Member#: 120152
My tuner just cleared the CEL's IIRC and I passed OBD-II inspection in NYS 2 years in a row (moved out of NYS now).
also, I couldn't remove the hose on the back side of the passenger head with the stock uppipe on (heatsheild interfered). To get around this, I just block off the inlet of that hose until I changed uppipes and head clear access.
Old 09-28-2009, 06:05 PM   #7
JonJ
Member#: 78484
2006 Impreza WRX
Good deal, yeah I just got off of the phone with Engine Logics here in Houston, and they said they could clear it all for me. Seem like some good people. If this goes well I'll probably go back there for some tuning work. My room mate has an 07 STi and he's looking to get his tuned soon, so it's good to know there is a recommended/ trusted shop locally.
Old 09-29-2009, 10:13 AM   #8
JonJ
Member#: 78484
2006 Impreza WRX
So I picked it up from the service center last night, and on top of putting 20 miles on my car, they managed to get the E Brake light to stick on. I checked my rear pads and they seem fine, the car could use a little break fluid but it's not low by any means. So for anyone in the Houston area I would avoid the service center at West Houston Subaru.
On top of the new problems, they were wanting me to get 2 grand worth of work done that did not need to be done. q >.< p
2006 WRX: P2444 Secondary Air Pump Stuck On dousbon Newbies & FAQs 88 07-17-2016 03:41 AM
Plugging Secondary Air Pump BlueSubeDude Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 08-03-2013 08:36 PM
CEL p2444 secondary air pump?? tcr04 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-27-2013 07:12 AM
WTB: Secondary air pump baro sensor 07 WRX ronzogonzo Private 'Wanted' Classifieds 0 11-25-2009 05:37 PM
