Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 09-29-2009, 12:54 PM   #1
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
Default For what its worth, CV replacement
For those of you who may need to replace a front axle on the Baja, keep in mind that the ride height changed from 03 to 04 and again in 05. This appears to matter when purchasing an after market part from Autozone, VIP, etc. I recently had a torn inner boot on the passenger side front this Spring, and could not get an axle for an 05 (it was unavailable) so I purchased one for an 03. To the eye it looked the same and installed OK. I also bought a replaement boot to repair the original and use as a spare. After the install I noticed a slight shuddering at about 20 to 25 mph, this would go away at higher speeds. At first I thought it might be a misfiring plug, so I changed wires and plugs, but the shudder remained. So I just lived with it (I did suspect the axle). Well last week I replaced a torn inner boot on the drivers side, and while the Baja was jacked up I also removed the aftermarket 03 axle and reinstalled the repaired passenger side axle. Now the shudder is gone So either it is crappy aftermarket parts, or the increased angle from the slight factory lifts are taken into account when these axles are manufactured
Note:As the title implies, this is just my personal observation.
Buck
Buck Rogers is offline   Reply With Quote
Old 09-29-2009, 01:25 PM   #2
nickybots110
Member#: 186436
2005 Forester XT
Its possible there is a difference. But I kow I've had numerous problems at the shop with cheap aftermarket axles with vibration. More then likely I'll say it was poor workmanship on the axle. I'm gonna look up both axles now and see if there is a difference
nickybots110 is offline   Reply With Quote
Old 09-29-2009, 01:44 PM   #3
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
I cought mine in time....
pretty easy to do...
holland_patrick is offline   Reply With Quote
Old 09-29-2009, 07:29 PM   #4
twheats1
Member#: 147722
11 Rug
00 R 1100RS
A while back I replaced axles on my 04. One of the remanufactured axles had a similar problem along with vibration at high speed. Ended up replacing them with new axles. (only $30 more apiece)
twheats1 is offline   Reply With Quote
Old 09-30-2009, 03:00 AM   #5
steven765
Member#: 105920
2006 Baja 5 Speed
so who's axle's did you use. Subaru OE?
Reason I ask is that I have the same vibration around 20-25mph that seemed to start just after subaru warrantied one of my axles! It has been driving me nuts for a while.
steven765 is offline   Reply With Quote
Old 09-30-2009, 07:33 AM   #6
jeromes
Member#: 192299
2011 Forester XT
Default I would like to know this also
What brand did you buy?
jeromes is offline   Reply With Quote
Old 09-30-2009, 08:01 AM   #7
twheats1
Member#: 147722
11 Rug
00 R 1100RS
The axles were aftermarket, from either Autozone or Napa. I don't remember which right now, I had called a lot of parts stores to find them.
Old 09-30-2009, 02:23 PM   #8
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
In my case, I have the original axles (both repaired with new inner boots) the after market axle is out. If Subaru replaced your axle, and it vibrates, I'd bring it back and have the mechanic drive it.
Old 10-04-2009, 01:25 AM   #9
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
Ive gotten bad rebuilt cv axles before, just have to exchange it. I tend to stay away from napa parts anyway though, had alot of bad, misboxed or poorly rebuilt parts.
bobjr94 is offline   Reply With Quote
'97 Impreza L for sale, seeing what its worth! impreza97 Private Vehicle 'For Sale' Classifieds 2 08-30-2006 03:04 PM
TEIN HA full set, tell me what its worth... jared nelson Private 'For Sale' Classifieds 0 02-03-2006 02:52 PM
When was the last time you heard Buffalo Springfield's For What its Worth? DJ 9iron Off-Topic 3 08-31-2005 06:13 PM
What its worth? lawchang Bay Area Impreza Club Forum -- BAIC 0 07-15-2004 09:11 PM
Take it for what its worth- info on the Outback and STi Jon [in CT] Scoobie Newbie News & Rumors 15 02-23-2004 04:10 PM
