Notices
Old 09-29-2009, 02:03 PM   #1
azn_outlaw
Member#: 91572
2005 Impreza WRX
Silver Tack
Default Tips to share to prevent stripped threads?
I bought a used TMIC
due to the one in which came with my 05 WRX, reason I know is that I discovered that the OEM BOV was silconed on, in the end when re-installing the OEM BOV. one of the bolts would refuse to tighten..
so instead of trying to fix it, I left it until I can get a good deal on a stock TMIC..
finally found one, and now want to try my best to prevent the threads from stripping on this used intercooler I bought...
what are some tips too preventing or minimize a striped thread from happening again
thanks
azn_outlaw is offline   Reply With Quote
Old 09-29-2009, 02:08 PM   #2
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
You can buy a thread chaser kit. I happened to buy a kit at sears when I could not find an m12 1.25 tap in my numerous tools. The chaser is specifically made for existing threads and cleans them up really nicely. Run it through any threaded hole before you start.
Also, don't overtorque. That'll potentially start a strip.
Old 09-29-2009, 02:10 PM   #3
fred.r
Member#: 204474
2002 Almost STi Wagn
RAW
Liquid wrench or PB Blaster to help prevent snapping/rounding off bolts or nuts.
And hand thread the bolts/nuts first, making sure it's threading properly before using a wrench. And USE A TORQUE WRENCH for proper torque spec.
fred.r is offline   Reply With Quote
Old 09-29-2009, 02:12 PM   #4
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
luck and take your time
bigolrig is offline   Reply With Quote
Old 09-29-2009, 02:13 PM   #5
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Thread chaser is good. Setting the bolt by hand is good. Using a cutting fluid is good. I use rapid tap brand, but nearly any will work. Mostly, exercise some caution and care.
UFOpilot is offline   Reply With Quote
With all the WAPCE threads lately, I had to share this one left footed whooten Off-Topic 23 02-18-2007 02:27 PM
Another lame email I received today that I had to share to make you guys miserable... chris619 Off-Topic 14 05-25-2005 01:38 PM
Dumb useless thread to show a pic I found and wanted to share... Janq Off-Topic 4 09-24-2004 04:13 AM
any environmentalists out there care to share your tips? Disoriental Off-Topic 38 02-25-2004 04:56 PM
Whistle tips?? Had to share... sigh kschmohl Mid Atlantic Impreza Club -- MAIC 16 08-20-2003 09:45 AM
