Notices
Old 05-09-2002, 07:56 PM   #1
Onederer
I am NOT nice
Member#: 7952
2014 Ford Fiesta ST
Default Equal Vs Unequal length headers
What are the pro's and cons of each system?
And why. Also, what if any audible difference is there?
Some one told me that the Equal length headers will take away that distinctive Subaru flat 4 sound.
Thanks
@copy
Onederer is offline   Reply With Quote
Old 05-09-2002, 08:00 PM   #2
mlambert
Member#: 13831
equal length tuned headers normally enhance the sound of a motor...but with a turbine in the exhaust path...i doubt it would sound much different.
mlambert is offline   Reply With Quote
Old 05-10-2002, 02:13 AM   #3
wrx99
Member#: 17686
Any headers on the wrx change the sound of the engine unfortunately. I made my own 1.5 inch diameter copies of the Zerosport design which are very unequal in length, and the boxer sound is only there at idle. It sounds very wrc-like at revs over 1000 and makes a lot more power. Be careful that you have your aftermarket ecu (if you have one) tuned to suit, otherwise the increased efficiency from the headers will mean that the motor will run lean. I had to add fuel at the top end and made about 20 more horses. The other advantage of headers (according to my tuner) is that the engine will rarely ping (knock, detonate) as easily as it will with the stock manifold from over advanced timimg. He reckons you'll lose power before it detonates if you keep advancing the timing.
wrx99 is offline   Reply With Quote
Equal vs. Unequal length headers bcWRX-02 Newbies & FAQs 58 05-25-2009 04:29 AM
GT-Spec equal length vs. unequal length headers SW00P_G Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 31 02-17-2009 07:40 AM
equal vs unequal length headers on an 06 TR VRT Gump Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 08-06-2007 04:28 PM
Please compare equal vs. unequal length headers... shemoves Normally Aspirated with bolt-on Forced Induction Powertrain 6 09-02-2006 02:44 PM
Equal length vs. Unequal length headers 4080wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-21-2004 10:03 PM
