Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 09-29-2009, 07:23 PM   #1
DJS_02_WRX
Member#: 205058
2002 WRX Wagon
1992 Built Civic Hatch NA
Default Best way to remove rust from a muffler?
I have the stock exhaust piping welded together from a 2005 WRX sedan with a Magnaflow muffler on it. The piping is in good shape, it came stock on the car when my cousin bought it. I was going to clean it up and sell it, but I noticed that it started to rust from sitting in my garage. I know people will want to buy it because some people like the deep tone that exhausts give, but they don't like it too loud, and this exhaust system would hit that right on the head. It's perfect for that.
But my question is - what kind of product(s) are good for removing rust from the muffler?
Thanks in advance!
- DJ
DJS_02_WRX is offline   Reply With Quote
Old 09-29-2009, 07:28 PM   #2
tank1987
Member#: 223181
05 WRX, stage mehh
hybrid built SOLD!!! :(
Naval Jelly works, dependant on how bad it is. You can get it at any hard ware store.
tank1987 is offline   Reply With Quote
Old 09-29-2009, 07:50 PM   #3
racer580
Member#: 202667
2006 WRX stage II
steel wool + elbow grease (lots of it) + any metal polish will do a pretty good job on the rust spots.
racer580 is offline   Reply With Quote
Old 09-29-2009, 07:51 PM   #4
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Stainless steel/metal/aluminum polish and compound?
EdHilario is offline   Reply With Quote
Old 09-29-2009, 07:52 PM   #5
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
clay bar
V6TurboTA is offline   Reply With Quote
Old 09-29-2009, 08:26 PM   #6
NutBucket
Member#: 90804
'15 SJ, '05 GG
Dirty
Wire brush + drill.
NutBucket is offline   Reply With Quote
Old 09-29-2009, 09:54 PM   #7
krzemienr
Member#: 134140
2000 Impreza RS
BRP
um... from what every said... the only thing that will work is naval jelly (ace hardware carries it cheap). polishing it will only make it change colors and not fully convert/remove it.
krzemienr is offline   Reply With Quote
Old 09-29-2009, 10:05 PM   #8
ADAS1223
Member#: 159853
2005 Impreza
wrb
k/y???
ADAS1223 is offline   Reply With Quote
Old 09-29-2009, 10:12 PM   #9
bannerd
Member#: 110771
2006 WRX
black
I looked into this a long time ago because I was fed up with having rust on certain objects and worst of all salt build up. Muscle Grease is what you want.. just spray it on and let that crap sit for a few days. You can leave it on it's 100% water proof and heat resistant. Or you can wipe it off and it will fill the pores in the metal making it last longer. Pretty good crap, 8$ for a can, try it and you'll be amazed.
bannerd is offline   Reply With Quote
Old 09-30-2009, 03:17 AM   #10
sube-trex
Member#: 97577
2001 IS 300
Never-Dull+elbow grease, I knew I should of took pics of before and after of my exhaust.
sube-trex is offline   Reply With Quote
Old 09-30-2009, 04:27 AM   #11
STi22B
Member#: 86906
07 Scion tC
Pearl White
i would opt for this
STi22B is offline   Reply With Quote
Old 09-30-2009, 06:38 PM   #12
TexSurfer
Member#: 76072
Thanks in advance!
- DJ
Depends on how far along the rust is. There are a lot of rust removal products on the market. Just be careful, as some are more corrosive than the rust. Make sure to pick a product that is appropriate for the type of metal. Steel wool will often work. Just start with the least aggresive (#0000). A good metal polish will also work if the rust isn't too bad. I really like Flitz. You'll also want to use this after steel wool if you choose that route.
TexSurfer is offline   Reply With Quote
Old 09-30-2009, 07:12 PM   #13
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Repainting is always an option too
Old 09-30-2009, 08:42 PM   #14
racer580
Member#: 202667
2006 WRX stage II
Haha ya it worked really really well for me. Here's a link of my experience: http://forums.nasioc.com/forums/show....php?t=1818688
Given that the rust spots on my tip weren't very large/intense, for the OP's application, just more time + elbow grease will most likely do the trick.
Old 09-30-2009, 09:05 PM   #15
fzel07wrx
Member#: 150710
2012 SWP WRX Hatch
2005 Lotus Elise
Plus a coat of wax/sealant (whatever you have) applied/wiped away with any crappy rag. It won't last forever obviously, but it'll still bead away the elements for quite some time!
I bought this exhaust used two years ago (can't even remember the miles on it then)... about 20K myself... look how nicely it shines up with some metal polish and wax about once a year.
fzel07wrx is offline   Reply With Quote
Old 09-30-2009, 09:28 PM   #16
racer580
Member#: 202667
2006 WRX stage II
^^ +1 for it still being so clean.
Old 09-30-2009, 09:39 PM   #17
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Thanks in advance!
- DJ
DJS_02_WRX is online now Report Post Reply With Quote
Best stuff I've EVER found for Stainless steel.
5lipstream is offline   Reply With Quote
Old 09-30-2009, 11:59 PM   #18
ctrent86
Member#: 129199
0000 steel wool and flitz or Optimum Metal Polish
ctrent86 is offline   Reply With Quote
Old 10-01-2009, 02:12 AM   #19
pablod
Member#: 222934
Psm
use clr and steel wool after your done whipe it down really good buy some wax and use microfiber towels to whipe down you can also buy the powerball to wax
pablod is offline   Reply With Quote
Old 10-03-2009, 12:03 AM   #20
02SportWagon
Member#: 224751
2002 WRX Wagon STG 2
Turtle Wax makes a Mag and Wheel Polish, it works great on SS and when used with 0000 steel wool it takes off most heavy rust deposites. Transformed my buddies twin exhaust on his 87 RX7.
and fzel07, how is that car so clean? Mine was that clean for about a month and half...
02SportWagon is offline   Reply With Quote
Old 10-03-2009, 04:00 AM   #21
fzel07wrx
Member#: 150710
2012 SWP WRX Hatch
2005 Lotus Elise
Ha, at that time of the picture being taken, I JUST resprayed my rear sway and tow hook, and I polished/waxed the muffler and tip.
This was about a month ago, and I can assure you those parts are covering up the normal wear we're all used to seeing.
Even through the Rochester winters, the touchless washes with undercarriage spray work wonders!
Old 10-04-2009, 06:00 PM   #22
Rexxyou
Member#: 110816
USMC Semper Fi
GT35
steel wool
Rexxyou is offline   Reply With Quote
Best way to remove decals from window iwantmyWRX Interior & Exterior Modification 5 03-17-2008 08:22 PM
What's the best way to remove dust from clean exterior? HAL1 Car Care & Detailing 29 08-24-2007 02:34 AM
Best Way to Remove Paint from Another Car? Backup7 Interior & Exterior Modification 10 05-18-2007 12:05 PM
Whats the best way to remove corrosion from small gold connector contacts? Prod Off-Topic 8 01-11-2007 10:27 PM
best way to remove rear nut from front control arm? rex n effect Brakes, Steering & Suspension 5 04-28-2004 08:09 PM
