Old 09-30-2009, 02:06 AM   #1
chrisc75
Member#: 183729
07 sti
swp ///95 m3/ 94 supra tt
Default wanted to know if anyone had this problem?
soo i was out goin to school today in my daily (03 wrx wagon) and i start gettin into boost and it gets to about 10 pounds and starts fluttering and hesitating..soo i took the car back home. I got home after school and start checking thing..find a good cut in my inlet hose(stock) and once i pulled the plugs i noticed they were white tiped..can the slice have cause me to go lean? i got new plugs in it now and im gonna get a new inlet hose. but should i check for anything eles? can this cause the problem i was having?
have changed anything recently
chrisc75 is offline   Reply With Quote
Old 09-30-2009, 02:21 AM   #2
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Was the slit before or after the MAF? If it was after, the car was likely running lean as the engine was really getting more air than the MAF was reading. This would turn your plugs white. Did you notice higher temps? I'm guessing the hesitations you felt were detonation? In which case, don't drive the car till its fixed.
Anybody else, am I way off base here?
that1dude is offline   Reply With Quote
Old 09-30-2009, 02:25 AM   #3
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
Sounds about right. Your car goes into 'limp mode', hence only 10 psi of boost. Replace the hose and be on your way.
575rider is offline   Reply With Quote
Old 09-30-2009, 01:47 PM   #4
chrisc75
Member#: 183729
07 sti
it was after the maf and im replacing the hose and plugs and ill see how it goes
Old 09-30-2009, 01:49 PM   #5
subiee88
Member#: 223352
2004 wrx wrb
stock
whats the normal psi of boost for a wrx? my gauge gets up to 11 pds with the stock turbo when im close to redline.
subiee88 is offline   Reply With Quote
Old 09-30-2009, 01:56 PM   #6
T_Racer69
Member#: 188079
2003 Stg 2 Bug Wagon
Sonic Yellow
Some years may be a little differnt. Mine, an 03 2.0L, stock is 13.5, but tapers down as it approches redline. Also, max boost is different for 1st, 2nd, and 3rd-5th, with max. being raised a little each gear.
To OP, this may be a chance to go ahead and upgrade to an inlet and MAF silicone hose, lasts longer and performs better. Win-win.
Travis
T_Racer69 is offline   Reply With Quote
Old 09-30-2009, 04:55 PM   #7
RobSTI89
Member#: 225268
2005 STI
Get a silicone one, wht a pain to install tho.
RobSTI89 is offline   Reply With Quote
Old 09-30-2009, 07:02 PM   #8
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Usually involves pullin the intake manifold...
Old 09-30-2009, 07:09 PM   #9
chrisc75
Member#: 183729
07 sti
lol i have a sti that all apart..i know how to pull the intake manifold off lol
Old 09-30-2009, 07:16 PM   #10
Mobius118
Member#: 159098
2005 LGT Ltd 5AT OBP
2003 WRX Stg4 PSM- RIP
What's more a pain is to install it without removing the intake manifold ; )
Mobius118 is offline   Reply With Quote
Old 10-01-2009, 05:34 PM   #11
RobSTI89
Member#: 225268
2005 STI
I have done it twice without removing the madifold, helps if you have some one else, and some socket it extentions to help push the nipples though. So it doent rip or tear it!
My wife wants to know if you notice anything wrong with this video. BacDoc Off-Topic 56 11-09-2009 12:12 AM
Didn't know if you had this info already plokivos Normally Aspirated with bolt-on Forced Induction Powertrain 2 07-07-2005 12:13 AM
UTEC Stopped Working - Anyone Had This Problem? ITWRX4ME Engine Management & Tuning 7 07-07-2003 02:04 PM
has anyone had this problem? 42202sub Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-03-2002 09:26 PM
Hey all! i just wanted to know if anybody had the website for.... doulikjai Canada Region Forum 6 07-28-2000 12:43 AM
