Alaskan Impreza Club
Old 09-30-2009, 12:19 PM   #1
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Aspen White, WRB interior
Default Cylinder 3 misfire
Anyone have an extra coil pack I could borrow to see if my coil pack is bad? I havent tried moving it around to see if the problem follows but will most likely do it today.
coqui2004miguel is offline   Reply With Quote
Old 09-30-2009, 01:23 PM   #2
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Pull the plug out while your there and take a look.
TurboSetch is offline   Reply With Quote
Old 09-30-2009, 01:35 PM   #3
Brando5185
Member#: 189926
2006 Jeep GC Limited
It's a HEMI!! Yee-haw
He has already replaced the plugs.
Brando5185 is offline   Reply With Quote
Old 09-30-2009, 01:50 PM   #4
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
well he still needs to move that coilpack around.
I had the samething going on with my engine before it seized...but I think it was my headers hittin the subframe sending the missfire...
Marlons101 is offline   Reply With Quote
Old 09-30-2009, 02:40 PM   #5
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Thats not the point. Look at the plug and better yet compare it to the one next to it. These misfire codes tend to lie about which cyl is really having the issue. Sometimes you can tell just by looking at the condition of the plug vs another.
The car determins a misfire from the crank angle sensor. Check to be sure its secure. You could also have internal engine problems. A leak down or compression test would be the next move if the coil pack swap fails. Just keep in mind you might be chasing the wrong cyl so move it around.
Old 09-30-2009, 03:58 PM   #6
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Roger that Seth. I dont even know the numbers on the cylinders...Looking at the engine bay from the front, the back left cylinder plug had oil on it. I know my car has been smokin a bit for the past 2 months and losing oil.
Old 09-30-2009, 04:23 PM   #7
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.54 Dale tuned
ok left side is 2 and 4 and right side is 1 and 3, if your sitting in the drivers seat not looking at it
tribalwrx is offline   Reply With Quote
Old 09-30-2009, 06:17 PM   #8
coqui2004miguel
Member#: 189901
02 WRX Bugeye
so sitting in the drivers seat it looks like this ?
2 1
4 3
-------Firewall-------
Drivers Pasenger
seat seat
Old 09-30-2009, 06:30 PM   #9
tribalwrx
Member#: 32993
vf39 Best trap 110
yep it is
Old 09-30-2009, 06:44 PM   #10
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
nice dia
Old 09-30-2009, 10:28 PM   #11
Wrbimprezasti
Member#: 115505
2005 Sti
Stock VF39 12.4@109
your cars acting up to miguel? i still havent traced my problem down to see if its my damn o2 sensor yet...=(
Wrbimprezasti is offline   Reply With Quote
Old 09-30-2009, 10:33 PM   #12
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
I was having a cyl 3 misfire code on my ej205, turned out to be a fuel filter after switching around coil packs, plugs, and a compression test. Go spend the $20 and see if it goes away. you should replace the fuel filter often anyways
greenspeed is offline   Reply With Quote
Old 09-30-2009, 10:41 PM   #13
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Ok, I will be switching the coil packs around first to see if it traces back. If it stays i will go for the Fuel Filter. Thats the little baggy thing attached to the Fuel Pump right?
Old 09-30-2009, 10:43 PM   #14
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Yeh man it wont stop throwing the cylinder 3 misfire. The blinking CEL light is really getting on my last nerve .
Old 09-30-2009, 10:56 PM   #15
ridestreet84
Member#: 132030
2007 obp STI
95 impreza (rally beater)
if you want to do a compression test get with me i have the tester to do one
ridestreet84 is offline   Reply With Quote
Old 10-01-2009, 03:55 AM   #16
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
whoa whoa whoa...totally different scenarios. Type A misfires cause a CEL to blink because it is detrimental to the cat. It is flashing to let you know that the conditions it is running at can cause the cats to overheat break down and fail.
You're not geting a solid CEL I'm guessing scenarios chance. Compression test should be done first and quickly, also check the condition of your turbo, look for leaking injectors, along with condition of the plugs.
Basically get the car warmed up, take the packs off plugs out (mark where each one went) compression test each cylinder, should be within 10% of each cylinder. Mine were at 105, 110, 110, 109 so I was good, but my numbers were lower cause it was cold, what is important is if the number are close to each other.
What mods do you have done?
Old 10-01-2009, 02:02 PM   #17
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Doesn't have to be hot since your looking for a major difference between cyls. Numbers will read a little lower thats all. Stock pistons don't expand much. I only say this because it sucks doing the test with a hot motor.
The only O2 sensor that the ECU really listens to is the front one. The rear one is to check the catalyst performance. I have read a little about people saying the rear O2 was causing issues but I just don't see how. More research here perhaps.
Old 10-01-2009, 02:11 PM   #18
coqui2004miguel
Member#: 189901
02 WRX Bugeye
I have a leaky injector. It blinks from time to time. Im now getting a heater bank 2 CEL.
As far as mods I'm an sti without motor and tranny. Pink injectors, vf39 and supporting mods.
Old 10-01-2009, 07:47 PM   #19
tribalwrx
Member#: 32993
vf39 Best trap 110
no the fuel filter is on the the drivers side strut mount, that is a filter on the fuel pump but not the main fuel filter for our cars, also when you change it let it drain out as much as possible then spray some brake clean in it and smack it a few times on the ground then pour the brake clean out and you'll see just how dirty your filter was
Old 10-01-2009, 07:48 PM   #20
tribalwrx
Member#: 32993
vf39 Best trap 110
pick up a new fuel filter at conti for around $30 i think might have been 26.95 give andrew a shout about it
Old 10-02-2009, 06:40 PM   #21
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Sounds good. When by FATS Auto and picked up new O-rings for the injectors and will perform the rest of the stuff this weekend. Turns out the flashy light is my O2 Sensor.
Old 10-04-2009, 12:00 AM   #22
coqui2004miguel
Member#: 189901
02 WRX Bugeye
Well I changed out the O-rings on the leaky injector and i havent got the misfire again. I did realize tho I never put back the black cap underneath the injectors on the drivers side and now i cant find it. Im not sure what its called but Marlon said it was a breather so Ive been leaking air through there since i first did the injector upgrade back in February. Im not sure what affects this has on my engine but if anyone has one or knows of where to get one, and the name of the part, it would greatly be appreciated.
Cylinder 3 misfires.. could use some help jerky007 Factory 2.5L Turbo Powertrain 4 06-09-2008 09:23 AM
Intermittent Cylinder 3 Misfire TheShad0w Factory 2.0L Turbo Powertrain 15 12-09-2007 01:50 PM
Cylinder 3 Misfire ImPrEzZzZZA Factory 2.0L Turbo Powertrain 0 05-29-2003 05:51 PM
Cylinder 3 misfire hokiewrx Factory 2.0L Turbo Powertrain 3 01-04-2003 04:01 PM
p303 cylinder 3 misfire defduane Factory 2.0L Turbo Powertrain 4 10-22-2002 09:45 AM
Message Board Statistics All times are GMT -4. The time now is 10:54 AM.
