Old 05-10-2002, 02:49 AM   #1
IslandImprezaRS
Member#: 18668
Default Turbo and Intake systems?
Im planning on installing a Turbo and an Intake system on my 99 Impreza 2.5RS. My Questions are:
What Turbos and Intake systems do you suggest?
If I add a Turbo it has been suggested to add new driveshafts, because the stock driveshafts supposedly can't take the power, is that true?
And is there a rev limiter on the car that keeps it from going faster than 120mph and will i have to add new gauges if i add the turbo and the intake system.
My car already has K&N filter, STi struts and rear tower brace in the trunk, and is lowered an inch.
Thanks for the help.
IslandImprezaRS is offline   Reply With Quote
Old 05-10-2002, 03:03 AM   #2
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
read the sticky post at the top.
or search these topics:
Turbo Kit
Ludespeed
Force Air Tech
Chalak Gear Set
Dogbox
KillerTHC is offline   Reply With Quote
Old 05-10-2002, 03:07 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
And any turbo kit should come with an intake already. Remember, the intake goes directly to your turbo, then to your throtlebody.
Eric
Eric SS is offline   Reply With Quote
Old 05-10-2002, 09:46 PM   #4
bensonwrx
Member#: 6904
AWD R35, XE30, V37
BO, AS, MW
Hehe, I would suggest adding an IC between the turbo and the throttle body
Reading the sticky will give you a better idea, but yes you will need gauges; that's a must.
The tranny isn't the most ideal setup as stock, but really it depends on how powerful your setup is going to be and how you drive.
Good luck
-Benson (Another MY98 Owner)
bensonwrx is offline   Reply With Quote
wtb: stock turbo legacy intake system 91turbosedaan Private 'Wanted' Classifieds 0 12-09-2008 11:16 PM
Wtt: wrx turbo and intercooler for stock Turbo legacy turbo and intake 91turbosedaan Private 'Wanted' Classifieds 1 12-06-2008 06:17 AM
bigger turbo and fuel system? i like high psi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-06-2004 11:16 AM
Upgraded turbo and fuel system w/ no engine management? TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-16-2003 02:20 PM
Questions on adding Turbo and Intake? IslandImprezaRS Newbies & FAQs 3 05-09-2002 11:39 PM
