Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 10-01-2009, 08:08 PM   #1
STirish
Member#: 71515
'06 STi
Default Running Redline 75W90 NS in a STi tranny...Thoughts?
Hey Y'all,
Playing around with tranny/diff fluid and wondered what some thought about running strict Redline 75W90NS in the STi 6-Speed tranny. The implication is that the diffs share fluid with the tranny. The idea being better lock up during wheel spin.
The car is strictly used for motorsports other than drives to/from the autocross/track and a rare weekend trip to the hardware store to remind myself why I don't daily the car.
A little info from redline:
http://www.redlineoil.com/product.aspx?pid=47&pcid=7
Rob
STirish is offline   Reply With Quote
Old 10-02-2009, 10:50 AM   #2
gregr01
Member#: 49333
04 STi
java pearl black
I've been using RLO 75W90NS exclusively since 2005 in the transmission.
Recommend it, and standard RLO 75W90 in the rear diff.
gregr01 is offline   Reply With Quote
Old 10-02-2009, 10:50 AM   #3
unclemat
Member#: 114530
2005 LGT 6MT wagon
Use Subaru Extra-S. Much better than some piss thin Redline crap.
unclemat is offline   Reply With Quote
Old 10-02-2009, 11:14 AM   #4
pete_falcone
Member#: 123330
16 ZoomZoom CeX-3
15 ZoomZoom3-Regina
Amsoil 75w90. It's the S.
pete_falcone is offline   Reply With Quote
Old 10-02-2009, 11:35 AM   #5
STirish
Member#: 71515
'06 STi
Maybe I should have been more specific. It's not a discussion of which fluid people use, but a discussion about running a fluid without a friction modifier. The kind of thing that makes the diff audibly bind when turning tightly at slow speed. Think when the 50/50 lock is set.
Thanks,
Rob
Old 10-02-2009, 11:37 AM   #6
STirish
Member#: 71515
'06 STi
Why? Can you talk about the benefits/cons you have seen vs. running a stock fluid or a fluid with a friction modifier. Any diff issues to report. What kind of mileage and use have been put on the car?
Rob
Old 10-02-2009, 12:23 PM   #7
gregr01
Member#: 49333
04 STi
java pearl black
Been covered in this forum more than once previously--see this thread for good info and opinions.
Before going with RLO I spoke with one of their engineers (Dave). As I posted back in '05:
I've tried Red Line ShockProof Heavy and LightWeight Gear Oil in the rear diff and they both caused chatter. Went to their standard 75W90 after contacting RLO directly--this was their specific recommendation for the STi. I purchased their Limited Slip Friction Modifier but it wasn't necessary to add any. No more chatter.
In the transmission I first tried ShockProof but it caused stiffer shifting. I now run 75W90NS as recommended by RLO, and shifting is smooth and easy.
Some people run OEM and are happy. I choose to use RLO. I've run track days in 100+ ambient and autox in 110+ ambient. I change out both gear fluids every year. I used to use this car for frequent track days and autox, though in the last year it's only been autox. Total mileage is 36,000.
If you're asking about MPG I can't be certain as I only use 100 octane and never run through a tank that doesn't include at least one event. Still it's around 19 combined, putting down 325whp/340wtq.
Rob
Old 10-02-2009, 01:20 PM   #8
STirish
Member#: 71515
'06 STi
I'm more curious about the front and center differentials and how they react to the 75W90NS. My front/center diffs currently bind up/chatter when turning at a slowly rate of speed. I'm curious about a quantitative advantage of running the NS fluid when it comes to how well the differential work vs. the accelerated wear that will be accounted.
So far I have been unable to qualify any gains running the straight NS vs. something with a friction modifier.
Keep in mind this is my race car, I'm only concerned about how well the car works and how long the parts last
Rob
Old 10-02-2009, 02:18 PM   #9
gregr01
Member#: 49333
04 STi
java pearl black
Fully-built road race car I'd be trying out Redline Heavy Shockproof (Jamie aka Subie Gal uses it as well, or at least used to).
Multi-use track/autox/street I still think 75W90NS is best (or OEM if you prefer).
'04 STi uses a different front LSD than '06 (I believe) so YMMV.
Old 10-02-2009, 03:46 PM   #10
GrantC
Member#: 94477
2005 WRX Stg2/STX
The shockproof shouldn't be used in a transmission with an internal filter... AKA. it's fine in the 5MT but a no-no in the 6MT.
GrantC is offline   Reply With Quote
Old 10-03-2009, 11:23 PM   #11
Back Road Runner
Member#: 60082
2004 Forester STI
Amsoil's Severe Gear does come in 75w110 and 75w140 if you're seeking a little more protection.
Redline Shockproof is a good option too as that's sort of its specific gearing.
Old 10-04-2009, 01:07 AM   #12
kh15
Member#: 132400
i have been running redline 75w90ns in my tranny for over 30k! Its just like engine oil debates, its just personal preference! try it out and if you dont like it, switch!
kh15 is offline   Reply With Quote
Old 12-31-2013, 11:48 PM   #13
gregr01
Member#: 49333
04 STi
java pearl black
Reviving this oldie with new observations... it was easier to have the dealer swap OEM gear oil... that was the worst 12+ months I've ever endured. Balky shifting in the hot or cold, whether the car was warmed up or not. Terrible.
Swapped back to RLO ns in the tranny yesterday and it's back to smooth and slick action, and this in a transmission with 53k and hard autox and track day use.
For my '04 STi, the difference is remarkable, and I continue to recommended RLO.
+1 very happy customer. :-)
Run only redline lw shockproof in ppg syncro tranny with cusco Diffs? White 2.5rs Transmission (AT/MT) & Driveline 17 07-15-2009 03:04 PM
07 sti clutch in 04 sti tranny? RobWRX04 Transmission (AT/MT) & Driveline 0 08-29-2008 03:42 PM
Why not 75w90 ns in read LS diff? davidji Service & Maintenance 5 01-04-2007 07:35 PM
Redline 75W90 NS tranny oil question SilverSubaab Transmission (AT/MT) & Driveline 4 08-27-2005 07:06 PM
Redline 75w90 NS (how long)? XBD Transmission (AT/MT) & Driveline 2 12-01-2001 11:27 AM
