Old 05-10-2002, 09:23 AM   #1
2 HOT 4 U
Member#: 18112
2000 IMPREZA 2.5 RS
PEARL RIDGE BLUE
Default Turbo and intake opinions for 2.5 rs
I was just wondering what direction I should go in adding a turbo and intake for my 2000 2.5rs? Who makes a good turbo and intake? I have heard that Weapon R intake is terrible but that was the only intake that I have been told about so far....
Thank you for your help in this matter
2 HOT 4 U is offline   Reply With Quote
Old 05-10-2002, 09:44 AM   #2
Jewbaru
Member#: 1994
2013 Impreza WRX
you cannot have an "intake" with a turbocharged 2.5 RS. If you swap in a MY02 WRX motor, you can add an intake with the turbo, but not with any aftermarket kits. 99% of the kits come with an intake pipe, so you don't need to worry about an "intake".
Jewbaru is offline   Reply With Quote
Old 05-10-2002, 02:21 PM   #3
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
Uhh someone had a nice injen setup with a ludespeed kit. It was posted here like a couple weeks ago. Its just some intake pipes that come with turbo kits dont look as nice. My suggestion is just find an intake from another car and just hack off the end to it so it fits. But Tom made a nice intake for someone i forgot who.
Andy
ac_gohan is offline   Reply With Quote
Old 05-10-2002, 08:37 PM   #4
bensonwrx
Member#: 6904
AWD R35, XE30, V37
BO, AS, MW
Actually it's the fitment that you have to think about. A turbo kit still requires an intake, unless you want to put a sock on the turbo for filtration purpose. Anyway, if you can make the aftermarket intake to fit, by all means go for it. It's more for look than go though, as most of the powers are going to be from the FI setup (esepcially the one w/IC), not so much for the intake. The CAI will have slightly better low end power, but again high end is reduced (same theory as N/A setup but much less degrees).
Conclusion is that aftermarket intake will work, but usually requires some DIY mods to perfect fit it.
Good luck
-Benson (Another MY98 Owner)
bensonwrx is offline   Reply With Quote
turbo kit or supercharger for 2.5 rs Dan Bessey General Community 6 01-21-2006 12:50 AM
FS: Used Ganzflow intake and K&N filter for 2.5 RS DrBoy01 Private 'For Sale' Classifieds 9 12-09-2003 08:18 AM
Cheap Cold Air Intake For 2.5 RS 2000 and Up Imprezive2002 Private 'For Sale' Classifieds 1 07-25-2003 11:17 AM
FS: Exedy Racing Clutch and 12lb Flywheel for 2.5 RS... Brand New! Strider Tri-State Area Forum 0 04-22-2003 03:17 PM
Yes! Getting a custom turbo setup in Orlando for 2.5 RS Imprezha Normally Aspirated with bolt-on Forced Induction Powertrain 18 07-17-2001 08:49 PM
