Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 10-03-2009, 11:09 AM   #1
Sparconx88
Member#: 161756
05 Wrx
Default Will I pass emissions?
So I have a stage 2 wrx, it has a catless up pipe, catless turboback exhaust, short ram intake, and open source tune. I just received a notice in the mail that says I need to get my 2010 registration and in order to do that I have to take an emissions test. The only stock part of the exhaust I have is the catback. First off, if I can find somebody to let me borrow their stock catted DP and I put that on along with the stock catback will I be able to pass? Also, if I put on the stock turboback exhaust, will it screw up anything with the open source tune? I would rather just put the stock downpipe back on and leave the 3 inch catback just so its less work. My main concern is blowing up my motor because I went from a tuned 3inch catless downpipe to a 2.5 inch catted down pipe from the factory. I live in Littleton Colorado BTW and the altitude here is roughly 6,000ft.
Sparconx88 is offline   Reply With Quote
Old 10-03-2009, 12:32 PM   #2
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
Depends on what they do for Colorado emissions. If it's just OBD-II and visual, you should be fine. If they smog test it, you'll have some trouble. But if they're just running the OBD, then your engine management from the tune should have cleared all the codes.
magicstop is offline   Reply With Quote
Old 10-03-2009, 01:40 PM   #3
Fast03Wagon
Member#: 142375
2003 WRX Wagon
Midnight Blue
colorado is really pretty strict; they actually put it up on dyno type rollers and measure CO2, NOx and SOx, as well as unburned hydrocarbons. there is no way to pass without putting that stock downpipe on.
Fast03Wagon is offline   Reply With Quote
Old 10-03-2009, 05:41 PM   #4
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
You should have the original stock map. Just reload it and put the stock catted dp and exhaust back on. You may get an error code/check engine light without the catted up-pipe on the stock map. You can disable the codes with open source.
Fierysun is offline   Reply With Quote
Old 10-03-2009, 06:25 PM   #5
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
Maybe I just got lucky, I passed completely catless when I lived in Denver. I didn't have any CELs.
Thug Nasty is offline   Reply With Quote
Will I pass emissions?? mikeG8U Engine Management & Tuning 9 05-30-2005 08:41 AM
my Front O2 sensor caused CEL, will I pass Emissions?? Jobey Engine Management & Tuning 4 04-27-2005 06:52 PM
Moving to SoCal from INDY will I pass EMISSIONS? christianvwcars Southern California Impreza Club Forum -- SCIC 25 02-16-2004 02:24 PM
Moving to SF: Will I pass emissions? fastfood Bay Area Impreza Club Forum -- BAIC 9 05-11-2003 03:35 AM
DownPipe W/O Cat..Will it pass Emissions? blindclown New England Impreza Club Forum -- NESIC 10 05-20-2002 01:58 PM
