Old 10-04-2009, 02:00 AM   #1
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
Default DBA 4000 front rotors and hawk hps pads smoking?
ok so I did my front rotors and pads today, DBA 4000 slotted and hawk hps pads. I cleand the rotors with alcohol, wiped them down. I followed the Hawk instructions for bedding them in but the pads started smoking like crazy. Is this normal? I have to do threars tomorrow or monday and was wondering if this will happen again or did I do something wrong.
subiesoho is offline   Reply With Quote
Old 10-04-2009, 02:22 AM   #2
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
No they shouldn't smoke...
that1dude is offline   Reply With Quote
Old 10-04-2009, 03:09 AM   #3
csmithwrx'05
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
No way something is wrong. I have that exact setup.
csmithwrx'05 is offline   Reply With Quote
Old 10-04-2009, 06:36 AM   #4
Rexer06
Member#: 125065
2006 WRX
when you said you followed hawk's instructions, what exactly did you do? stock WRX callipers or aftermarket callipers? is this your 1st time replacing rotors and/or pads?
Rexer06 is offline   Reply With Quote
Old 10-04-2009, 01:44 PM   #5
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
yes first time replacing rotors and pads. I did 10 stops from 30-35 med pressure and 3 hard stops from 45. I am also using TIC titanium shims insted of the slotted stock ones but am using the stock anti squeal shims that go facing the pistons.
Old 10-04-2009, 01:54 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
take all the shims out until the pads wear a bit
and
throw those away
Old 10-04-2009, 02:03 PM   #7
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
<---- Has never used shims. Never had a problem.
Old 10-04-2009, 02:05 PM   #8
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
and
throw those away
so the only shims I need are the Ti TIC shims or do I need those slotted ones also? I also have to do the rears same setup but no TIC Ti shims. What shims do I reuse for the rear the stock slotted ones and get rid of thoes half shims that are supposed to be anti squeal shims?
thanks everyone
Old 10-04-2009, 02:09 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
thanks everyone
listen
to
me
take
ALL
as
in
every
one
of
the
shims
out
NOW
wait
a
couple
weeks
and
put
the
tic
shims
back
in
those
rotors
are
thicker
than
stock
and
the
pads
are
new
and
there
isnt
room
for
it
all
until
the
pads
wear
a
bit
Old 10-04-2009, 02:10 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
you
dont
really
need
ANY
shims
at
all
but
you
dont
know
that
Old 10-04-2009, 04:13 PM   #11
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
I was just worried abou heat transfer to the caliper and destroying the seals. Also over heating the fluid. I am switching over the stainless brakelines and Motul 660 fluid when I am done.
For the rears when they are broken in I should still not use any shims, even the slotted ones?
thanks for the help. I will also be doing struts and springs soon with groupn tophats.
Old 10-04-2009, 06:19 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
if you are not tracking your car regularly.....you are wasting your $$$ and time
no doubt
Old 10-04-2009, 07:50 PM   #13
Rexer06
Member#: 125065
2006 WRX
same here. anyway, some of the pads already come with shims which are permanently fixed to back of the pads so no point adding extra shims
Old 10-04-2009, 09:08 PM   #14
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
the hawk hps pads do not have shims.
Old 10-05-2009, 01:40 PM   #15
19gda
Member#: 211135
2007 EDM WRX
Orange
check the rotation of the rotor ..as I remember it is directional..
19gda is offline   Reply With Quote
Old 10-05-2009, 02:01 PM   #16
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
They should
KNS Brakes is offline   Reply With Quote
Old 10-05-2009, 02:02 PM   #17
KNS Brakes
Member#: 125739
2015 WRB WRX
RBF660 and street pads?
Old 10-05-2009, 02:48 PM   #18
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
Originally Posted by WRXBrakes View Post
They should
nope hawk hps pads for 06-07 do not have shims.
Old 10-05-2009, 02:57 PM   #19
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
what's wrong with that I figure the high boiling point of the 660 and the ss lines I should not have a problem with the fluid getting too hot, and it will decrease brake fade. I also would like to get into non contact road racing.
Old 10-05-2009, 03:07 PM   #20
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
Scotty I took all the front shims out and did the rears today with no shims. The question is would the front pads be ruined? They have a small lip near the outer edge of the pad. I sprayed them down with brake cleaner and scuffed them up to take the glazing off. Do you think they will be fine?
Old 10-05-2009, 03:55 PM   #21
Uncle Scotty
Member#: 16200
OK buy Nates beans
d0000000000d
they are brand new pads....they are fine....and if you scrape them with a file, that works great
Old 10-05-2009, 04:57 PM   #22
CyborgX_CZ
Member#: 145351
0000 RIP 2006 STi
04 FXT / 89 SE30
Are you sure there is no another metal plate stamped to the back of the pad? Looks similar to this.
RBF 660, are you looking in to some serious racing? I have ATE which is less than Motul RBF 600 and so far 30min at the race track with race pads braking from 140mph and 80-90F outside temp. I have no problem boiling fluid. So it is just wasting your money and if you think you will be faster than me then those brakes will not save you and you need to look for BBK. Also before that fluid will see any high temperature your HPS pads will vaporize. It’s just a bad combo, super high racing fluid and street pads.
CyborgX_CZ is offline   Reply With Quote
Old 10-05-2009, 04:58 PM   #23
classicaddict
Member#: 220619
04 wrx wagon
you say they have a lip. as in the pad is hanging over the outer edge of the rotor? scuffing the pad should be just fine. one thing you should do is drop by any auto parts store and pick up some synthetic brake grease. put a nice thin layer on the back of the pad. doing this some what adhearse the pad to the caliper and pistons so the pad pulls off the rotor.
also, new rotors and pads do have a habit of smoking a bit after the first "hard" run, its impossible to get new rotors 100% clean and dry before install, it happens. however i have noticed some companies have some fairly aggressive bed in procedures. a few semi brisk stops from 30mph with moderate brake pedal has always worked for me. but if they smoke on normal driving thats no good.
classicaddict is offline   Reply With Quote
Old 10-05-2009, 05:37 PM   #24
KNS Brakes
Member#: 125739
2015 WRB WRX
I think that's the first HPS pad I've seen w/ no shim.
Old 10-05-2009, 08:23 PM   #25
subiesoho
Member#: 164241
2007 wrx wagon
pearl white
I had HPS pads on my 99 neon rt and on my 98 prelude, they both had shims on them. The WRX 06-07 pads don't have shims on the fronts or rears. Fronts are 4 piston and the rears are 2 piston. That's why I found it weird to use no shims at all
Stock front calipers Power Slot rear rotors and Hawk HPS pads for 2002 WRX MTL_SLVR_WRX Suspension/Brakes/Handling 1 06-22-2010 11:17 AM
FS: 04sti rotors and Hawk hps pads vangstaboi86 Suspension/Brakes/Handling 11 06-30-2008 01:30 PM
Racing Brake Rotors and Hawk HPS pads Psydotek SCIC Private Classifieds 9 04-29-2006 11:37 AM
FS : WRX Calipers, rotors, and Hawk HPS pads..... Converted Private 'For Sale' Classifieds 2 02-24-2006 11:28 AM
WTB - Brembo OE rotors and Hawk HPS pads for 01 RS Geoffman72 Private 'Wanted' Classifieds 4 05-12-2005 09:00 PM
