Old 10-04-2009, 02:34 PM   #1
carter_wrx
Member#: 225745
2002 WRX wagon
Default rough idle, misfire, CEL funky high idle
Hey guys, new here...and having some wierd issues with my JDM 94 sube...its got the 2.0L turbo of course...117 xxxkm's
well, its intermitent, one day i came home and it had a bouncy idle and check engine light came on but when driving it drove normal. I shut it off...bought a case of beer and came out...and it ran fine...
also while running, idling fine you can hear it hicup (for lack of a better work) slightly like its misfiring.
a few weeks later i started it after work and it idled up to 2000 rpm and wouldn't go down, so i limped it home and checked hoses, conections etc. i took the maf out and it appeared to be clean. The sensor conected to the TB i beleive is the throttle possition sensor? i unplugged that and and the idle dropped to almost normal. I should add that turning the A/C on would make it drop as well.
I pulled it off to see if i could clean it...couldn't, it apears to be a sealed unit so i reinstalled it and adjusted itso it'll idle at 1000 rpm at idle. plugged it back in and works fine.
Now that the cold weather is here (around 0 celcius) it is not happy about starting, it'll have a real rough low idle for 5 seconds and then idle up to 1000 and be fine.
Recently i've also noticed when doing a hard pull it'll surge around 5000 rpm...feels like it loses boost but the boost gauge says 13 psi and doesnt move...it maybe a misfire too...
- I plan on doing a tune up (plugs, air filter, possibly coilpacks?) this weekend but, i know this wont fix my non existant high idle when cold problems...anyone have a clue of whats going on? And is there a way to check what the CEL means on these older cars? thanks guys
carter_wrx is offline   Reply With Quote
Old 10-04-2009, 02:44 PM   #2
carter_wrx
Member#: 225745
2002 WRX wagon
also if i try give it a bit of throttle to help it idle up it tries to die... im able to get a video of whats happening if that would help you guys. Thanks
High Idle, Rough Idle? Brettweiser Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-09-2007 11:10 PM
Rough idle, misfire CEL, car stumbles when cold roksax Service & Maintenance 6 07-22-2006 03:53 PM
High idle, CEL, Outback EJ25, misfire, related? CirrusWRX Normally Aspirated Powertrain 10 05-01-2005 03:11 AM
Rough Idle and CEL 6Pack Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-25-2003 09:46 AM
Spark plug=very rough idle and CEL? Bunuel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-22-2002 11:59 PM
