Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 10-04-2009, 06:42 PM   #1
Member#: 224705
2003 NA Baja sport
Default Wind noise fix!
Was searching around on the nets recently and came across this thread on the Suburu Legacy International forums:
In it the poster describes the prescribed Subaru fix, which involves a lot of measuring and replacing of the gusset around the mirror area and their fix which involves apply a squeezing motion with your fingers. I did the squeezing thing and it worked out great and I know have a HUGE reduction of noise when driving at high speeds (good thing too becouse it was really starting to drive me insane) and since I know this is a common problem I thought I would spread the knowledge to the forums I frequent. Here are some pics of me doing the fix.
Step one: Roll down the window.
Step two: Start to pry off that little plastic triangle thing at the corner of your window, there arent any screws or anything it just pulls off, wih your finger.
Step three: Finish prying it off with a flat head screw driver or something.
Step four: Apply pressure where my thumb is. That little bit is apparently made of a metal that you can bend inwards and close up that gap the window goes in. *
Extra: Since I noticed that the little plastic triangle vibrates a lot during higher speed driving and can cause some noise itself I put some 1/4" microcell foam in it to deaden vibrations (I use this for some other projects I do, a few layers of crafting foam from walmart would probably do the trick as well) though ultimately it doesnt seem to make a difference if its there or not.
Step five: Roll up your window, close your door and go driving on the highway and rejoice at the lack of sound coming from your door.
Note* Play with it a couple times to make sure the seal is tight by rolling the window up and down.
There you go; an easy to follow guide on how to reduce wind noise inside your sooby. If it starts making noise again just do it again.
Cross posted to scoobytruck.com
sabber is offline   Reply With Quote
Old 10-04-2009, 09:45 PM   #2
Member#: 127720
2015 WRX
Lightning Red
Thanks for the info.! I have the tweeters from the stereo(factory) there, so I'll have to see how they're attached.
BajaGuy68 is offline   Reply With Quote
Old 10-05-2009, 07:02 AM   #3
Member#: 192299
2011 Forester XT
Thanks for the Post.
jeromes is offline   Reply With Quote
Old 10-05-2009, 11:28 AM   #4
Member#: 79616
That's it? That's all there is to it?
I was just thinking this weekend that there was an excess amount of wind noise at high speed, and I was going to look up the fix. Low and behold, no searching required, here it is. Nice.
It works. Closed the gap down to 2mm. Took a couple time of rolling up and down the windows to make sure it remains consistent. Jumped on the freeway, got it up to speed, and nice and quiet.
The test drive took more time than the fix
Guzzler is offline   Reply With Quote
Old 10-15-2009, 09:30 PM   #5
Member#: 64311
2003 Baja
Wow! It only took a few minutes to fix! In the 3 days since I tried this the wind noise has been greatly diminished. I have traveled at 70 mph on the freeway and it appears to be gone. The true test will be a day with a good headwind.
YooperBaja is offline   Reply With Quote
Old 10-23-2009, 03:07 PM   #6
Member#: 227846
Thanks for the tip! Three years of nagging wind finally gone
devitol is offline   Reply With Quote
Wind Noise, Wind Noise, Wind Noise b4wantab Legacy Forum 6 01-06-2005 12:53 PM
wind noise fix for the front window biggreen96 Legacy Forum 12 11-17-2002 03:06 AM
mirror wind noise efoo General Forum Archive 7 02-16-2001 04:30 AM
Weird winding noise when I let off the gas... Siper2 General Forum Archive 12 12-09-2000 09:15 AM
